cannot connect to duet 2 Wi-Fi or board
![17079268194356958301088299834109.jpg](Request Entity Too Large) ![17079264559383776398370068987908.jpg](Request Entity Too Large) @droftarts The new board would not connect by USB from the beginning so I did load runonce.g to the system file and I was able to connect buy Wi-Fi to the board and I was configuring the board but just recently I was not able to connect by Wi-Fi it was working fine but now it will not connect by Wi-Fi to the board I mailed the old board on June 28th 2024 I will include a picture of the drop off slip. The new board is set to channel 10 and it is running at 2.4 G and I'm still not able to connect via Wi-Fi! I purchased the original board from printed![1707926955140444270627850315521.jpg](Request Entity Too Large) solid
[17079263815565014596051133997642.jpg](Request Entity Too Large) -
@droftarts I purchased the original board from printedsolid
@Blunt2007 said in cannot connect to duet 2 Wi-Fi or board:
Okay, I'll ask @Phaedrux to check that.
When connected via USB, do you still see the Duet in the device manager? If so, can you right click on it, and take a screenshot of the properties?
For the WiFi, have you set the router channel to 10 on the router? It is not something that the Duet can force, it has to come from the router. When you try to connect via WiFi, does it just not connect and result in a blank screen, or do you get some other message? Again, a screenshot may be useful.
@droftarts Yes on the router it is set to channel 10 at 2.4 I sent you a picture of the router connection and yes via USB it comes up in the Device Manager as duet![17079303616003203406867574172911.jpg](Request Entity Too Large)
@Blunt2007 ![1707930945074619340256192983025.jpg](Request Entity Too Large)
@Blunt2007 please repost your pictures in a size <4mbs so they upload.
@T3P3Tony The resolution that I'm uploading them with is the lowest that's my phone will take the photo in I uploaded them before with some help I don't have a photo editor
Sorry that's the best I can do right this time -
@Blunt2007 take a screenshot and post that
@droftarts I'm sorry My misunderstanding I did not know I needed to open a new ticket with this new board so I contacted printed solid to open a new ticket 42307
Did Printed Solid replace your board already?
undefined Phaedrux referenced this topic
@Phaedrux Yes Prince solutions already replaced the board this is a new board and I'm still not able to connect USB and the Wi-Fi will not connect to duet web connect and if I do connect it loses signal and will not reconnect
@Phaedrux wow it's connected today so I'm going to try running some updates and level in my bed with a BL touch
@Phaedrux having problem connecting to duet Web connect it was working fine for the 2 weeks and I printed a calibration cube and it came out pretty good I had to take two weeks off to take care of my dad and now I'm trying to reconnect to duet web connect and now it will not connect I tried turning off the board turning it back on I tried turning off the computer rebooting the computer several times I tried turning off Wi-Fi and turn it back on no matter what I do it will not connect to the wet web connect
Can you remind me if you were able to get a USB terminal connection going through the YAT software?
@Phaedrux no I had never had been able to connect via USB since I got the board I had to add a file to systems with my Wi-Fi information I haven't tried that yet this time I figured it was working fine when I last used it but now it doesn't work at all no matter what I do I cannot connect to duet web connect
Were you connecting to the DWC by an IP address?
It's possible that after a few weeks the IP address lease from your router has expired, and the IP address the Duet has now is different.
The only way to check this is to either connect by USB terminal to ask the Duet what IP address it currently has and to see if it's otherwise working, or to connect to your wifi router and see if the Duet has connected and what IP address it is using now. This is also the place where you would tell the router to reserve that IP address for the Duet so that it doesn't change in the future. This is called a DHCP reservation, but may have a different name on your router.
Having a working USB connection to the Duet is very useful in cases like this, so I would suggest going through the guide I linked again and seeing if you can get YAT to connect to the Duet. Figuring our how to reserve the IP address in your router would be a good next step.
@Phaedrux I did reserve a IP address in my router for the duet board on my screen when I go under settings it shows that IP address and the screen connects to that router number
@Blunt2007 I will try connecting by USB again I will give you an update in a little bit I got to go to lunch with my mom and dad
@Phaedrux I will try connecting via USB again I will give you an update in a little bit I got to go to lunch with my mom and dad I'll do it when I get back so probably about an hour or so
![Screenshot_20240312-175000.png](Request Entity Too Large) @Phaedrux ![Screenshot_20240312-174844.png](Request Entity Too Large) I tried connecting by USB and it will not connect still I checked my router and it is connecting to the designated IP address that I signed to it to make sure that it was I turned it off checked my router and then turned it on and it came up with the correct IP address connected
