Dual extrusion on a pendulum x-carraige
I am sorry about posting this but I am looking for some validation and as I can seem to wrap my head around this and come up with a valid answer.
I am tired of my duel e3d on my Prusa clone destroying prints with the second hotend. I have printed a carriage from Thingiverse ( https://www.thingiverse.com/thing:2260178 ). I need to use the servo to tilt the hot end to use each hotend. I am familiar with utilizing heater 3 on the 40 pin connector like I did when I had a BL touch. I understand the need to use M307 H3 A-1 C-1 D-1 which is pin 8 and for 5 volts use pin 1 and 2 is ground. The issue I am having is getting my mind wrapped around the servo control which is M280. I need to add the heater number as P3 if I am correct and for the first hot end I would need to use S0 to have the lowest through of the servo for 1 extruder and S180 for the other as it is a complete sweep of the servo from 1 hotend to the other.
Would I place the code, M280 P3 S0, for example, in the tool section of my slicer?
Is it going to damage the servo if it calls up the tool 0 and it is already there?
Can some one clarify if I am correct and if not correct it for me?
thanks.
You can place the M280 commands in the tool change files tpost0.g and tpost1.g. Sending the same servo command again won't damage it.
Thank you dc42. I am having fun and learning more and more about the hardware every day.
