Solved 3.5.0rc1: Input shaping causes layer shifts!?
@oliof
Did you mean to add M376 H3 to bed.g (or config.g)?
If so, I did. No change, still layer shifting.config.g
; Axis and motor configuration M569 P0 S1 ; Drive 0 goes forwards M569 P1 S1 ; Drive 1 goes forwards M569 P2 S1 ; Drive 2 goes forwards M569 P3 S1 ; Drive 3 goes backwards M569 P4 S0 ; Drive 4 goes backwards ;M574 X2 Y2 Z2 P1 ; set endstop configuration (all endstops at high end, active high) M574 X2 S1 P"xstop" ; X min active high endstop switch M574 Y2 S1 P"ystop" ; Y min active high endstop switch M574 Z2 S1 P"zstop" ; Z min active high endstop switch ;M665 R175.50 L360.24 B140.0 H467.0 X0.00 Y0.00 Z0.00 ; set delta radius, diagonal rod length, printable radius, homed height and XY tower corrections ;M665 R168.00 L360.24 B140.0 H444.0; X0.00 Y0.00 Z0.00 ; set delta radius, diagonal rod length, printable radius, homed height and XY tower corrections M665 L360.240:360.240:360.240 R171.368 H445.000 B140.0 X0.331 Y-0.086 Z0.000 ;M666 X-0.27 Y0.52 Z-0.26 ; put your endstop adjustments here, or use auto calibration to find them all) M666 X0.00 Y0.00 Z0.00 M584 X0 Y1 Z2 E3 M92 X160.804 Y160.804 Z160.804 ; Set axis steps/mm (20 tooth pulleys, 0.9deg/step motors) M350 Z16 X16 Y16 E16 I1 ; Set 16x microstepping with interpolation ;M579 X1.005 Y1.005 X0.995 ;SCALE M579 X1.000 Y1.000 X1.000 ;SCALE M906 X1300 Y1300 Z1300 E600 I30 ; Set motor currents (mA) ;M201 X800 Y800 Z600 E1000 ; Set accelerations (mm/s^2) ;M203 X12000 Y12000 Z8000 E12000 ; Set maximum speeds (mm/min) ;M566 X700 Y700 Z1000 E1200 ; Maximum instant speed changes M201 X2000 Y2000 Z2000 E6000 ; Set accelerations (mm/s^2) M203 X14000 Y14000 Z10000 E6000 ; Set maximum speeds (mm/min) M566 X1000 Y1000 Z1000 E500 ; Maximum instant speed changes (jerk) G21 ; Work in millimetres G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves ; Thermistors and heaters ;M305 S0 P"bed_temp" Y"thermistor" T100000 B3950 R4700 H0 L0 ; RRF3 Typical Chinese bed thermistor. Put your own H and/or L values here to set the bed thermistor ADC correction. ;M305 S1 P"e0_temp" Y"thermistor" T100000 B4388 R4700 H0 L0 ; RRF3 E3Dv6 hot end. Put your own H and/or L values here if necessary to set the first nozzle thermistor ADC correction. M308 S0 P"bed_temp" Y"thermistor" T100000 B5000 ; define bed temperature sensor ;M308 S1 P"e0_temp" Y"thermistor" T100000 B4725 C7.06e-8 ; define E0 temperature sensor M308 S1 P"e0_temp" Y"thermistor" T100000 B4725 C7.060000e-8 M308 S3 Y"mcu-temp" A"MCUTemp" ; configure sensor 3 as MCU Temperature M950 H0 C"bed_heat" T0 ; heater 0 uses the bed_heat pin, sensor 0 M950 H1 C"e0_heat" T1 ; heater 1 uses the e0_heat pin and sensor 1 M140 H0 ; the bed heater is heater 0 ; Fans M950 F0 C"fan0" Q500 ; Print Fan M950 F1 C"fan1" Q500 ; Hotend Fan M950 F2 C"fan2" Q500 ; MCU FAN M106 P0 H-1 C"Print Fan" M106 P1 H1 S1 T60 C"Hotend Fan" ;S1 I0 F500 H2:2:1 T45 ; set fan 0 name, value, PWM signal inversion and frequency. Thermostatic control is turned on M106 P2 H3 S0.4 T45:65 C"MCU FAN" ; set fan 1 name, value, PWM signal inversion and frequency. Thermostatic control is turned off M301 H0 P20 I0.5 D1000 T0.85 W150 B0 ; PID settings for the bed M301 H1 P10 I0.10 D100 T0.50 ; PID settings for extruder 0 M570 S200 H1 ; Allow extra heating time M143 S300 ; max hotend temp ;M307 H1 A343.1 C127.3 D 6.1 B0 ;From tuning H1 ( M307 H0 F20 M307 H1 R4.141 