Solved stop.g didn't run at end of print - 3.5.0-b4
Just finished a print, and when I went to check in on the printer the nozzle stood still exactly where the print had finished (and had stood there for a while).
Thankfully i cought it before anything catastrophic happened, but i can't get why on earth this happened. I have ran 6 prints sliced with the exact same slicer profile/settings, filament etc. back to back prior to this happening. The only thing different with the print who failed is that it was a couple hours longer than the others, and i had a filament runout happen during the print (loaded a new spool, purged manually and resumed the print again).
Here is the last portion of the job file:
G11 ; unretract M205 X7 Y7 ;WIDTH:0.40688 G1 F12000 G1 X201.139 Y144.363 E.00457 ;WIDTH:0.401572 G1 X194.095 Y139.556 E.24667 ;WIDTH:0.43104 G1 X193.915 Y139.414 E.00718 ;WIDTH:0.460508 G1 X193.734 Y139.273 E.00772 ; stop printing object basket-lid.stl id:80 copy 0 G10 ; retract M106 S0 ;TYPE:Custom ; filament end gcode ; Filament-specific end G-code START ; ; Filament specific end G-code: END ; End G-code: START ; ; End G-code: END M73 P100 R0 ; EXECUTABLE_BLOCK_END
Here is the relevant section from the debug log:
2023-12-20 17:28:29 [warn] Error: Filament error on extruder 0: noFilament 2023-12-20 17:28:29 [info] M291: - Printing paused - Filament error on extruder 0: noFilament 2023-12-20 17:28:29 [debug] - Printing paused - 2023-12-20 17:28:29 [debug] Filament error on extruder 0: noFilament 2023-12-20 17:28:29 [warn] Resume state saved 2023-12-20 17:34:00 [warn] Printing resumed 2023-12-20 17:34:00 [debug] Printing resumed 2023-12-20 21:46:55 [warn] Error: Failed to switch off remote heater 1: 2023-12-20 21:46:55 [debug] Done printing file 2023-12-20 21:46:55 [debug] Done printing file 2023-12-20 21:46:55 [warn] Cancelled printing file 0:/gcodes/basket-lid_0.2mm_ABS_0.4n_3h24m.gcode, print time was 4h 32m 2023-12-20 21:46:55 [info] Event logging stopped
Is this a known issue in 3.5.0b4, or have i got something weird in my code i can't see?
Printer / system info: Duet 3 Mini WiFi, 1LC, RRF 3.5.0-b4, DWC 3.5.0-rc2, WiFiServer 2.1b6, fw-retraction, IS, PA & standalone mode
@Exerqtor this sounds like the issue with prints not quite completing. It has been fixed in 3.5.0-rc.2.
@dc42 Aha ok, too bad i can't run 3.5.0-rc2 because of the reversing extruder issue
