1LC - extruder randomly stopping/reversing - ≤3.5.0-rc1
@Exerqtor said in 1LC stepper intermittently running backwards - 3.5.0-r1+:
Ok let's see, I've installed those last binaries and the "normal" 3.5.0rc1+ release on the 1LC.After that I tried one of the jobs that failed earlier, and it completed without reversing the extruder (or crashing).I'll try some of the other jobs that has failed too now and see of they also complete.
Should i still leave the "stuff" we put in daemon.g be there for a while btw?(Copying this response to the other thread too, since it's refering to the same binaries)Well that didn't last long, the next print started reversing after the second layer completed, it's still going as i type this reply.
So here is a few reports from when it's currently reversing:
M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1++wdb (2023-12-11 09:30:48) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: XNHXF-HR6KL-K65J0-409N2-K9W1Z-RV2MZ Used output buffers: 12 of 40 (40 max) === RTOS === Static ram: 102844 Dynamic ram: 126732 of which 0 recycled Never used RAM 7128, free system stack 128 words Tasks: NETWORK(1,ready,143.3%,173) HEAT(3,nWait,0.2%,327) Move(4,nWait,6.2%,242) CanReceiv(6,nWait,0.4%,774) CanSender(5,nWait,0.2%,327) CanClock(7,delaying,0.1%,350) TMC(4,nWait,5.7%,74) MAIN(1,running,583.5%,584) IDLE(0,ready,0.9%,29) AIN(4,delaying,6.4%,264), total 746.8% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 01:50:12 ago, cause: software Last software reset at 2023-12-11 16:03, reason: User, Gcodes spinning, available RAM 13548, slot 1 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00446000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x04 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 6612142, completed 6612142, timed out 0, errs 0 MCU temperature: min 34.7, current 46.4, max 46.8 Supply voltage: min 7.5, current 24.1, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 198/23, heap memory allocated/used/recyclable 2048/788/444, gc cycles 18 Events: 0 queued, 0 completed Driver 0: ok, SG min 0, read errors 0, write errors 1, ifcnt 166, reads 20196, writes 50, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 164, reads 20196, writes 50, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 70, reads 20217, writes 28, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 72, reads 20217, writes 28, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 68, reads 20219, writes 27, timeouts 0, DMA errors 0, CC errors 0 Driver 5: not present Driver 6: not present Date/time: 2023-12-11 17:54:00 Cache data hit count 4294967295 Slowest loop: 306.84ms; fastest: 0.09ms === Storage === Free file entries: 16 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 9.2ms, write time 6.2ms, max retries 0 === Move === DMs created 83, segments created 44, maxWait 2843003ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, ebfmin 0.00, ebfmax 0.00 next step interrupt due in 63 ticks, enabled Moves shaped first try 2684, on retry 3142, too short 7967, wrong shape 32970, maybepossible 1754 === DDARing 0 === Scheduled moves 7910, completed 7871, hiccups 0, stepErrors 0, LaErrors 31, Underruns [0, 0, 0], CDDA state 3 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 0 is on, I-accum = 0.4 Heater 1 is on, I-accum = 0.0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is doing "G1 X170.601 Y152.656 E.00239" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is doing "G4 S10000" in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0, sync state 1 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000807 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === Filament sensors === in 0 notIn 0 Extruder 0 sensor: no filament === CAN === Messages queued 111977, received 136294, lost 0, errs 1, boc 0 Longest wait 6ms for reply type 6029, peak Tx sync delay 340, free buffers 26 (min 24), ts 33061/33060/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 210.23ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 3 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.1beta4 MAC address c4:5b:be:ce:91:93 Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42948 WiFi IP address 192.168.10.x Signal strength -49dBm, channel 6, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0
M122 B121 Diagnostics for board 121: Duet TOOL1LC rev 1.1 or later firmware version 3.5.0-rc.1+ (2023-11-21 09:48:16) Bootloader ID: SAMC21 bootloader version 2.4 (2021-12-10) All averaging filters OK Never used RAM 2556, free system stack 89 words Tasks: Move(3,nWait,1.4%,71) HEAT(2,nWait,2.5%,91) CanAsync(5,nWait,0.0%,54) CanRecv(3,nWait,0.4%,77) CanClock(5,nWait,0.1%,67) ACCEL(3,nWait,0.0%,53) TMC(2,nWait,22.2%,57) MAIN(1,running,38.2%,316) IDLE(0,ready,0.0%,27) AIN(2,delaying,35.0%,114), total 100.0% Last reset 01:50:46 ago, cause: software Last software reset data not available Driver 0: pos 0, 568.8 steps/mm, standstill, SG min 0, read errors 0, write errors 3, ifcnt 140, reads 40832, writes 24, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 4320865 Moves scheduled 47946, completed 47946, in progress 0, hiccups 77, segs 43, step errors 0, maxPrep 887, maxOverdue 7251, maxInc 2966, mcErrs 0, gcmErrs 0, ebfmin -1.00 max inf Peak sync jitter -2/11, peak Rx sync delay 279, resyncs 0/0, no timer interrupt scheduled VIN voltage: min 7.7, current 24.1, max 24.5 MCU temperature: min 38.8C, current 66.5C, max 74.8C Last sensors broadcast 0x00000012 found 2 34 ticks ago, 0 ordering errs, loop time 0 CAN messages queued 137004, send timeouts 0, received 112920, lost 0, errs 1213, boc 0, free buffers 18, min 18, error reg 110000 dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 369, adv 35625/74652 Accelerometer: LIS3DH, status: 00 Inductive sensor: not found I2C bus errors 0, naks 6, contentions 0, other errors 0 === Filament sensors === Interrupt 5726621 to 0us, poll 2 to 1966us Driver 0: ok
@Exerqtor please use the 3.5.0-rc.1++ tool board/expansion board firmware from https://www.dropbox.com/scl/fo/gaxzegafmnmagaefo9mgc/h?rlkey=hk4wpttdje76oews8zkuh86q3&dl=0.
