Blown fan MOSFET, using different pin on RRF2.x
@Phaedrux I'm gonna changing them, with the aid of a local laboratory.
Concerning expansion port, I know I can't use for a direct load,
so I should use a simple Fotek SSR.
But...which command and which pin?It should be M42, but I'm having difficulties in order to understand the online guide and docs, which pin is available of PWM and pin numbering,
so any help will be appreciated, at least an example (ok, I don't want to get out of contest, here we are for mosfets) -
@supermarioprof Assuming you're using RRF 3.x, most ports are available. However, only some offer PWM. See the list here https://docs.duet3d.com/Duet3D_hardware/Duet_2_family/Duet_2_WiFi_Ethernet_Hardware_Overview#inputoutput
So for PWM, it's bedheat, e[0-1]heat, exp.heater[3-7], or fan[0-2]. For example, you could use HEATER3, which is pin 8 on the Expansion header, pin name 'exp.heater3'. Define it with M950, then set PWM with M42, eg:
M950 P0 C"exp.heater3" Q100 ; create output/servo port 0 attached to heater 3 pin on expansion connector, 100Hz PWM frequency M42 P0 S0.5 ; set 50% PWM on GPIO port 0
@droftarts thanks for your help!
I understand your code, the problem is I'm under RRF 2.05.
Yes I know I should upgrade, it will be the next step.But: what to do with pins, PWM and expansion port under RRF 2.x?
I know about M42 but, obviously, I get an error, likeM42 P3 I1 S240 --> Error: M42: Logical pin X is not available for writing
this sounds ok, since I didn't define that pin with M950 like you did,
but M950 is for RRF 3.x only.
Which command for RRF 2.x? -
@supermarioprof see the notes under the pin table. In RRF 2, pins are pre assigned, so you need to unassign them first:
RRF 2.x - Disable a heater using M307 H# A-1 C-1 D-1 to make the pin available, where # is the heater number, and make sure that no tool is configured to use that heater.
RRF 2.x - Disable a fan using M106 P# I-1 to make the pin available, where # is the fan number.Ian
@droftarts Oh my god I totally missed that line in the guide!
so, if I correctly understood:say I wanna use pin 8 <--> HEATER3
this should be these gcodes:
M307 H3 A-1 C-1 D-1
M42 P3 I1 S240I can't try right now, my damaged Duet3D is still under repair, but I will try as soon as possible.
Last question:
I will need to change my gcodes and my slicer settings, will I?
because FAN0, FAN1 e FAN2 are connected to specific pins (20-22), but my new fan1 should be pin 8, so what?p.s.: I would like to change the thread title so that it will be more inherent with current content, but....is it possible? I can't find any button or settings
Is there a reason to stay on RRF2?
@supermarioprof said in FAN mosfet probably blown:
because FAN0, FAN1 e FAN2 are connected to specific pins (20-22), but my new fan1 should be pin 8, so what?Are you going to have an external MOSFEt? Pin 8, and all expansion pins, are 3.3V signalling, ie not enough to run a fan directly. You can control it with M106, by using the A parameter in RRF 2.x, see https://docs.duet3d.com/User_manual/Reference/Gcodes#m106-fan-on and the notes:
The A parameter can be used to assign a fan to a different output pin, for example a spare heater output (use a M307 command to disable the heater and free up the pin first).
Edit the first post, you can change the thread title there.
@Phaedrux Summer laziness, now I need my 3d printer to be working reliably for a while. during Christmas holiday I will upgrade to RRF3
@droftarts sure I can use an external MOSFET or a Fotek SSR.
thank you very much, M106... A is exactly what I was looking for! -
@droftarts said in FAN mosfet probably blown:
Ianimpossible, too late... 🥺
@supermarioprof Okay, I can, what do you want it to say?
@droftarts "Fan MOSFET blown - using different pin on RRF2.x" could be good, or something like that, it's up to you, thanks!
@supermarioprof Done, going to mark as solved too.
