Duet does not auto-connect to WiFi
@Bassbadger Try running M122 and M552 (both with no parameters) via the USB connection after a power on and post the output here. You might also want to post the contents of your config.g file so we can take a look at that as well.
@Bassbadger said in Duet does not auto-connect to WiFi:
Back on a USB connection I can see that the Duet still has the correct settings stored to join the network.
So sending M587 shows the correct SSID added?
Here's the M122 diagnostic:
M122
M552
WiFi module is disabled
ok
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.5 (2022-11-30 19:36:12) running on Duet WiFi 1.02 or later
Board ID: 08DGM-917DA-G4MSD-6JTDJ-3SJ6N-KBTZ9
Used output buffers: 1 of 26 (12 max)
Static ram: 23836
Dynamic ram: 73384 of which 0 recycled
Never used RAM 14860, free system stack 184 words
Tasks: NETWORK(ready,7.5%,517) HEAT(notifyWait,0.0%,388) Move(notifyWait,0.0%,363) MAIN(running,92.4%,428) IDLE(ready,0.0%,30), total 100.0%
Owned mutexes: USB(MAIN)
Last reset 00:04:08 ago, cause: power up
Last software reset time unknown, reason: StuckInSpinLoop, none spinning, available RAM 14860, slot 1
Software reset code 0x0092 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0040080f BFAR 0xe000ed38 SP 0x200034c4 Task NETW Freestk 539 ok
Stack: 0045e223 0045d046 6100f000 41d718fb 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 3f800000 00000000 4354c416 ba0afaff 41a6ac0a 00000000 00419773 00000000 0045e223 20016be8 00000000 00000000 200173f4
Error status: 0x00
Step timer max interval 0
MCU temperature: min 22.1, current 22.8, max 23.0
Supply voltage: min 0.5, current 0.5, max 0.5, under voltage events: 0, over voltage events: 0, power good: no
Events: 0 queued, 0 completed
Driver 0: ok, SG min n/a
Driver 1: ok, SG min n/a
Driver 2: ok, SG min n/a
Driver 3: ok, SG min n/a
Driver 4: ok, SG min n/a
Driver 5:
Driver 6:
Driver 7:
Driver 8:
Driver 9:
Driver 10:
Driver 11:
Slowest loop: 8.87ms; fastest: 0.14ms
=== Storage ===
Free file entries: 10
SD card longest read time 0.9ms, write time 0.0ms, max retries 0
DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
=== AuxDDARing ===
Bed heaters -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is ready with “M122” in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty
=== Network ===
Slowest loop: 0.20ms; fastest: 0.00ms
Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
HTTP sessions: 0 of 8
= WiFi =
Network state is disabled
Failed messages: pending 2779096485, notready 2779096485, noresp 2779096485
ok -
@gloomyandy
M552 S1
ok
WiFi module started
WiFi module is connected to access point TP-Link_1D56, IP address 192.168.1.66 -
@Phaedrux
Yes, it does.M587
Remembered networks:
TNCAP2FCC19 IP=192.168.1.14 GW=0.0.0.0 NM=0.0.0.0
PLUSNET-3X9K IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
Office IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
TP-Link_1D56 IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
ok -
@Phaedrux
Yes, it does.M587
okAh, the correct network is TP-Link_1D56. Should the IP be 0.0.0.0?
I suggest you send
M588 S"*"
to clear all saved networks and then use M587 to re-add your prefered network. -
@Phaedrux
M588 S”*”
ok
M587
Remembered networks: none
ok
M587 S”TP-Link_1D56” P”70259605”
ok
M587
okBut when I disconnect USB and switch on the PSU it does not connect.
Should there be an IP in the Remembered networks or should it be 0.0.0.0?
When you still have usb connected can you send M552 S1?
@Phaedrux
Connects fine and reachable with DWCM552 S1
ok
WiFi module started
Error: WiFi module reported: no known networks found
WiFi module is idle
@Bassbadger
I notice this file is the config-network.g
Is this the same as config.g as I don't seem to have one of those? -
Am I missing the config.g file and if so, where can I find it?
I'm using an Ooznest Workbee with a Duet 2 WiFiBoard: Duet 2 WiFi (2WiFi)
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.5 (2022-11-30)
Duet WiFi Server Version: 1.27 -
You have no config.g in your sys folder?
You may want to check in with Oozenest to make sure you have all the files they provide for configuration.
@Phaedrux
Thanks. I think I mistook config-network.g for config.g
So I'm guessing config.g calls config-network.g I'll check the Ooznest site for a config.g file. -
@Phaedrux
Got it! Added the config.g file to the system and now I have Wifi connection automatically.Thanks to all for your help.
