Cannot upgrading firmware from 2.05.1 to 3.0 and 3.4.5
@genioluiz7 no, that won't work. its on about config.json files for configs previously made with the config tool.
Just go through and get something near enough and then update it to match your current axis dimensions etc afterwards -
@jay_s_uk
how can i configure this page? -
@genioluiz7 assign things how they are in your current config
@jay_s_uk
Hi, I've configured the new file json. How can I be sure I set everything correctly? I want to check before upload that on duet.
@genioluiz7 the board doesn't use the json file it uses config.g
@droftarts don't worry I downloaded the zip file to from the RRF. Now what should I do?
@genioluiz7 said in Cannot upgrading firmware from 2.05.1 to 3.0 and 3.4.5:
Upload that zip file to the system tab in DWC.
@jay_s_uk don't worry I downloaded the zip file to from the RRF. Now what should I do?
@genioluiz7 if you have uploaded your configuration to the Duet, you now need to test everything works, and adjust it as necessary if it does not. Follow this guide: https://docs.duet3d.com/en/How_to_guides/Commissioning
@droftarts I've followed the instruction in the link you sent. After several configurations, these are the conclusions: something works something doesn't. The z-axis doesn't move correctly. My Chiron has two motors to lift the extruder, but only the left one is working, the other seems turned off.
So I think that I've to turn it on and next level the x-axis and synchronize the two z-motors (A and B) together.How can I fix this problem?
Many thanks for your help. Very appreciated. -
So I think that I've to turn it on and next level the x-axis and synchronize the two z-motors (A and B) together.Probably best to start a new thread for this problem. Include your config.g and how you have the motors connected.
