Reboots/resets randomly - RRF 3.5.0-b4
@dc42 noted
@droftarts I'm pretty sure i installed the newest one once David found and patched the issue, but ofc. I can download and install the newest one avalible on git to make sure.
I'm trying to avoid rolling back, if possible (since i would much rather try to have it fixed). If my memory serves right I had no issues on 3.5b2 either, and these issues was introduced with beta 3.
Otherwise, i did a total of 12hours printing yesterday almost back to back without any issues. The printer however totally lost it's shit during the day today while idle
π€£
2023-07-09 23:07:03 [warn] Finished printing file 0:/gcodes/Bottom_0.2mm_ABS_0.4n_5h46m.gcode, print time was 5h 37m 2023-07-09 23:07:08 [info] G10 P0 R0 S0 2023-07-09 23:07:08 [debug] ABS filament unloaded & pressure advance disabled 2023-07-09 23:07:08 [debug] ABS filament unloaded & pressure advance disabled 2023-07-10 06:30:48 [warn] HTTP client 192.168.10.100 login succeeded (session key 1350785786) 2023-07-10 11:21:16 [warn] HTTP client 192.168.10.100 login succeeded (session key 3991901514) power up + 00:00:03 [info] Event logging started at level debug power up + 00:00:03 [info] Running: Duet 3 Mini5plus WiFi: 3.5.0-beta.4 (2023-06-08 23:40:14) power up + 00:00:03 [debug] Done! power up + 00:00:03 [debug] RepRapFirmware for Duet 3 Mini 5+ is up and running. power up + 00:00:04 [warn] WiFi module started power up + 00:00:07 [warn] WiFi module is connected to access point RV32-IOT2G, IP address 192.168.10.50 power up + 00:00:08 [warn] HTTP client 192.168.10.100 login succeeded (session key 572637009) 2023-07-10 12:25:29 [warn] Date and time set at power up + 00:00:08 power up + 00:00:03 [info] Event logging started at level debug power up + 00:00:03 [info] Running: Duet 3 Mini5plus WiFi: 3.5.0-beta.4 (2023-06-08 23:40:14) power up + 00:00:03 [debug] Done! power up + 00:00:03 [debug] RepRapFirmware for Duet 3 Mini 5+ is up and running. power up + 00:00:04 [warn] WiFi module started power up + 00:00:07 [warn] WiFi module is connected to access point RV32-IOT2G, IP address 192.168.10.50 power up + 00:00:08 [warn] HTTP client 192.168.10.100 login succeeded (session key 927937073) 2023-07-10 12:37:30 [warn] Date and time set at power up + 00:00:08 power up + 00:00:03 [info] Event logging started at level debug power up + 00:00:03 [info] Running: Duet 3 Mini5plus WiFi: 3.5.0-beta.4 (2023-06-08 23:40:14) power up + 00:00:03 [debug] Done! power up + 00:00:03 [debug] RepRapFirmware for Duet 3 Mini 5+ is up and running. power up + 00:00:04 [warn] WiFi module started power up + 00:00:07 [warn] WiFi module is connected to access point RV32-IOT2G, IP address 192.168.10.50 power up + 00:00:08 [warn] HTTP client 192.168.10.100 login succeeded (session key 1498099025) 2023-07-10 15:57:31 [warn] Date and time set at power up + 00:00:08 2023-07-10 17:13:09 [warn] HTTP client 192.168.10.226 login succeeded (session key 4209983836)