K0.448:0.326 D2.92 E1.35 S1.00 B0 V24.0 ; Tool definitions M563 P0 D0 H1 ; Define tool 0 G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures ;M92 E450 ;old 475 ; Set extruder steps per mm for first and second extruders M92 E690 ; Set extruder steps per mm for first and second extruders ; CPU fan 60% ;M106 P1 H-1 ;M106 P1 S0.6 ;M106 P1 T45:65 H100:101:102 ; Z probe and compensation definition ;M558 P5 R0.4 F1000 T16000 ; Z probe is IR and is not used for homing any axes, Z probe dive height 3mm, probing speed 300mm/min, travel speed 12000mm/min ;M558 P5 C"e0stop" H5 F1000 T16000 ;G31 P100 X0 Y0 Z-0.12 ; Set the zprobe offset and threshold (put your own values here). For a delta, use zero X and Y offset. ;Duet3d Recommended M558 P8 C"zprobe.in+zprobe.mod" H4 F1000 T12000 R0.2 S0.02 A7 ;G31 X0 Y0 Z-0.12 P100 ; org - changed 201021-1627 ;G31 X0 Y0 Z-0.07 P100 ; s3d settings G31 X0 Y0 Z-0.0 P100 ; cura settings ;M572 D0 S0.12 ; set pressure advance M572 D0 S0.03 ; set pressure advance T0 ; select first print head ; Grid based M557 R130 S35 M501
config-override.g
; config-override.g file generated in response to M500 at 2023-10-29 18:24 ; This is a system-generated file - do not edit ; Delta parameters M665 L367.003:367.003:367.003 R161.017 H444.611 B140.0 X0.450 Y-0.055 Z0.000 M666 X-2.732 Y1.370 Z1.362 A0.75 B1.27 ; Heater model parameters M307 H0 R0.129 K0.143:0.000 D10.00 E1.00 S1.00 B1 M301 H0 P20.0 I0.500 D1000.0 M307 H1 R4.141 K0.448:0.326 D2.92 E1.35 S1.00 B0 V24.0 M301 H1 P10.0 I0.100 D100.0 ; Workplace coordinates G10 L2 P1 X0.00 Y0.00 Z0.00 G10 L2 P2 X0.00 Y0.00 Z0.00 G10 L2 P3 X0.00 Y0.00 Z0.00 G10 L2 P4 X0.00 Y0.00 Z0.00 G10 L2 P5 X0.00 Y0.00 Z0.00 G10 L2 P6 X0.00 Y0.00 Z0.00 G10 L2 P7 X0.00 Y0.00 Z0.00 G10 L2 P8 X0.00 Y0.00 Z0.00 G10 L2 P9 X0.00 Y0.00 Z0.00
bed.g
; Auto calibration routine for large delta printer with IR probe M561 ; clear any bed transform, otherwise homing may be at the wrong height ;G28 ; home the printer M376 H3 ; Probe the bed and do auto calibration G1 X0 Y0 Z10 F10000 ; go to just above the first probe point to speed up probing ; bed.g file for RepRapFirmware, generated by Escher3D calculator ; 16 points, 6 factors, probing radius: 110, probe offset (0, 0) ; bed offset IRH param after () REMOVE added Z-start Zstart=+1.0 (0.5mm measure thickness + 1.0mm added for negative to work) ; (Bedoff+IR)-(0.5+1.38) lower value = nozzle closer to bed G30 P0 X0.00 Y110.00 Z-99999 ; H0.05 ; 2.27 - 1.73 G30 P1 X55.00 Y95.26 Z-99999 ; H0.10 ; 2.49 - 1.92 (org H0.1) G30 P2 X95.26 Y55.00 Z-99999 ; H0.10 ; 2.42 - 1.94 (org H0.02) G30 P3 X110.00 Y0.00 Z-99999 ;H0.15 ; 2.12 - 1.70 G30 P4 X95.26 Y-55.00 Z-99999 ; H-0.20 ; 1.75 - 1.41 G30 P5 X55.00 Y-95.26 Z-99999 ; H-0.20 ; 1.50 - 1.18 G30 P6 X0.00 Y-110.00 Z-99999 ; H0.05 ; 1.43 - 1.08 G30 P7 X-55.00 Y-95.26 Z-99999 ;H0.03 ; 1.49 - 1.06 G30 P8 X-95.26 Y-55.00 Z-99999 ; H0.05 ; 1.67 - 1.19 G30 P9 X-110.00 Y0.00 Z-99999 ; ;H0.08 ; 1.74 - 1.24 G30 P10 X-95.26 Y55.00 Z-99999 ; ;H0.00 ; 1.88 - 1.37 G30 P11 X-55.00 Y95.26 Z-99999 ; ;H0.00 ; 2.02 - 1.50 G30 P12 X0.00 Y55.00 Z-99999 ; ;H-0.45 ; 1.88 - 1.37 G30 P13 X47.63 Y-27.50 Z-99999 ; H-0.10 ; 1.69 - 1.33 G30 P14 X-47.63 Y-27.50 Z-99999 ; ;H-0.00 ; 1.66 - 1.25 G30 P15 X0 Y0 Z-99999 S9 ; 1.71 1.71 - 1.25 0.46 G1 X0 Y0 Z150 F15000 ; get the head out of the way of the bed
Seeing now (not sure how I missed it) that there is already another thread on this.