@dc42 said in 1LC stepper intermittently running backwards - 3.5.0-r1+:
Aha, ok just moved over to it. I'll try the same job file again before hitting the bunk and report back
Just tried the same print with 3.5.0-c.1++ on the 1LC and it's the exact same behaviour:
M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1++wdb (2023-12-11 09:30:48) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: XNHXF-HR6KL-K65J0-409N2-K9W1Z-RV2MZ Used output buffers: 4 of 40 (40 max) === RTOS === Static ram: 102844 Dynamic ram: 125540 of which 0 recycled Never used RAM 9168, free system stack 138 words Tasks: NETWORK(1,ready,16.8%,179) HEAT(3,nWait,0.0%,352) Move(4,nWait,0.5%,244) CanReceiv(6,nWait,0.1%,774) CanSender(5,nWait,0.0%,327) CanClock(7,delaying,0.0%,350) TMC(4,delaying,0.7%,74) MAIN(1,running,80.9%,584) IDLE(0,ready,0.2%,29) AIN(4,delaying,0.8%,264), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:25:33 ago, cause: software Last software reset at 2023-12-11 19:17, reason: User, Gcodes spinning, available RAM 7056, slot 2 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00446000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x04 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 1533781, completed 1533780, timed out 0, errs 0 MCU temperature: min 37.0, current 46.4, max 46.6 Supply voltage: min 7.8, current 24.0, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/23, heap memory allocated/used/recyclable 2048/1912/1572, gc cycles 7 Events: 0 queued, 0 completed Driver 0: ok, SG min 0, read errors 0, write errors 1, ifcnt 201, reads 15125, writes 32, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 199, reads 15124, writes 32, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 93, reads 15136, writes 20, timeouts 0, DMA errors 0, CC errors 0 Driver 3: ok, SG min 0, read errors 0, write errors 1, ifcnt 96, reads 15135, writes 21, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 91, reads 15137, writes 20, timeouts 0, DMA errors 0, CC errors 0 Driver 5: not present Driver 6: not present Date/time: 2023-12-11 19:43:28 Cache data hit count 2492399296 Slowest loop: 226.89ms; fastest: 0.09ms === Storage === Free file entries: 16 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 5.4ms, write time 5.1ms, max retries 0 === Move === DMs created 83, segments created 42, maxWait 1083591ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, ebfmin 0.00, ebfmax 0.00 next step interrupt due in 30 ticks, enabled Moves shaped first try 265, on retry 158, too short 102, wrong shape 2987, maybepossible 63 === DDARing 0 === Scheduled moves 4562, completed 4522, hiccups 0, stepErrors 0, LaErrors 5, Underruns [0, 0, 0], CDDA state 3 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 0 is on, I-accum = 0.4 Heater 1 is on, I-accum = 0.0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is doing "G1 X187.692 Y162.442 Z1.35" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is doing "G4 S10000" in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0, sync state 1 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000807 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === Filament sensors === in 0 notIn 0 Extruder 0 sensor: no filament === CAN === Messages queued 17932, received 31633, lost 0, errs 0, boc 0 Longest wait 3ms for reply type 6013, peak Tx sync delay 327, free buffers 26 (min 25), ts 7669/7668/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 208.78ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 2 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.1beta4 MAC address c4:5b:be:ce:91:93 Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 43112 WiFi IP address 192.168.10.x Signal strength -48dBm, channel 6, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0
M122 B121 Diagnostics for board 121: Duet TOOL1LC rev 1.1 or later firmware version 3.5.0-rc.1++ (2023-12-07 12:52:31) Bootloader ID: SAMC21 bootloader version 2.4 (2021-12-10) All averaging filters OK Never used RAM 2628, free system stack 89 words Tasks: Move(3,nWait,0.1%,71) HEAT(2,nWait,0.3%,91) CanAsync(5,nWait,0.0%,55) CanRecv(3,nWait,0.0%,77) CanClock(5,nWait,0.0%,67) ACCEL(3,nWait,0.0%,53) TMC(2,nWait,3.0%,57) MAIN(1,running,91.7%,316) IDLE(0,ready,0.0%,27) AIN(2,delaying,4.8%,114), total 100.0% Last reset 00:26:29 ago, cause: software Last software reset data not available Driver 0: pos 0, 568.8 steps/mm, standstill, SG min 0, read errors 0, write errors 1, ifcnt 174, reads 7708, writes 22, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x6c, steps req 0 done 401933 Moves scheduled 2847, completed 2847, in progress 0, hiccups 1, segs 40, step errors 0, maxLate 1 maxPrep 900, maxOverdue 40, maxInc 40, mcErrs 0, gcmErrs 0, ebfmin -1.00 max inf Peak sync jitter -2/9, peak Rx sync delay 219, resyncs 0/0, no timer interrupt scheduled VIN voltage: min 8.1, current 24.1, max 24.7 MCU temperature: min 45.6C, current 61.2C, max 61.2C Last sensors broadcast 0x00000012 found 2 228 ticks ago, 0 ordering errs, loop time 0 CAN messages queued 32789, send timeouts 0, received 19593, lost 0, errs 1210, boc 0, free buffers 18, min 18, error reg 100000 dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 354, adv 35712/74647 Accelerometer: LIS3DH, status: 00 Inductive sensor: not found I2C bus errors 0, naks 6, contentions 0, other errors 0 === Filament sensors === Interrupt 5726621 to 0us, poll 2 to 1314us Driver 0: ok
@Exerqtor is the reversal random, or at the same point each time in a given print?
