Multiple Print Failures
@Dr_Ju_Ju Did this printer work OK at some point? If it did, what has changed since then?
@gloomyandy
yes it used to work fine, and even now it can still produce some great prints !! but it also wastes filament & time when it just stops at some point during a print -
@Dr_Ju_Ju So what if anything has changed since it was working well? Have you updated anything? Changed any of the printer hardware?
@gloomyandy
no hardware changes, & just the normal software updates pre & post the problems ... -
If you have spare hardware can you try swapping the Pi and then the Duet with one that is working?
@Dr_Ju_Ju do you really need to run in SBC mode? If you're not using something like pythonDSF I would just ditch the pi and run in standalone mode
I don't have a spare Pi @ the mo, but I do have a Rock64 / Rock64Pro spare both running Mate, so will the Duet SBC software run on them ??
I suppose it comes down to what the Voron recommendations were, also I originally tried a Duet2 ethernet (not on this 'Voron' but a previous iteration), in non SBC mode, which was an abject failure, so I was hoping that a Duet3-SBC, would be better....
@Dr_Ju_Ju IMO, standalone mode is better. Majority of my machines run as standalone
Hi I've a similar problem sometimes in SBC mode - https://forum.duet3d.com/topic/34315/rff-3-5-0-rc1-spi-reset-mid-print
since chris gave me the hint about the interference I was working on that topic to get down to the problem. So I hooked everthing up to a spectrum analyzer and saw that the 8MHz SPI bus is generating a lot of noice and harmonics.
green line is the 6xd in standalone mode, and the pink color is the 6xd in sbc (rock 4c+) with 130mm ribbon cable without ferrit or shielding.
the green line is the 6xd in sbc mode with 30mm ribbon cable.
the following shows in pink the 6xd connected to the rockpi c4+ with 130mm ribbon cable with one ferrit 139 Ohm @ 100MHz on the sbc side.
the following shows the 130mm ribbon cable without a ferrit but aluminium foil as shield.
for reference the rock 4c+ without the duet
so it can be seen from the above, that shielding and ferrit will help to reduce emi and emc - I'm working on that topic, as it is not satisfying for me.
Maybe, you can put a ferrit core around the ribbon cable and make it shorter as a quick measure.
But anyhow, the print should not stop, even if the spi need to do a restart - that should be handled by the software to do a resume - as I can do a manual resume in such case.
@timschneider The SPI protocol between Duet and SBC is designed to retry three times in a row on failed transfers. If that count is exceeded, both endpoints reset the connection.