@Jimborr Ah, yes, that seems to be something else that affects Delta printers.
undefined NeoDue referenced this topic
Sorry to resurrect this. was there every a resolution to this problem? I am running into similar issues. I am also showing tons of errors on CAN. Here is the diagnostic after a skip log:
m122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.5.0-rc.2 (2023-12-14 10:32:22) running on Duet 3 MB6HC v1.01 (standalone mode) Board ID: 08DJM-956BA-NA3TJ-6JTD8-3SJ6J-1UA2U Used output buffers: 3 of 40 (40 max) === RTOS === Static ram: 154844 Dynamic ram: 121700 of which 104 recycled Never used RAM 65432, free system stack 129 words Tasks: NETWORK(1,ready,37.6%,145) ETHERNET(5,nWait,0.1%,317) HEAT(3,nWait,0.0%,307) Move(4,nWait,1.2%,217) CanReceiv(6,nWait,0.0%,942) CanSender(5,nWait,0.0%,334) CanClock(7,delaying,0.0%,342) TMC(4,nWait,8.7%,59) MAIN(1,running,52.3%,103) IDLE(0,ready,0.0%,30), total 100.0% Owned mutexes: === Platform === Last reset 00:57:30 ago, cause: software Last software reset at 2024-01-04 23:56, reason: User, Gcodes spinning, available RAM 96264, slot 2 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x04 MCU temperature: min 31.1, current 32.5, max 32.7 Supply voltage: min 23.7, current 23.7, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.0, current 12.1, max 12.2, under voltage events: 0 Heap OK, handles allocated/used 99/8, heap memory allocated/used/recyclable 2048/544/396, gc cycles 0 Events: 1 queued, 1 completed Driver 0: ok, SG min 0, mspos 897, reads 63179, writes 4 timeouts 0 Driver 1: ok, SG min 0, mspos 280, reads 63180, writes 4 timeouts 0 Driver 2: ok, SG min 0, mspos 280, reads 63179, writes 4 timeouts 0 Driver 3: ok, SG min 0, mspos 232, reads 63179, writes 4 timeouts 0 Driver 4: ok, SG min 0, mspos 472, reads 63179, writes 4 timeouts 0 Driver 5: phase A may be disconnected, SG min 0, mspos 361, reads 63180, writes 3 timeouts 0 Date/time: 2024-01-05 00:55:37 Slowest loop: 206.82ms; fastest: 0.05ms === Storage === Free file entries: 18 SD card 0 detected, interface speed: 25.0MBytes/sec SD card longest read time 3.1ms, write time 1.1ms, max retries 0 === Move === DMs created 125, segments created 44, maxWait 132190ms, bed compensation in use: mesh, height map offset -0.034, max steps late 1, ebfmin -1.00, ebfmax 1.00 next step interrupt due in 84 ticks, disabled Moves shaped first try 986, on retry 262, too short 1372, wrong shape 2444, maybepossible 169 === DDARing 0 === Scheduled moves 7741, completed 7701, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state 3 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters 2 -1 -1 -1, ordering errs 0 Heater 1 is on, I-accum = 0.3 Heater 2 is on, I-accum = 0.0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is doing "G1 F6000 X98.532 Y184.403 E1.64932" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 1, axes/extruders owned 0x80000007 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === Filament sensors === check 3911776 clear 15534836 Extruder 0: no data received, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0 === CAN === Messages queued 4954, received 0, lost 0, errs 2619108, boc 0 Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 2752/0/0 Tx timeouts 0,0,2752,0,0,2202 last cancelled message type 4514 dest 127 === Network === Slowest loop: 142.85ms; fastest: 0.03ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0) HTTP sessions: 1 of 8 = Ethernet = Interface state: active Error counts: 0 0 0 0 0 0 Socket states: 5 2 2 2 2 0 0 0 === Multicast handler === Responder is inactive, messages received 0, responses 0
I am also having issues uploading files. I switched SD cards and the problem persists. Sometimes they will upload but I have to keep retrying and eventually it uploads. I can still ping the IP when it disconnects.
I don't know if my board is on the way out or what. It has been nothing but problems over the last 2 months. I recently disassembled the entire printer and reconnected everything. My random crashes have stopped (for now) but these other issues are getting worse.
