Magnetic filament monitor specs and status
We're using the I2C interface of the AS5600. We drop the lowest 2 bits because they are noisy and we don't need that much precision anyway.
Great, thanks again X) Looks like I get to hack up some firmware.
Nice project! Monitoring the idler wheel is a good idea.
This post is deleted! -
@dc42 hi!
Can you help me?
what is the correct pinout and setting fuse bits attiny45/85?// Pin allocations on the ATTINY44A implementation
#define PIN_SWITCH PINA
const unsigned int PinSwitchBitNum = 2;#define PORT_LED PORTB
#define DDR_LED DDRB
const unsigned int PortLedRedBitNum = 0;
const unsigned int PortLedGreenBitNum = 1;#define PORT_OUT PORTA
#define DDR_OUT DDRA
const unsigned int PortOutBitNum = 7;#define PIN_PROG PINB
const unsigned int PinProgBitNum = 2;Thankyou
@metabo7000 see line 127 of the main.cpp file.
hello!
David eltudná e küldeni a teljes Magnetic filament monitor v2 forráskodot abban még látuk a attiny45 config lehetöséget mert a gibhub ezt gyüjti de már nem tudjuk letölteni csak v3..v4!
v2 giphub no compiled avr studio v7 link text
Nekünk megfelel a filament monitor v2 mert régi firmwert is használunk duet2 alat 2.26 !
Köszi! -
@metabo7000 we switched from attiny45 to attiny44a during the prototyping phase. The firmware has changed a lot since then.