10.7.2023, 17:22:44 M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-beta.4 (2023-06-08 23:40:14) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: FAP55-Q967A-G65J0-401GL-0S02Z-RF9TL Used output buffers: 14 of 40 (39 max) === RTOS === Static ram: 102996 Dynamic ram: 124180 of which 12 recycled Never used RAM 12012, free system stack 180 words Tasks: NETWORK(2,nWait,20.8%,219) HEAT(3,nWait,0.0%,327) Move(4,nWait,0.0%,344) CanReceiv(6,nWait,0.0%,672) CanSender(5,nWait,0.0%,337) CanClock(7,delaying,0.0%,351) TMC(4,nWait,1.2%,108) MAIN(1,running,73.9%,704) IDLE(0,ready,3.2%,29) AIN(4,delaying,0.8%,266), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 01:25:22 ago, cause: software Last software reset at 2023-07-10 15:57, reason: HardFault invState, Gcodes spinning, available RAM 11988, slot 0 Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00020000 ICSR 0x00000803 BFAR 0xe000ed38 SP 0x20011fa8 Task NETW Freestk 482 ok Stack: 000001ae 00000002 200014ec 00000000 2003335a 0009d43d 00000000 600f0000 00000000 00000000 00000000 00000000 20031144 00000800 20035e68 2002c558 20018670 2002c3f5 20018670 2001e920 0002fe6f 00000000 00000000 00000000 20012058 00000014 02005448 Error status: 0x00 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 5122213, completed 5122213, timed out 0, errs 0 MCU temperature: min 35.3, current 35.9, max 39.0 Supply voltage: min 23.7, current 23.8, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/28, heap memory allocated/used/recyclable 2048/916/532, gc cycles 1519 Events: 0 queued, 0 completed Driver 0: standstill, SG min 2, read errors 0, write errors 1, ifcnt 35, reads 6867, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 2, read errors 0, write errors 1, ifcnt 35, reads 6867, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 155, reads 6867, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 155, reads 6867, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 154, reads 6867, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 5: standstill, SG min 0, read errors 0, write errors 1, ifcnt 54, reads 6869, writes 10, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x6a Driver 6: standstill, SG min 0, read errors 0, write errors 1, ifcnt 54, reads 6870, writes 10, timeouts 0, DMA errors 0, CC errors 0 Date/time: 2023-07-10 17:22:44 Cache data hit count 4294967295 Slowest loop: 22.50ms; fastest: 0.14ms === Storage === Free file entries: 18 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 4.6ms, write time 3.6ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 1 is on, I-accum = 0.0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is doing "G4 P100 " in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000803 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === CAN === Messages queued 46107, received 102482, lost 0, boc 0 Longest wait 3ms for reply type 6053, peak Tx sync delay 322, free buffers 18 (min 17), ts 25611/25610/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 91.05ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 2 of 8 = WiFi = Interface state: active Module is connected to access point Failed messages: pending 0, notready 0, noresp 0 Firmware version 2.1beta4 MAC address bc:ff:4d:e6:b1:62 Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42796 WiFi IP address 192.168.10.50 Signal strength -53dBm, channel 1, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0
The fist of those crashes was with reduced SPI clock speeds, but the subsequent ones should be with default speed.
EDIT:
Just re-downloaded and installed the WifiServer from Release 3.5.0-beta.4 again. Lets see if it's any changes, I'm however 99,9% sure i allready had the latest release of it installed.
That reinstall of the 2.1b4 WiFiServer FW didin't help, just had another crash while swapping out filaments before starting a print.