@dc42 Seemingly random, definetly not on the same point/layer each time.
The first time it happened (where i thought it was a clog or something) it happened between layer 59-61 (based on messsuring the height of the failed print), so after making sure there was no clog etc. and restarting the print it began reversing at layer 4-5. And on the third try it started reversing on layer 2.
I just saw this thread and your reply to it. And it got me to remember that i did some IS tuning and changes between it working and these issues came back. May these be connected to each other?
The only changes i did was to alter the frequency and try a couple different shapers to see what changes it did to the readings.
@dc42 So I just grabbed the 3.5.0rc2 binaries and tried them on the machine, and it's still reversing the the print.
This time I kept a finger on the filament where it enters the reversed bowden while looking at the Z-height and it stopped extruding somewhere along Z 0.65.
Here is a couple fresh reports grabbed while it's acting up during a print:
M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.2 (2023-12-15 13:33:26) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: XNHXF-HR6KL-K65J0-409N2-K9W1Z-RV2MZ Used output buffers: 3 of 40 (40 max) === RTOS === Static ram: 102812 Dynamic ram: 128208 of which 0 recycled Never used RAM 5756, free system stack 120 words Tasks: NETWORK(2,nWait,21.9%,181) HEAT(3,nWait,0.0%,328) Move(4,nWait,0.5%,243) CanReceiv(6,nWait,0.1%,776) CanSender(5,nWait,0.0%,329) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.7%,80) MAIN(1,running,71.5%,603) IDLE(0,ready,4.5%,29) AIN(4,delaying,0.8%,264), total 100.0% Owned mutexes: === Platform === Last reset 00:36:34 ago, cause: software Last software reset at 2023-12-15 17:21, reason: User, Gcodes spinning, available RAM 12348, slot 2 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x04 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 2195019, completed 2195017, timed out 0, errs 0 MCU temperature: min 35.9, current 46.2, max 46.7 Supply voltage: min 7.5, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 198/28, heap memory allocated/used/recyclable 2048/1524/1120, gc cycles 4001 Events: 0 queued, 0 completed Driver 0: ok, SG min 0, read errors 0, write errors 1, ifcnt 149, reads 49926, writes 32, timeouts 0, DMA errors 0, CC errors 0 Driver 1: ok, SG min 0, read errors 0, write errors 1, ifcnt 149, reads 49926, writes 32, timeouts 0, DMA errors 0, CC errors 0 Driver 2: ok, SG min 0, read errors 0, write errors 1, ifcnt 115, reads 49937, writes 21, timeouts 0, DMA errors 0, CC errors 0 Driver 3: ok, SG min 0, read errors 0, write errors 1, ifcnt 116, reads 49936, writes 21, timeouts 0, DMA errors 0, CC errors 0 Driver 4: ok, SG min 0, read errors 0, write errors 1, ifcnt 115, reads 49937, writes 21, timeouts 0, DMA errors 0, CC errors 0 Driver 5: not present Driver 6: not present Date/time: 2023-12-15 17:57:46 Cache data hit count 3773989065 Slowest loop: 224.53ms; fastest: 0.09ms === Storage === Free file entries: 16 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 11.1ms, write time 4.5ms, max retries 0 === Move === DMs created 83, segments created 41, maxWait 1602827ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, ebfmin 0.00, ebfmax 0.00 next step interrupt due in 795 ticks, enabled Moves shaped first try 499, on retry 404, too short 194, wrong shape 4852, maybepossible 141 === DDARing 0 === Scheduled moves 8101, completed 8061, hiccups 0, stepErrors 0, LaErrors 10, Underruns [0, 0, 0], CDDA state 3 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 0 is on, I-accum = 0.4 Heater 1 is on, I-accum = 0.0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is doing "G1 X170.827 Y153.319 E.00731" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0, sync state 1 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000807 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === Filament sensors === check 0 clear 0 Extruder 0 sensor: no filament === CAN === Messages queued 26867, received 45197, lost 0, errs 1, boc 0 Longest wait 2ms for reply type 6031, peak Tx sync delay 403, free buffers 26 (min 25), ts 10975/10974/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 89.37ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 3 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.1beta6 MAC address c4:5b:be:ce:91:93 Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 41512 WiFi IP address 192.168.10.x Signal strength -50dBm, channel 6, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0
M122 B121 Diagnostics for board 121: Duet TOOL1LC rev 1.1 or later firmware version 3.5.0-rc.2 (2023-12-15 13:41:02) Bootloader ID: SAMC21 bootloader version 2.4 (2021-12-10) All averaging filters OK Never used RAM 2708, free system stack 91 words Tasks: Move(3,nWait,0.1%,73) HEAT(2,nWait,0.4%,97) CanAsync(5,nWait,0.0%,55) CanRecv(3,nWait,0.0%,77) CanClock(5,nWait,0.0%,69) ACCEL(3,nWait,0.0%,53) TMC(2,delaying,3.0%,57) MAIN(1,running,91.8%,318) IDLE(0,ready,0.0%,27) AIN(2,delaying,4.7%,114), total 100.0% Last reset 00:36:54 ago, cause: software Last software reset data not available Driver 0: pos 0, 568.8 steps/mm, standstill, SG min 0, read errors 0, write errors 1, ifcnt 97, reads 57835, writes 22, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 440142 Moves scheduled 3003, completed 3003, in progress 0, hiccups 4, segs 40, step errors 0, maxLate 1 maxPrep 887, maxOverdue 322, maxInc 322, mcErrs 0, gcmErrs 0, ebfmin -1.00 max inf Peak sync jitter -2/10, peak Rx sync delay 217, resyncs 0/0, no timer interrupt scheduled VIN voltage: min 7.7, current 24.1, max 24.5 MCU temperature: min 39.1C, current 68.7C, max 68.7C Last sensors broadcast 0x00000012 found 2 11 ticks ago, 0 ordering errs, loop time 0 CAN messages queued 45614, send timeouts 0, received 27424, lost 0, errs 1173, boc 0, free buffers 18, min 18, error reg 110000 dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 346, adv 35766/74655 Accelerometer: LIS3DH, status: 00 Inductive sensor: not found I2C bus errors 0, naks 6, contentions 0, other errors 0 === Filament sensors === Interrupt 5726621 to 0us, poll 4 to 1409us
And the sliced file for good measure.
