Wiped....rookie
Right so I misunderstood the instructions. Tried to install updates and it all froze. Didn't recognise anything the next time it was switched on so I ended up formatting my SD card. It now won't retrieve anything. Where do I start do I need to install anything on the SSD?
@kentcrafts probably this is a good starting point https://docs.duet3d.com/en/User_manual/RepRapFirmware/SD_card#creating-the-file-structure
The SD card contains the configuration files. Almost never need to wipe it. The firmware is stored on the board itself. If you're having trouble accessing the board, after restoring the SD card, try this guide,
https://docs.duet3d.com/en/User_manual/Troubleshooting/Duet_wont_respond
