ExecOnMcode with Bullseye DuetPi build
I'm trying the Bullseye build to use libcamera with a pi cam module 3. Is this plugin working on Bullseye? Or would it best to switch back to a previous build and keep using the old cam module 2?
@Forum-user There is no official Bullseye DuetPi build but you can try the experimental Bookworm build if you want to.
@chrishamm the bookworm build works ok (not having any issues with a hdmi screen), although I am running into a problem with the execonmcode plugin with this build as it requires DSF 3.4. Is it possible to update the plugin to 3.5? Happy to look into it if you point me in the right direction.
@Forum-user one for @Falcounet