I just adjusted my belt tention and retuned input shaping after moving to 3.5.0-rc2, to see if applying new shaper settings would remedy anything.
Started a print, and now it stops extruding earlier than ever, now it only does a tiny bit of my purge line before it stops.
So i thought fuck it and removed the extrusion reset commands from my layer change g-code, sliced the model again and did another try. The exact same behaviour.
Here is another set of M122 reports from while the problem is happening:
M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.2 (2023-12-15 13:33:26) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: XNHXF-HR6KL-K65J0-409N2-K9W1Z-RV2MZ Used output buffers: 13 of 40 (40 max) === RTOS === Static ram: 102812 Dynamic ram: 128544 of which 0 recycled Never used RAM 5420, free system stack 120 words Tasks: NETWORK(1,ready,83.7%,181) HEAT(3,nWait,1.0%,328) Move(4,nWait,0.3%,243) CanReceiv(6,nWait,1.7%,776) CanSender(5,nWait,0.0%,328) CanClock(7,delaying,0.3%,350) TMC(4,delaying,24.0%,74) MAIN(1,running,106.6%,584) IDLE(0,ready,179.1%,29) AIN(4,delaying,27.9%,264), total 424.7% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 17:00:25 ago, cause: software Last software reset at 2023-12-15 17:21, reason: User, Gcodes spinning, available RAM 12348, slot 2 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x04 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 61224767, completed 61224767, timed out 0, errs 0 MCU temperature: min 34.8, current 46.4, max 46.4 Supply voltage: min 23.4, current 23.9, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 198/28, heap memory allocated/used/recyclable 2048/612/192, gc cycles 119204 Events: 0 queued, 0 completed Driver 0: ok, SG min 0, read errors 0, write errors 0, ifcnt 247, reads 26512, writes 98, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x71 Driver 1: ok, SG min 0, read errors 0, write errors 0, ifcnt 247, reads 26513, writes 98, timeouts 0, DMA errors 0, CC errors 0 Driver 2: ok, SG min 0, read errors 0, write errors 0, ifcnt 152, reads 26571, writes 37, timeouts 2, DMA errors 0, CC errors 0, failedOp 0x41 Driver 3: ok, SG min 0, read errors 0, write errors 0, ifcnt 154, reads 26572, writes 38, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x6c Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 152, reads 26572, writes 37, timeouts 2, DMA errors 0, CC errors 0, failedOp 0x6f Driver 5: not present Driver 6: not present Date/time: 2023-12-16 10:21:36 Cache data hit count 4294967295 Slowest loop: 408.12ms; fastest: 0.09ms === Storage === Free file entries: 16 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 8.7ms, write time 8.1ms, max retries 0 === Move === DMs created 83, segments created 41, maxWait 53449812ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, ebfmin 0.00, ebfmax 0.00 next step interrupt due in 55 ticks, enabled Moves shaped first try 196, on retry 110, too short 86, wrong shape 1517, maybepossible 32 === DDARing 0 === Scheduled moves 432, completed 422, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 49], CDDA state 3 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 0 is on, I-accum = 0.4 Heater 1 is on, I-accum = 0.0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 3 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 1, axes/extruders owned 0x0000807 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === Filament sensors === check 0 clear 0 Extruder 0 sensor: no filament === CAN === Messages queued 533567, received 1211128, lost 0, errs 0, boc 0 Longest wait 6ms for reply type 6024, peak Tx sync delay 277, free buffers 26 (min 24), ts 295151/295151/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 211.17ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.1beta6 MAC address c4:5b:be:ce:91:93 Module reset reason: Power up, Vcc 3.37, flash size 2097152, free heap 41168 WiFi IP address 192.168.10.x Signal strength -49dBm, channel 6, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0
M122 B121 Diagnostics for board 121: Duet TOOL1LC rev 1.1 or later firmware version 3.5.0-rc.2 (2023-12-15 13:41:02) Bootloader ID: SAMC21 bootloader version 2.4 (2021-12-10) All averaging filters OK Never used RAM 2708, free system stack 91 words Tasks: Move(3,nWait,0.1%,73) HEAT(2,nWait,11.4%,97) CanAsync(5,nWait,0.0%,54) CanRecv(3,nWait,0.4%,77) CanClock(5,nWait,0.6%,69) ACCEL(3,nWait,0.0%,17) TMC(2,delaying,101.1%,57) MAIN(1,running,154.7%,318) IDLE(0,ready,0.0%,27) AIN(2,delaying,159.0%,114), total 427.3% Last reset 17:00:30 ago, cause: software Last software reset data not available Driver 0: pos 0, 568.8 steps/mm, standstill, SG min 0, read errors 0, write errors 0, ifcnt 101, reads 16617, writes 4, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x71, steps req 0 done 91906 Moves scheduled 3087, completed 3087, in progress 0, hiccups 3, segs 40, step errors 0, maxLate 0 maxPrep 853, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0, ebfmin 0.00 max inf Peak sync jitter -3/10, peak Rx sync delay 219, resyncs 0/0, no timer interrupt scheduled VIN voltage: min 23.3, current 24.1, max 24.6 MCU temperature: min 38.6C, current 63.8C, max 69.2C Last sensors broadcast 0x00000012 found 2 24 ticks ago, 0 ordering errs, loop time 0 CAN messages queued 1210805, send timeouts 0, received 533070, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0 dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 334, adv 35725/74654 Accelerometer: LIS3DH, status: 00 Inductive sensor: not found I2C bus errors 0, naks 0, contentions 0, other errors 0 === Filament sensors === Interrupt 5726621 to 0us, poll 5 to 1436us Driver 0: ok
And here is the relevant config files & sliced job.