Here is my config:
;Initialize variables if !exists(global.materialtype) global materialtype = "" if !exists(global.materialprint) global materialprint = "" if !exists(global.materialstandby) global materialstandby = "" if !exists(global.materialbed) global materialbed = "" if !exists(global.machineheater) global machineheater = 0 if !exists(global.inFilamentError) global inFilamentError = false ;General Setup - RailCore RRF Duet3 M552 P0.0.0.0 S1 G21 ;Work in millimetres G90 ;Send absolute coordinates... M83 ;...but relative extruder moves ; Stepper configuration M569 P1 S1 D3 ;Drive 0 X / Rear M569 P0 S0 D3 ;Drive 1 Y / Front ;M569 P0 S0 D3 ;Drive 0 X / Rear ;M569 P1 S1 D3 ;Drive 1 Y / Front M569 P2 S1 D3 ;Drive 2 Z Front Left M569 P3 S1 D3 ;Drive 3 Z Rear Left M569 P4 S1 D3 ;Drive 4 Z Right M569 P5 S1 D3 ;Drive 5 Extruder ;Axis configuration M669 K1 ;CoreXY mode M584 X0 Y1 Z2:3:4 E5 ;Map X to drive 0 Y to drive 1, Z to drives 2, 3, 4, and E to drive 5 ;Leadscrew locations M671 X-13.6:-13.3:340 Y22:278:149 S7.5 M350 X16 Y16 Z16 E16 I1 ;Set 16x microstepping for axes with interpolation M906 X1500 Y1500 Z1200 E1200 I30 ;Set motor currents (mA) ; Fully commissioned speeds. M201 X3000 Y3000 Z100 E1500 ; Accelerations (mm/s^2) M203 X24000 Y24000 Z800 E3600 ; Maximum speeds (mm/min) M566 X1000 Y1000 Z100 E600 P1 ; Maximum jerk speeds mm/minute M208 X290 Y290 Z275 ;Set axis maxima and high homing switch positions (adjust to suit your machine) M208 X0 Y0 Z0 S1 ;Set axis minima and low homing switch positions (adjust to make X=0 and Y=0 the edges of the bed) M92 X200 Y200 Z1600 E696 ;Orbiter ;M92 X200 Y201 Z1600 E835 ;Bowden ; End Stops M574 X1 S1 P"io1.in" ;Map the X endstop to io1.in M574 Y1 S1 P"io2.in" ;May the Y endstop to io2.in ; Filament Sensor M591 D0 P5 C"io5.in" R60:215 E3.0 S0 A1 L0.406 ;Duet3D laser sensor for extruder drive 0, connected to IO 5, tolerance 60 to 215%, 3mm comparison length, disabled ; Thermistors M308 S2 P"temp0" Y"thermistor" A"chamber_temp" T100000 B3950 H0 L0 ;Chamber thermistor M308 S0 P"temp2" Y"thermistor" A"plate_heat" T100000 B3960 H0 L0 ;Plate thermistor M308 S1 P"temp1" Y"thermistor" A"e0_heat" T100000 B4725 C7.06e-8 H0 L0 ;E3D thermistor ;Define Heaters M950 H0 C"out0" T0 ;Bed heater is on out0 M950 H1 C"out1" T1 ;Hotend heater is on out1 M950 H2 C"out2" T2 ;Chamber heater is on out2 ;Define Bed M140 H0 ;Define Chamber M141 H2 M307 H0 R0.394 K0.158:0.000 D13.55 E1.35 S1.00 B0 ;Bed Duet 3 configuration M307 H1 R2.812 K0.374:0.000 D4.13 E1.35 S1.00 B0 V23.8 ;Phaetus Hotend Duet 3 configuration M307 H2 R0.048 K0.134:0.000 D16.81 E1.35 S1.00 B0 ;Chamber calibration ;M307 H2 R0.425 K0.744:0.000 D14.76 E1.35 S1.00 B0 ;old hotend value M307 H1 A310.1 C144.7 D2.6 S1.00 B0 ;old bed value M307 H0 A90.0 C700.0 D10.0 S1.00 B0 M570 H0 T15 ;Set hot end fault behaviour. 15C excursion before error M143 H1 S300 ;Set max hotend temperature M143 H0 S150 ;Set max bed temp ; Fans M950 F0 C"out6" Q100 ;Layer fan on "out6" connector M106 P0 S0 H-1 C"Part Fan" ;Layer fan M950 F1 C"out8" ;Hotend fan on "out8" connector without PWM M106 P1 C"Hotend Fan" ;M106 P1 S255 H1 T50 "Hotend Fan" ;enable thermostatic mode for hotend fan M950 F2 C"out7" Q2500 ;Heater cooling fan on "out7" connector M106 P2 S0 C"Cooling Fan" ;Heater cooling fan M950 F3 C"out4" ;Extruder fan on "out4" connector M106 P3 T40 H2 C"Extruder Fan" ;Extruder fan ; Accelerometer ;M955 P0 I50 C"spi.cs3+spi.cs2" ; all wires connected to temp DB connector ; Input Shaping M593 P"zvd" F70 S0.3 ; Tool definitions M563 P0 D0 H1 F0 ;Define tool 0 uses extruder 1, heater 1 and fan 1 G10 P0 S0 R0 ;Set tool 0 operating and standby temperatures ; Pressure Advance ;M572 D0 S0.06 ; set extruder 0 pressure advance to 0.01 seconds ; Euclid M558 P5 C"^io0.in" H2 F250:15 T24000 A6 S0.02 ;Tip: A larger trigger height in G31 moves you CLOSER to the bed G31 X1 Y37.5 Z6.58 P25 ;Nozzle-X set the probe offsets ;G31 X0 Y40 Z2.8 P25 ;0.25mm nozzle set the probe offsets T0 ;Select first hot end
@agmeadows I have a couple of suggestions:
Do you have a PanelDue connected? One known cause of network disconnections is running older PanelDueFirmware with recent versions of RRF. Older PanelDueFirmware can't handle the longer object model keys in more recent versions of RRF, causing PanelDueFirmware to recognis that it doesn't have enough buffer space and abandon the JSON parse. Unfortunately it then asks for the data again immediately without leaving a pause. This is fixed in recent beta versions of PaneDueFirmware.
