Expanding Duet3D mini 5+
Thank you for the suggestion @Phaedrux . I am using 6 NEMA 34 stepper motor and 3 servo motors. The integrated driver in Duet3D mini 5+ will not be able to drive NEMA 34. So I thought of using Duet 3 Expansion 3HC but that has only 3 drivers. I don't have any idea of how to expand the board for more drivers. What is the procedure for expanding it further?
@Andrew_15 you could use two 3HC boards. But why not use a Duet 3 6HC instead of a Duet 3 Mini?
