Firmware 1.20 Release Candidate 1 available
Hi David,
Here are some things I have noticed, and they could be features or bugs, you tell me
- if you issue a M913 X10 Y10 to reduce XY currents to 10 percent, the new current setting sets in only after a move on one of the axis
- if you speciffy in bed.g coordinates outside the table, it will execute ignoring the table dimensions set with M208
Cheers,
Sascha -
David,
I have just tried to upgrade to 1.20RC1 on Duet 0.85, from 1.19 Stable.
It seems I have a difficulty to connect to my Duet over the Ethernet. I have my Duet set up to get the IP address over the DHCP. It seems it cannot do it anymore for some reason. I must admit, that I have a complicated network, but it was and is working until 1.20 just fine.
I have used the DWC to upgrade the FW, and after the flashing, I could not connect to the board anymore.
I was thinking that flashing over DWC went wrong for some reason, so I have flashed the board with Bossa.
It seems that the Duet reacts just fine with RJ45 disconnected, I can use PanelDue to home, and to jog the axes.
However, as soon as I plug in the Network cable, printer starts to act strange. The PanelDue commands are ignored, or executed with a great delay. It seems like the CPU is struggling to get the IP or something.
I also notice the SmartEffector LEDs are blinking very shortly once in a while. Like after a reset during boot up.I have downgraded to 1.19, and network and the Duet is working fine.
But I get random Duet resets out of nowhere with 1.19… so I wish to get upgraded as soon as possible. -
David,
It seems I have a difficulty to connect to my Duet over the Ethernet. I have my Duet set up to get the IP address over the DHCP. It seems it cannot do it anymore for some reason. I must admit, that I have a complicated network, but it was and is working until 1.20 just fine.Thanks for your report. One of my printers uses a Duet 085 and gets its IP address via DHCP, so I know this works at least in some configurations.
Please can you load RRF 1.20RC1 again, confirm, the problem is still there, then send M122 for USB and post the report here. Also post a M122 report from RRF 1.19.
One possibility is that the configuration you are using is leaving your Duet short of memory, which would explain the problems you are having with both RRF versions. The M122 report may shed some light on that theory.
I confirm that it is not possible to tune heaters in firmware 1,20RC1. This will be fixed in 1.20RC2. Meanwhile, use the same heater parameters that you were using with firmware 1.19 or a 1.20beta.
David, I have tried to flash it again using the DWC. The same behavior. It seems I also cannot sonnect over the USB, the Duet is recognized in Windows, but the drivers can not be installed for some reason, so I cannot connect via Comport. I am not sure why it is not working. The erased board is recognized just fine. I can flash it with Bossa.
Any thoughts?
Update:
I have been playing around to gather more information, please let me know if I should open a separate topic.
It seems that I cannot flash a newest FW over the DWC (1.19.3) anymore. The procedure works fine with FW_1.18.1, but with 1.19 and 1.20RC1 the printer doesn't seem to be able to reboot automatically, and gets stuck with the 'Update successfull! rebooting…' message on the PanelDue.
With the 1.19 FW I can power-cycle the printer and it will operate 'fine'. But reboots once in a while, even with sitting still and doing nothing.
With 1.20RC1 even if I power-cycle it, it doesn't seem to be able to find the network (see my original post).I will use 1.19 to get the M122 listing for you...
Update
I have the M122 listings, but I cannot find a way to attach it to this message from my mobile device... -
M307 now accepts an F parameter to allow the PWM frequency to be set. Caution: do not use excessively high PWM frequencies, especially with the bed heater, because you may overheat the mosfets.
This feature I am especially excited to try out, I've had to use bang-bang for my heated bed because with PID a couple nearby lights in my house would visibly flicker.
I implemented it just for you, in response to your post in another thread.
I just installed RC1. I can confirm M307 Fx works fine at 1, 1.5 and 2Hz and the light flicker is a lot less annoying. Thank you!
Only integer frequencies are supported, so 1.5Hz will get rounded, to 1Hz AFAIR.
I've just noticed something that may be a firmware issue but may be a DWC thing. I'm currently printing an object using all 5 extruders with a mixing ratio of 0.20:0.20:0.20:0.20:0.20 and notice that on the Print Status page of DWC, in the Machine Status panel top right, under Head Position I have Extruder Drives but it's only showing filament used for Drive 3 to 5 - Drives 1 and 2 are showing 0.0. (and yes, all 5 extruders are indeed moving and all at the same speed).I've no idea if this issue applies to other mixing ratios - it's not something I take much notice of. For the same reason, this issue could have been present for some time and not specifically related to 1.20RC1 release. I'm in the middle of a long print but if I get chance, I'll run some tests with other extruder drive combinations to see what happens.
Copy and paste of software information is this:Firmware Name: RepRapFirmware for Duet Ethernet
Firmware Electronics: Duet Ethernet 1.0 + DueX5
Firmware Version: 1.20RC1 (2017-12-08)
Web Interface Version: 1.19.3Oh, and following on from another thread, this is another instance of where Drives 0 to 4 are labelled as 1 to 5 (my pet hate rears it's ugly head again)
Edit. Ignore that. I may have found the reason. I initially sliced this with a 3 extruder printer configuration and afterwards realising my mistake, I manually edited the gcode file. It's likely that there is something in the comments that Slic3r adds that DWC reads and which I haven't edited.
OK that seems about right. Thanks again.