The large number of CAN errors probably means that you have a CAN wiring error, or perhaps that you have two boards configured to use the same CAN address. I suggest you try disconnecting some boards from CAN to see which one(s) trigger the errors. Also check that all boards are running the same 3.5.0-rc.2.
@dc42 I do not have a PanelDue connected. Also, I don't have any second boards connected. I downgraded to 3.5.0-beta.4 which seemed to resolve the layer shifts, but the errors and connection issues persist. If I keep retrying it eventually goes through. The larger the file the more I have to retry.
This is the log after a reset, boot up and then home all:
m122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.5.0-beta.4 (2023-06-08 23:41:30) running on Duet 3 MB6HC v1.01 (standalone mode) Board ID: 08DJM-956BA-NA3TJ-6JTD8-3SJ6J-1UA2U Used output buffers: 1 of 40 (28 max) === RTOS === Static ram: 155012 Dynamic ram: 121864 of which 120 recycled Never used RAM 65756, free system stack 117 words Tasks: NETWORK(1,ready,38.1%,182) ETHERNET(5,nWait,0.1%,317) HEAT(3,nWait,0.0%,325) Move(4,nWait,0.0%,251) CanReceiv(6,nWait,0.0%,941) CanSender(5,nWait,0.0%,335) CanClock(7,delaying,0.0%,343) TMC(4,nWait,8.5%,59) MAIN(1,running,53.2%,137) IDLE(0,ready,0.0%,30), total 100.0% Owned mutexes: === Platform === Last reset 00:18:27 ago, cause: power up Last software reset at 2024-01-04 23:56, reason: User, Gcodes spinning, available RAM 96264, slot 2 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 MCU temperature: min 21.1, current 30.5, max 31.5 Supply voltage: min 23.8, current 23.8, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.0, current 12.1, max 12.2, under voltage events: 0 Heap OK, handles allocated/used 99/6, heap memory allocated/used/recyclable 2048/372/268, gc cycles 0 Events: 0 queued, 0 completed Driver 0: standstill, SG min 0, mspos 328, reads 14665, writes 21 timeouts 0 Driver 1: standstill, SG min 0, mspos 200, reads 14665, writes 21 timeouts 0 Driver 2: standstill, SG min 0, mspos 120, reads 14665, writes 21 timeouts 0 Driver 3: standstill, SG min 0, mspos 168, reads 14665, writes 21 timeouts 0 Driver 4: standstill, SG min 0, mspos 744, reads 14665, writes 21 timeouts 0 Driver 5: standstill, SG min n/a, mspos 8, reads 14671, writes 16 timeouts 0 Date/time: 2024-01-09 22:46:22 Slowest loop: 42.83ms; fastest: 0.08ms === Storage === Free file entries: 20 SD card 0 detected, interface speed: 25.0MBytes/sec SD card longest read time 2.4ms, write time 18.5ms, max retries 0 === Move === DMs created 125, segments created 16, maxWait 728978ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled === DDARing 0 === Scheduled moves 50, completed 50, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters 2 -1 -1 -1, ordering errs 0 Heater 1 is on, I-accum = 0.0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x80000007 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === Filament sensors === Extruder 0: no data received === CAN === Messages queued 9968, received 0, lost 0, boc 0 Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 5539/0/0 Tx timeouts 0,0,5538,0,0,4428 last cancelled message type 4514 dest 127 === Network === Slowest loop: 1589.55ms; fastest: 0.03ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0) HTTP sessions: 2 of 8 = Ethernet = Interface state: active Error counts: 0 0 0 1 0 0 Socket states: 5 5 2 2 2 0 0 0 === Multicast handler === Responder is inactive, messages received 0, responses 0
@agmeadows Just to be clear, can you confirm that you do not have any CAN based boards connected to the main control board? Do you have anything connected to the CAN connector on the board? Perhaps a photo of the board showing your connections would help?
@gloomyandy I have no additional boards connected to the 6HC and nothing plugged into the RJ11 connector. Here are two pictures of the board:
I am having strange disconnects as well when uploading files. I spoke with another person on the Railcore Discord server and they are having the same issue. They said, and I quote, "When uploading g code files to my duet3 connection is lost. The larger the file the larger the chance that connection is lost during upload. Using a wired connection directly to the duet."