(All these files are grabbed from the printer, so it's 100% the config I'm currently running)
@Exerqtor have we already ascertained if the problem goes away when input shaping and/or pressure advance are disabled? What size nozzle are you using?
@droftarts said in 1LC - stepper randomly reversing - ≤3.5.0-r1+:
No I haven't tried that out yet, been waiting on feedback as to where/what to start with to be honest.
I can try disabling Input Shaping first and see if that yield different results on the same job that I supplied in my last post.
I can confirm that it still happens with IS disabled:
M593 Input shaping is disabled
M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.2 (2023-12-15 13:33:26) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: XNHXF-HR6KL-K65J0-409N2-K9W1Z-RV2MZ Used output buffers: 25 of 40 (40 max) === RTOS === Static ram: 102812 Dynamic ram: 128544 of which 0 recycled Never used RAM 5420, free system stack 120 words Tasks: NETWORK(2,nWait,23.7%,179) HEAT(3,nWait,0.0%,328) Move(4,nWait,2.4%,243) CanReceiv(6,nWait,0.1%,776) CanSender(5,nWait,0.0%,328) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.8%,74) MAIN(1,running,66.8%,584) IDLE(0,ready,5.3%,29) AIN(4,delaying,0.9%,264), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 18:04:31 ago, cause: software Last software reset at 2023-12-15 17:21, reason: User, Gcodes spinning, available RAM 12348, slot 2 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x04 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 65070749, completed 65070749, timed out 0, errs 0 MCU temperature: min 46.0, current 46.4, max 46.7 Supply voltage: min 23.8, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 198/28, heap memory allocated/used/recyclable 2048/1836/1416, gc cycles 126614 Events: 0 queued, 0 completed Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 10, reads 1329, writes 0, timeouts 0, DMA errors 0, CC errors 0 Driver 1: ok, SG min 0, read errors 0, write errors 0, ifcnt 10, reads 1329, writes 0, timeouts 0, DMA errors 0, CC errors 0 Driver 2: ok, SG min 0, read errors 0, write errors 0, ifcnt 160, reads 1329, writes 0, timeouts 0, DMA errors 0, CC errors 0 Driver 3: ok, SG min 0, read errors 0, write errors 0, ifcnt 162, reads 1329, writes 0, timeouts 0, DMA errors 0, CC errors 0 Driver 4: ok, SG min 0, read errors 0, write errors 0, ifcnt 159, reads 1329, writes 0, timeouts 0, DMA errors 0, CC errors 0 Driver 5: not present Driver 6: not present Date/time: 2023-12-16 11:25:42 Cache data hit count 4294967295 Slowest loop: 9.56ms; fastest: 0.11ms === Storage === Free file entries: 16 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 6.0ms, write time 1.0ms, max retries 0 === Move === DMs created 83, segments created 41, maxWait 842ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, ebfmin 0.00, ebfmax 0.00 next step interrupt due in 107 ticks, enabled Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0 === DDARing 0 === Scheduled moves 1066, completed 1044, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 0 is on, I-accum = 0.4 Heater 1 is on, I-accum = 0.0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is doing "G1 X226.271 Y197.626 E.02799" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is doing "G4 P10" in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 1, axes/extruders owned 0x0000807 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === Filament sensors === check 0 clear 0 Extruder 0 sensor: no filament === CAN === Messages queued 509, received 517, lost 0, errs 0, boc 0 Longest wait 0ms for reply type 0, peak Tx sync delay 9, free buffers 26 (min 25), ts 126/126/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 20.63ms; fastest: 0.06ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.1beta6 MAC address c4:5b:be:ce:91:93 Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42988 WiFi IP address 192.168.10.x Signal strength -50dBm, channel 6, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0
M122 B121 Diagnostics for board 121: Duet TOOL1LC rev 1.1 or later firmware version 3.5.0-rc.2 (2023-12-15 13:41:02) Bootloader ID: SAMC21 bootloader version 2.4 (2021-12-10) All averaging filters OK Never used RAM 2708, free system stack 91 words Tasks: Move(3,nWait,0.0%,73) HEAT(2,nWait,0.3%,97) CanAsync(5,nWait,0.0%,54) CanRecv(3,nWait,0.0%,77) CanClock(5,nWait,0.0%,69) ACCEL(3,nWait,0.0%,17) TMC(2,delaying,3.0%,57) MAIN(1,running,91.9%,318) IDLE(0,ready,0.0%,27) AIN(2,delaying,4.7%,114), total 100.0% Last reset 18:04:47 ago, cause: software Last software reset data not available Driver 0: pos 0, 568.8 steps/mm, standstill, SG min 0, read errors 0, write errors 0, ifcnt 103, reads 28066, writes 2, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 38048 Moves scheduled 3098, completed 3098, in progress 0, hiccups 1, segs 40, step errors 0, maxLate 0 maxPrep 334, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0, ebfmin 0.00 max inf Peak sync jitter -2/11, peak Rx sync delay 215, resyncs 0/0, no timer interrupt scheduled VIN voltage: min 23.3, current 24.1, max 24.5 MCU temperature: min 38.6C, current 57.8C, max 69.2C Last sensors broadcast 0x00000012 found 2 103 ticks ago, 0 ordering errs, loop time 0 CAN messages queued 79268, send timeouts 0, received 35985, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0 dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 323, adv 35708/74652 Accelerometer: LIS3DH, status: 00 Inductive sensor: not found I2C bus errors 0, naks 0, contentions 0, other errors 0 === Filament sensors === Interrupt 5726621 to 0us, poll 5 to 1432us Driver 0: ok
