PanelDue CNC Pendant-pass trough not working
I think PD firmware has the option to use a CRC now instead of a checksum. I don't think the pendant firmware has been updated to handle the CRC.
This was added in PanelDue firmware 3.4.2-pre2:
added CRC16 to gcode request
- by default CRC16 is enabled
- added option to disable checksum and CRC16 in gcode requests
So change M575 to S0 if it's set to S1 in config.g, I think.
Edit: let me know if this works, and I'll add it to the wiki page.
@droftarts said in PanelDue CNC Pendant-pass trough not working:
Hey Ian, unfortunately changing S1 to S0 in the M575 command did not solve the problem.
On another note, is the voltage devider needet when using a Duet 6HC? I understand that the URXD0 pin on the DuetWifi's PanelDue connecter is expecing a 3.3V signal but on the Duet 6HC 5V should work as well?
@MaxGyver said in PanelDue CNC Pendant-pass trough not working:
I haven't worked out how to change the PanelDue to use checksum rather than CRC, and it's possible turning off both causes other problems if there's interference.
Good point, I'm no electronic engineer, so I don't know! I'll ask @dc42.
@MaxGyver the pendant firmware needs to be changed to accept (and preferably generate) a CRC. It's not a lot of work to do but it it will have to be scheduled in with all the other firmware work going on.
@dc42 said in PanelDue CNC Pendant-pass trough not working:
Okay, thank you for your feedback. Is this issue limited to RRF 3.5?
I understand that there is a lot going on with the upcoming release of RRF 3.5. I would very much apreciate if the nessecary firmware updates would be made soon. The pendant is for my CNC-Router that I regularely use for my work. One of the main reasons I decided to convert this machine to use a DUET 6XD controller was the need for a more capable CNC-Pendant.
@MaxGyver it's not directly related to RRF 3.5, it's related to recent PanelDue firmware versions that use CRC16 in preference to checksum, because we've seen that the checksum doesn't offer sufficient protection against interference picked up by the serial line in some installations. As a temporary workaround, you could try an older version of PanelDueFirmware, if that provides enough functionality for you.
@MaxGyver Can you try using PanelDue firmware 3.4.0? https://github.com/Duet3D/PanelDueFirmware/releases/tag/3.4.0. This was from before the CRC feature was implemented. It should still work okay with RRF 3.5, until @dc42 has a chance to update the Pendant firmware.
I think leave the voltage divider in place for now. If it works as-is, you can try without it.
Let me know if the older PanelDue firmware works, and I'll update the instructions until such time as David updates the Pendant firmware.
@MaxGyver I've provisionally scheduled this work on the pendant firmware for shortly after FormNext ends which is on 10 November. Are you happy to wait until then?
@MaxGyver I had a few spare minutes so I created a new branch "crc16" of the pendant firmware with code added to support CRC from PanelDue. I don't have time before FormNext to set up a system to test it, but I guess there's a small chance that it might work; so try it if you wish. There's a #define in file GCodeSerial.h that controls whether it send checksums or CRCs to the Duet.
Of course! I know that you guys have a lot going on. I flashed the PanelDue with FW version 3.4.0. Here it works as expected.
@MaxGyver did you see my message of 1 November?
undefined droftarts referenced this topic