I am doing the same thing. I had a keystone hack mounted on an external panel. I bypassed that and plugged straight in and it still had the issue.
@agmeadows do you see later shifts?
I see there is this thread:
https://forum.duet3d.com/topic/34247/duet-6hc-randomly-crasing-again/16?_=1705047609298Where you are discussing the crashes you see on the 6HC.
@T3P3Tony Yes. I have since disassembled the printer and reassembled it. The crashing seems to be resolved. Mind you, I could go several months without a problem.
The board just seems to be acting strange. Either the board or the firmware.
@NeoDue I was seeing major layer shifting on 3.5.0-rc2, like an inch or two at a certain height consistently on a certain print I was doing. Going back to 3.4.6 resolved the issue. Seems like there are still some major kinks to work out in rc2. This was on a railcore II with a duet2 wifi and duex.
@skrotz Thanks for the information! I guess your message saves me from re-testing with 3.5.0rc2 for now, at least until the Duet team asks me to do some tests.
I am aware that it works with 3.4.6. But I am afraid going back is not an option for me since I use some of the new functionality introduced in 3.5.
Thus, no input shaping for me until this issue is resolved.
@skrotz One more thing: it might be great to keep / post the affected print file and your config.g from when the issue happened here to give the Duet team the chance to take a look at these files as well.
Github issue:
https://github.com/Duet3D/RepRapFirmware/issues/945 -
@NeoDue and @skrotz please can you both try the firmware at https://www.dropbox.com/scl/fo/8mwsfwo61tacbyxsu39j9/h?rlkey=zwyd8luhpj7hnanldm4rzm5om&dl=0. If you encounter any layer shifts, then to help me track down the cause please report the following:
- A M122 report taken after layer shifts have occurred. Don't run M122 more than once unless further layer shifts occur, because each time M122 is run it clears the data it reports, and I want the data that may relate to a layer shift.
- Your config.g file
- What M593 input shaping command you were using, if it isn't in the config.g file
- What height the layer shift(s) occurred at
- A link to the GCode file you were printing.
Also please verify that you don't get layer shifts if you do the same print with input shaping disabled (i.e. M593 P"none").
@dc42 thanks! I might only be able to do that the coming weekend, but I definitely will as soon as I can!
Made test print with your rc2+ firmware. Layer shifted at 16,05mm
I didn't get M122 directly after layer shift, I did it when I disovered it.
M122 toolhead
M122 B121 Diagnostics for board 121: Duet TOOL1LC rev 1.1 or later firmware version 3.5.0-rc.2 (2023-12-14 08:58:51) Bootloader ID: SAMC21 bootloader version 2.8 (2023-07-25) All averaging filters OK Never used RAM 2672, free system stack 89 words Tasks: Move(3,nWait,1.6%,71) HEAT(2,nWait,6.4%,91) CanAsync(5,nWait,0.0%,54) CanRecv(3,nWait,0.6%,77) CanClock(5,nWait,0.4%,67) ACCEL(3,nWait,0.0%,17) TMC(2,nWait,61.9%,57) MAIN(1,running,86.2%,316) IDLE(0,ready,0.0%,27) AIN(2,delaying,92.7%,114), total 249.8% Last reset 21:44:27 ago, cause: software Last software reset time unknown, reason: OutOfMemory, available RAM 16088, slot 0 Software reset code 0x01c0 ICSR 0x00000000 SP 0x20002770 Task MAIN Freestk 784 ok Stack: 00004000 00005e8b 00004000 000041cf a5a5a5a5 00004000 a5a5a5a5 a5a5a5a5 a5a5a5a5 0001d199 a5a5a5a5 0001d1b5 a5a5a5a5 00005a4f a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 Driver 0: pos 0, 617.6 steps/mm, ok, SG min 0, read errors 2, write errors 1, ifcnt 144, reads 54569, writes 16, timeouts 140, DMA errors 0, CC errors 0, failedOp 0x71, steps req 0 done 15440450 Moves scheduled 261208, completed 261207, in progress 1, hiccups 4282, segs 40, step errors 0, maxLate 1 maxPrep 564, maxOverdue 5374, maxInc 2158, mcErrs 0, gcmErrs 0, ebfmin -1.00 max 1.00 Peak sync jitter -6/8, peak Rx sync delay 260, resyncs 0/0, no timer interrupt scheduled VIN voltage: min 24.2, current 24.4, max 29.8 MCU temperature: min 28.9C, current 75.1C, max 75.2C Last sensors broadcast 0x00001002 found 2 241 ticks ago, 0 ordering errs, loop time 0 CAN messages queued 1568794, send timeouts 6, received 969293, lost 0, errs 34187, boc 0, free buffers 18, min 17, error reg 110000 Last cancelled message type 4525 dest 0 dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 420, adv 35575/74660 Accelerometer: LIS3DH, status: 00 Inductive sensor: not found I2C bus errors 0, naks 6, contentions 0, other errors 0
