Filament sensor changing status once starting print.
I just installed 3.4.6. I have a filament sensor that we've been trying to get working no matter what we do for the simple sensor high signal or low signal it will always show that we have no filament when I start a print. I can do an m591 d0 to show that I have filament prior to starting the print and that the sensor is working correctly and as soon as I start the print or resume a print it shows that I have no filament. Something is wrong with the firmware I'm imagining. Anyone have this or can point me in the right direction? I'm also using an s1 so I don't need the new event monitoring.
undefined Phaedrux moved this topic from Firmware installation
What type of filament sensor is it?
Can you share your full configuration? -
@Phaedrux Here is what I have in config.g I have also tried P2 instead of the P1 as well as S1 instead of the S2 which is what I normally use.
M591 D0 P1 C"e0stop" S2
Picture of sensor in use and the wiring diagram in it as well. I also have the 3.3 to the middle pin on e0stop the signal wire to the top pin on e0stop and the ground on the bottom pint of e0stop.
There is only one orientation I can get it to somewhat work but it basically is with filament out it prints and says there is filament. Then when I take the filament out it says there is no filament present. So I then switch to a P2 instead of the P1 and I get same functions.
@Phaedrux Was able to get this to work on e1stop vs trying to use e0stop for whatever reason.