@droftarts And the exact same with both Input Shaping and Pressure Advance disabled:
M593 Input shaping is disabled M572 D0 Extruder pressure advance: 0.000
M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.2 (2023-12-15 13:33:26) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: XNHXF-HR6KL-K65J0-409N2-K9W1Z-RV2MZ Used output buffers: 3 of 40 (40 max) === RTOS === Static ram: 102812 Dynamic ram: 128544 of which 0 recycled Never used RAM 5420, free system stack 120 words Tasks: NETWORK(2,nWait,22.2%,179) HEAT(3,nWait,0.0%,328) Move(4,nWait,0.5%,243) CanReceiv(6,nWait,0.1%,776) CanSender(5,nWait,0.0%,328) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.7%,74) MAIN(1,running,70.6%,584) IDLE(0,ready,5.0%,29) AIN(4,delaying,0.9%,264), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 18:14:11 ago, cause: software Last software reset at 2023-12-15 17:21, reason: User, Gcodes spinning, available RAM 12348, slot 2 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x04 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 65650769, completed 65650768, timed out 0, errs 0 MCU temperature: min 42.2, current 46.2, max 46.8 Supply voltage: min 23.4, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 198/28, heap memory allocated/used/recyclable 2048/716/296, gc cycles 127712 Events: 0 queued, 0 completed Driver 0: ok, SG min 0, read errors 0, write errors 0, ifcnt 29, reads 30499, writes 19, timeouts 0, DMA errors 0, CC errors 0 Driver 1: ok, SG min 0, read errors 0, write errors 0, ifcnt 29, reads 30499, writes 19, timeouts 0, DMA errors 0, CC errors 0 Driver 2: ok, SG min 0, read errors 0, write errors 0, ifcnt 168, reads 30510, writes 8, timeouts 0, DMA errors 0, CC errors 0 Driver 3: ok, SG min 0, read errors 0, write errors 0, ifcnt 169, reads 30512, writes 7, timeouts 0, DMA errors 0, CC errors 0 Driver 4: ok, SG min 0, read errors 0, write errors 0, ifcnt 167, reads 30510, writes 8, timeouts 0, DMA errors 0, CC errors 0 Driver 5: not present Driver 6: not present Date/time: 2023-12-16 11:35:22 Cache data hit count 4294967295 Slowest loop: 216.18ms; fastest: 0.09ms === Storage === Free file entries: 16 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 6.6ms, write time 5.2ms, max retries 0 === Move === DMs created 83, segments created 41, maxWait 322812ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, ebfmin 0.00, ebfmax 0.00 next step interrupt due in 50 ticks, enabled Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0 === DDARing 0 === Scheduled moves 842, completed 836, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state 3 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 0 is on, I-accum = 0.5 Heater 1 is on, I-accum = 0.0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 3 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is doing "G4 P10" in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 1, axes/extruders owned 0x0000807 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === Filament sensors === check 0 clear 0 Extruder 0 sensor: no filament === CAN === Messages queued 6599, received 12089, lost 0, errs 0, boc 0 Longest wait 6ms for reply type 6013, peak Tx sync delay 262, free buffers 26 (min 25), ts 2900/2900/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 209.17ms; fastest: 0.06ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.1beta6 MAC address c4:5b:be:ce:91:93 Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 39732 WiFi IP address 192.168.10.x Signal strength -48dBm, channel 6, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0
M122 B121 Diagnostics for board 121: Duet TOOL1LC rev 1.1 or later firmware version 3.5.0-rc.2 (2023-12-15 13:41:02) Bootloader ID: SAMC21 bootloader version 2.4 (2021-12-10) All averaging filters OK Never used RAM 2708, free system stack 91 words Tasks: Move(3,nWait,0.0%,73) HEAT(2,nWait,0.4%,97) CanAsync(5,nWait,0.0%,54) CanRecv(3,nWait,0.0%,77) CanClock(5,nWait,0.0%,69) ACCEL(3,nWait,0.0%,17) TMC(2,delaying,3.0%,57) MAIN(1,running,91.8%,318) IDLE(0,ready,0.0%,27) AIN(2,delaying,4.7%,114), total 100.0% Last reset 18:14:15 ago, cause: software Last software reset data not available Driver 0: pos 0, 568.8 steps/mm, standstill, SG min 0, read errors 0, write errors 0, ifcnt 105, reads 21809, writes 2, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 38048 Moves scheduled 3109, completed 3109, in progress 0, hiccups 2, segs 40, step errors 0, maxLate 0 maxPrep 261, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0, ebfmin 0.00 max inf Peak sync jitter -1/10, peak Rx sync delay 213, resyncs 0/0, no timer interrupt scheduled VIN voltage: min 23.4, current 24.1, max 24.5 MCU temperature: min 38.6C, current 61.1C, max 69.2C Last sensors broadcast 0x00000012 found 2 168 ticks ago, 0 ordering errs, loop time 0 CAN messages queued 11838, send timeouts 0, received 6345, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0 dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 324, adv 35827/74649 Accelerometer: LIS3DH, status: 00 Inductive sensor: not found I2C bus errors 0, naks 0, contentions 0, other errors 0 === Filament sensors === Interrupt 5726621 to 0us, poll 5 to 1488us Driver 0: ok
I just removed all the "extra stuff "that was put in daemon.g to see if that mad a difference but it still starts reversing. Same if i "disable" daemon.g or run it completely empty.Now it's on the first line of my 3-line purge/prime code each time "no matter" what i do.