M122 Mainboard
M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.2+ (2024-01-15 11:56:10) running on Duet 3 Mini5plus Ethernet (standalone mode) Board ID: KHLQ8-GU8LU-F65J0-409N2-1313Z-H6T1G Used output buffers: 8 of 40 (32 max) === RTOS === Static ram: 103168 Dynamic ram: 116132 of which 16 recycled Never used RAM 18404, free system stack 128 words Tasks: NETWORK(1,ready,23.0%,173) ETHERNET(5,nWait 7,0.2%,569) HEAT(3,nWait 6,0.7%,326) Move(4,nWait 6,6.8%,241) CanReceiv(6,nWait 1,1.0%,774) CanSender(5,nWait 7,0.2%,327) CanClock(7,delaying,0.1%,348) TMC(4,nWait 6,15.4%,66) MAIN(1,running,35.8%,667) IDLE(0,ready,0.0%,30) AIN(4,delaying,16.6%,256), total 100.0% Owned mutexes: === Platform === Last reset 21:45:00 ago, cause: software Last software reset at 2024-01-15 21:55, reason: User, Gcodes spinning, available RAM 27976, slot 2 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 78301312, completed 78301310, timed out 0, errs 0 MCU temperature: min 17.7, current 33.9, max 34.4 Supply voltage: min 23.7, current 23.8, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/3, heap memory allocated/used/recyclable 2048/1296/1220, gc cycles 0 Events: 1 queued, 1 completed Driver 0: ok, SG min 0, read errors 0, write errors 1, ifcnt 196, reads 57358, writes 25, timeouts 0, DMA errors 0, CC errors 0 Driver 1: ok, SG min 0, read errors 0, write errors 1, ifcnt 196, reads 57358, writes 25, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 39, reads 57352, writes 30, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 38, reads 57352, writes 30, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 37, reads 57353, writes 30, timeouts 0, DMA errors 0, CC errors 0 Driver 5: not present Driver 6: not present Date/time: 2024-01-16 19:51:08 Cache data hit count 4294967295 Slowest loop: 258.21ms; fastest: 0.11ms === Storage === Free file entries: 18 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 4.8ms, write time 10.9ms, max retries 0 === Move === DMs created 83, segments created 35, maxWait 68167851ms, bed compensation in use: none, height map offset 0.000, max steps late 1, ebfmin 0.00, ebfmax 0.00 next step interrupt due in 35 ticks, enabled Moves shaped first try 9805, on retry 12276, too short 53284, wrong shape 153332, maybepossible 8084 === DDARing 0 === Scheduled moves 281191, completed 281158, hiccups 0, stepErrors 0, LaErrors 211, Underruns [0, 0, 5], CDDA state 3 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters 9 -1 -1 -1, ordering errs 0 Heater 0 is on, I-accum = 0.5 Heater 1 is on, I-accum = 0.0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is doing "G1 X220.349 Y71.367 E.00382" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is doing "M0" in state(s) 0, sync state 1 Queue2 is idle in state(s) 0 Q0 segments left 1, axes/extruders owned 0x0000807 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === CAN === Messages queued 970855, received 1569669, lost 0, errs 1, boc 0 Longest wait 5ms for reply type 4014, peak Tx sync delay 420, free buffers 26 (min 24), ts 391502/391501/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 230.49ms; fastest: 0.03ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 = Ethernet = Interface state: active Error counts: 0 0 9158 0 0 0 Socket states: 5 2 2 2 2 2 0 0
config.g
; Configuration file for Duet 3 Mini 5+ (firmware version 3.5) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3.16 on Thu Nov 23 2023 20:11:54 GMT+0200 (Eastern European Standard Time) ; General preferences M575 P1 S1 B57600 ; enable support for PanelDue G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"VT1011" ; set printer name M669 K1 ; select CoreXY mode ; Wait a moment for the CAN expansion boards to start G4 S2 ; Network M552 P192.168.90.200 S1 ; enable network and set IP address M553 P255.255.255.0 ; set netmask M554 P192.168.90.1 ; set gateway M586 P0 S1 ; enable HTTP M586 P1 S1 ; enable FTP M586 P2 S0 ; disable Telnet ; --- Drive map --- ; (While looking at the printer top down) ; 0.0-----0.1 ; | 0.2 | ; |-------| ; |0.3|0.4| ; ---+--- ; Front ; Drives for X & Y M569 P0.0 S1 D2 ; physical drive 0.0 goes forwards M569 P0.1 S1 D2 ; physical drive 0.1 goes forwards ; Drives for Z M569 P0.2 S0 D3 ; physical drive 0.2 goes backwards Stealthchop | Z1 M569 P0.3 S0 D3 ; physical drive 0.3 goes backwards Stealthchop | Z0 M569 P0.4 S0 D3 ; physical drive 0.4 goes backwards Stealthchop | Z2 ; Drive for Extruder M569 P121.0 S0 D2 ; physical drive 121.0 goes backwards ; Motor mapping and steps per mm M584 X0.0 Y0.1 Z0.3:0.2:0.4 E121.0 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X160 Y160 Z800 ; set steps per mm M92 E617.6470588 ; galileo 2 steps per mm ; Drive currents M906 X1700 Y1700 Z1000 E700 I30 ; set motor currents (mA) and motor idle factor in per cent M84 X Y Z E0 S30 ; Set idle timeout ; Axis accelerations and speeds M566 X500 Y500 Z120 E300 P1 ; set maximum instantaneous speed changes (mm/min) M203 X18000 Y18000 Z900 E7200 ; set maximum speeds (mm/min) M201 X8000 Y8000.00 Z350 E2000 ; set accelerations (mm/s^2) ; Reduced accelerations ;M201.1 X500 Y500 Z80 E500 ; Set reduced acceleration for special move types (mm/s²) ; Printing and travel accelerations M204 P5000 T7000 ; Set printing acceleration and travel accelerations (mm/s²) ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minimal M208 X300 Y305 Z240 S0 ; set axis maximal ; Endstops M574 X2 S1 P"121.io1.in" ; configure sensorless endstop for high end on X M574 Y2 S1 P"io6.in" ; configure sensorless endstop for high end on Y ; Klicky M558 P8 C"^121.io2.in" T18000 F600:180 H2 A10 S0.01 ; set Z probe type to KLICKY and the dive height + speeds G31 P500 X0 Y28 Z4.80 ; 5,4 set Z probe trigger value, offset and trigger height(Z_offset - bigger number bed closer to nozzle) ; Bed leveling M671 X-50:150:350 Y18:348:18 S5 ; front left, back, front right M557 X15:285 Y30:285 P5 ; define grid for mesh bed compensation, bed mesh distance 83mm to get 4x4 square ; Accelerometer M955 P121.0 I10 ; Configure accelerometer M593 P"mzv" F25 S0.01 L0.15 ; disabled 3.5.0rc1 has layer shift issues when IS enabled ; Heaters ; Bed heater M308 S0 P"temp0" Y"thermistor" T100000 B4725 C7.06e-8 A"Bed" ; 4138 configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M143 H0 A2 C0 S120 ; Make sure bed heater stays below 120C M143 H0 A1 C0 S125 ; Make sure bed heater shuts down at 125C ; Hodend heater M308 S1 P"121.temp0" Y"pt1000" A"Hotend" ; configure sensor 1 as thermistor on pin 121.temp0 M950 H1 C"121.out0" T1 ; create nozzle heater output on 121.out0 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S350 ; set temperature limit for heater 1 to 350C ; Chamber heater M308 S9 P"temp1" Y"thermistor" A"Chamber" T100000 B4725 C7.06e-8 ; Chamber thermistor conf - ATC Semitec 104NT-4-R025H42G M950 H9 C"io5.in" Q1 T9 ; dummy port used M307 H9 B0 S1.00 M141 H9 ; fake chamber heater for reporting in DWC M143 H9 P0 S40 A2 M143 H9 P1 S60 ; Duet5+ mcu temp M308 S3 Y"mcu-temp" A"MCU" ; Configure sensor 2 as MCU temperature M912 P0 S-2.9 ; MCU temp calibration parameters ; toolhead temp M308 S12 Y"mcu-temp" P"121.dummy" A"1LC MCU" ; Fans ;Part cooling M950 F0 C"121.out1" ; create fan 0 on pin 121.out1 and set its frequency M106 P0 S0 H-1 C"Part Cooling" ; set fan 0 value. Thermostatic control is turned off ;Hotend fan M950 F1 C"121.out2" ; create fan 1 on pin 121.out2 and set its frequency M106 P1 S1 H1 T45 C"Hotend Fan" ; set fan 1 value. Thermostatic control is turned on ; Bed fan M950 F2 C"out3" ; create fan 2 on pin out3 and set its frequency M106 P2 C"BEDF_12V" S0 H-1 ; set fan 2 value. Thermostatic control is turned on ; Exhaust fan M950 F3 C"out6" ; create fan 3 on pin out6 and set its frequency M106 P3 C"EXHAUSTF" S0 B0.1 H9 T45 ; set fan 3 value. Thermostatic control is turned on ; Nevermore filter M950 F4 C"out5" ; create fan 4 on pin out5 and set its frequency M106 P4 C"FILTER" S0 B0.1 H0 T90 ; set fan 4 value. Thermostatic control is turned on ; Tools M563 P0 S"Mosquito Magnum" D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M950 P0 C"out1" ; Create output Port0 attached to out1 connector for LED lights M501 ; load saved parameters from non-volatile memory T0 ; select first tool
Print file 3DBenchy-Voron-Trident-300-0.4-nozzle-1011-ABS-Orange-Polymaker.gcode
Active IS graph IS
@vaike_peeter do you have a spec sheet of your stepper drivers at hand?
Z-motors - LDO-42STH40-1684L300E
A and B(x,y) motors - LDO-42STH48-2004MAH
I already checked current if you think that.