Is it any apparent issue from the M122 reports i've been posting, or is that just a complete waste of time to post those?
Feel like i'm pulling straws out of my ass at this point, but could formating the sd-card and reinstalling all the firmware be worth a try?
I mean, i've been installing so many different builds the last 3-4months maybe something got messed up?
Or is that just nonsense?
@Exerqtor If it makes you feel better I figured out the problem I have been having for the last week is the extruder occasionally stopping. Using a Duet 3 mini 5+ with a RRF-36 toolboard. 3.5.0-R1 on the board and 3.5.0.r1+101 on the toolboard.
I thought it was cooling related since it is a new Dragonfly BMO hotend and EVA34 setup thanks to a fan failure earlier. But nothing is wrong, the heatbreak is clear, the nozzle is not clogged Went through the wiring too to make sure no momentaries were happening.
Not seeing an error and no desire to try it again and waste more expensive carbon fiber PC filament. Plus I am going to be tied up for the next couple weeks, So I'll park that printer and revisit it early next year.
I did kill daemon.g to see if it was related since that and the new hotend assembly were the changes recently done and it did not help. Not seeing any crashes but I am running a different setup than you. Win 10 with Cura slicing the files and firefox running DWC. And the 2 reprints also failed. They sure mess up a print when they happen.
@KenW
Sucks to hear you also have problems, but it really does make me feel better to hear that it's not another "one off" issue, and it's something happening to others as well😮💨
I've got alot of projects I hoped to get done by/in the comming holidays, but it's looking increasingly less and less likely
It's luckily some bog standard ABS i've had to throw in the fuckit-bucket, but it's still annoying af.
@Exerqtor That is the only printer running the beta firmware. It has to run it to use the RRF-36 toolboard. I had noticed your post but was ignoring them since I thought it was filament getting stuck in the heatbreak or possibly carbon fiber jamming the nozzle. I can take down and reassemble the EVA in minutes now with all the practice I have been getting.
Since mine is not acting up exactly like yours unless your extruder just stops for a bit then restarts with no error maybe it's another issue.
After I get back home in a few weeks I'll play around more with it,. Gave up today on the print I was trying to take with me. -
@KenW I also thought i had gotten a clog or something when it started happening again so i get your logic lol. It will be interesting seeing how it plays out when you get some time to look at it again.
I just reverted to 3.5.0b4 on the mobo & toolboard to see what happens at least, too be continued.
EDIT:
After reverting too 3.5.0b4 I was finally able to complete the print without issues.I'm gonna try doing some more prints after work tomorrow to see if the "solution" holds, but it sure looks like the problem lies in 3.5.0-rc1/2.
@dc42 I've ran over ballpark 24hr of prints on 2.5.0b4 now without any issues.
Weird that noone else reports about this.
@Exerqtor Not home to look at anything but it might depend on the setup. I had another printer earlier that I also had a duet 3 mini 5+ with 3.5.0 r.1 and a RRF-36 mounted with 3.5.0 r1 firmware. That was an ender 3 pro, a simple bed slinger. I did multiple test prints on it before it was wrapped up as a gift and hauled up here. In 5 days it gets to live again and hopefully will still be problem free.
The printer giving me problems is a CoreXY with 3 Z steppers and a klicky so a bit more complex and different motion system. Also a Duet 3 mini 5_ with the other RRF-36 and the same firmware as the ender.
@dc42 I tried installing 3.5.0-rc2 again, with a freshly formated SD card etc. to see if that might help (downloaded the binaries again also just in case) and it still shits the bed:
M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.2 (2023-12-14 10:30:57) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: XNHXF-HR6KL-K65J0-409N2-K9W1Z-RV2MZ Used output buffers: 4 of 40 (40 max) === RTOS === Static ram: 102812 Dynamic ram: 128720 of which 0 recycled Never used RAM 5196, free system stack 118 words Tasks: NETWORK(1,ready,119.4%,195) HEAT(3,nWait,0.7%,328) Move(4,nWait,14.5%,239) CanReceiv(6,nWait,1.2%,774) CanSender(5,nWait,0.3%,327) CanClock(7,delaying,0.2%,350) TMC(4,nWait,17.4%,74) MAIN(1,running,53.1%,580) IDLE(0,ready,19.8%,29) AIN(4,delaying,20.2%,264), total 246.8% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 24:56:40 ago, cause: software Last software reset at 2023-12-21 16:42, reason: User, Gcodes spinning, available RAM 12348, slot 0 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00446000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x04 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 89801376, completed 89801376, timed out 0, errs 0 MCU temperature: min 34.4, current 46.8, max 47.3 Supply voltage: min 8.0, current 23.9, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 198/28, heap memory allocated/used/recyclable 2048/532/136, gc cycles 15646 Events: 1 queued, 1 completed Driver 0: ok, SG min 0, read errors 0, write errors 1, ifcnt 33, reads 7119, writes 123, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x72 Driver 1: ok, SG min 0, read errors 0, write errors 1, ifcnt 33, reads 7120, writes 123, timeouts 0, DMA errors 0, CC errors 0 Driver 2: ok, SG min 0, read errors 0, write errors 1, ifcnt 149, reads 7187, writes 56, timeouts 0, DMA errors 0, CC errors 0 Driver 3: ok, SG min 0, read errors 0, write errors 1, ifcnt 145, reads 7185, writes 57, timeouts 0, DMA errors 0, CC errors 0 Driver 4: ok, SG min 0, read errors 0, write errors 1, ifcnt 144, reads 7187, writes 55, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x01 Driver 5: not present Driver 6: not present Date/time: 2023-12-22 17:38:55 Cache data hit count 4294967295 Slowest loop: 226.03ms; fastest: 0.09ms === Storage === Free file entries: 16 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 11.0ms, write time 62.9ms, max retries 0 === Move === DMs created 83, segments created 43, maxWait 59621605ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, ebfmin 0.00, ebfmax 0.00 next step interrupt due in 37 ticks, enabled Moves shaped first try 52954, on retry 20590, too short 71476, wrong shape 255081, maybepossible 11645 === DDARing 0 === Scheduled moves 2684, completed 2644, hiccups 1184, stepErrors 0, LaErrors 1095, Underruns [0, 0, 4], CDDA state 3 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 0 is on, I-accum = 0.3 Heater 1 is on, I-accum = 0.0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is doing "G1 X131.338 Y134.213 E.09057" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is doing "G4 P250" in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0, sync state 1 Queue2 is idle in state(s) 0 Q0 segments left 1, axes/extruders owned 0x0000807 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === Filament sensors === check 0 clear 0 Extruder 0 sensor: no filament === CAN === Messages queued 1264763, received 1844452, lost 0, errs 1, boc 0 Longest wait 6ms for reply type 6013, peak Tx sync delay 276, free buffers 26 (min 24), ts 449002/449001/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 211.13ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.1beta6 MAC address c4:5b:be:ce:91:93 Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 36292 WiFi IP address 192.168.10.x Signal strength -52dBm, channel 6, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0
M122 B121 Diagnostics for board 121: Duet TOOL1LC rev 1.1 or later firmware version 3.5.0-rc.2 (2023-12-14 08:58:51) Bootloader ID: SAMC21 bootloader version 2.4 (2021-12-10) All averaging filters OK Never used RAM 2580, free system stack 89 words Tasks: Move(3,nWait,2.9%,71) HEAT(2,nWait,7.9%,91) CanAsync(5,nWait,0.0%,55) CanRecv(3,nWait,1.0%,77) CanClock(5,nWait,0.4%,67) ACCEL(3,nWait,0.0%,53) TMC(2,nWait,70.2%,57) MAIN(1,running,53.1%,316) IDLE(0,ready,0.0%,27) AIN(2,delaying,111.1%,114), total 246.6% Last reset 24:56:46 ago, cause: software Last software reset data not available Driver 0: pos 0, 568.8 steps/mm, ok, SG min 0, read errors 5, write errors 1, ifcnt 112, reads 29381, writes 30, timeouts 10, DMA errors 0, CC errors 0, failedOp 0x01, steps req 0 done 54758132 Moves scheduled 451072, completed 451072, in progress 0, hiccups 6856, segs 42, step errors 0, maxLate 2 maxPrep 759, maxOverdue 7315, maxInc 2784, mcErrs 0, gcmErrs 0, ebfmin -1.00 max inf Peak sync jitter -2/12, peak Rx sync delay 280, resyncs 0/0, no timer interrupt scheduled VIN voltage: min 8.3, current 24.1, max 24.6 MCU temperature: min 39.4C, current 73.3C, max 79.5C Last sensors broadcast 0x00000012 found 2 138 ticks ago, 0 ordering errs, loop time 0 CAN messages queued 1844535, send timeouts 0, received 1264877, lost 0, errs 1230, boc 0, free buffers 18, min 17, error reg 110000 dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 390, adv 34547/74657 Accelerometer: LIS3DH, status: 00 Inductive sensor: not found I2C bus errors 0, naks 6, contentions 0, other errors 0 === Filament sensors === Interrupt 5726621 to 0us, poll 4 to 2681us
And it's still happening at random points.
@Exerqtor I can’t remember if you have posted your config.g recently, but if not, could you post it again, please? If it calls macros, maybe a zip of you sys folder might be easier, to include them all. It’s just the Mini 5+ and a 1LC? What revision of each board? And what extruder type and motor? Does it still do it if you run a ‘dry’ job with no filament? Finally, can you post a Gcode file that provokes the retractions? Though I suspect it isn’t related to the Gcode itself.