11.7.2023, 11:10:03 M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-beta.4 (2023-06-08 23:40:14) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: FAP55-Q967A-G65J0-401GL-0S02Z-RF9TL Used output buffers: 15 of 40 (33 max) === RTOS === Static ram: 102996 Dynamic ram: 125612 of which 12 recycled Never used RAM 10580, free system stack 188 words Tasks: NETWORK(2,nWait,20.3%,213) HEAT(3,nWait,0.0%,327) Move(4,nWait,0.0%,358) CanReceiv(6,nWait,0.0%,672) CanSender(5,nWait,0.0%,337) CanClock(7,delaying,0.0%,351) TMC(4,nWait,1.2%,108) MAIN(1,running,74.0%,704) IDLE(0,ready,3.7%,29) AIN(4,delaying,0.8%,266), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:02:00 ago, cause: software Last software reset at 2023-07-11 11:07, reason: HardFault invState, Platform spinning, available RAM 9188, slot 1 Software reset code 0x4060 HFSR 0x40000000 CFSR 0x00020000 ICSR 0x00000803 BFAR 0xe000ed38 SP 0x20011fa8 Task NETW Freestk 482 ok Stack: 000001af 00000002 200014ec 00000000 2003335b 0009d43d 00000000 600f0000 00000000 00000000 00000000 00000000 2003092c 00000800 20035e68 2002c558 20018670 2002c3f5 20018670 2001e920 0002fe6f 00000000 00000000 00000000 20012058 00000014 02005448 Error status: 0x00 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 120690, completed 120690, timed out 0, errs 0 MCU temperature: min 40.5, current 40.7, max 43.8 Supply voltage: min 23.7, current 23.8, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/32, heap memory allocated/used/recyclable 2048/456/32, gc cycles 36 Events: 0 queued, 0 completed Driver 0: standstill, SG min 2, read errors 0, write errors 1, ifcnt 66, reads 10933, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 66, reads 10932, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 173, reads 10932, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 174, reads 10932, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 2, read errors 0, write errors 1, ifcnt 173, reads 10933, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 5: standstill, SG min 0, read errors 0, write errors 1, ifcnt 65, reads 10936, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 6: standstill, SG min 0, read errors 0, write errors 1, ifcnt 65, reads 10935, writes 10, timeouts 0, DMA errors 0, CC errors 0 Date/time: 2023-07-11 11:10:01 Cache data hit count 202352397 Slowest loop: 37.82ms; fastest: 0.14ms === Storage === Free file entries: 17 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 4.2ms, write time 4.5ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 1 is on, I-accum = 0.0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000803 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === CAN === Messages queued 1094, received 2447, lost 0, boc 0 Longest wait 3ms for reply type 6053, peak Tx sync delay 328, free buffers 18 (min 17), ts 604/603/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 22.06ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 = WiFi = Interface state: active Module is connected to access point Failed messages: pending 0, notready 0, noresp 0 Firmware version 2.1beta4 MAC address bc:ff:4d:e6:b1:62 Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 39884 WiFi IP address 192.168.10.50 Signal strength -60dBm, channel 1, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0
Rolling back the WiFiServer FW to 1.27 now to see if that helps.
Rolling back to WiFiServer 1.27 didn't help either.
2023-07-11 13:15:53 [warn] Finished printing file 0:/gcodes/A3-divided-raised_0.2mm_ABS_0.4n_1h55m.gcode, print time was 1h 55m 2023-07-11 13:15:58 [info] G10 P0 R0 S0 2023-07-11 13:15:58 [debug] ABS filament unloaded & pressure advance disabled 2023-07-11 13:15:58 [debug] ABS filament unloaded & pressure advance disabled power up + 00:00:03 [info] Event logging started at level debug power up + 00:00:03 [info] Running: Duet 3 Mini5plus WiFi: 3.5.0-beta.4 (2023-06-08 23:40:14) power up + 00:00:03 [debug] Done! power up + 00:00:03 [debug] RepRapFirmware for Duet 3 Mini 5+ is up and running. power up + 00:00:03 [warn] WiFi module started power up + 00:00:08 [warn] WiFi module is connected to access point RV32-IOT2G, IP address 192.168.10.50 power up + 00:00:09 [warn] HTTP client 192.168.10.100 login succeeded (session key 3300568348) 2023-07-11 14:21:10 [warn] Date and time set at power up + 00:00:09 power up + 00:00:03 [info] Event logging started at level debug power up + 00:00:03 [info] Running: Duet 3 Mini5plus WiFi: 3.5.0-beta.4 (2023-06-08 23:40:14) power up + 00:00:03 [debug] Done! power up + 00:00:03 [debug] RepRapFirmware for Duet 3 Mini 5+ is up and running. power up + 00:00:03 [warn] WiFi module started power up + 00:00:09 [warn] WiFi module is connected to access point RV32-IOT2G, IP address 192.168.10.50 power up + 00:00:09 [warn] HTTP client 192.168.10.100 login succeeded (session key 1905162507) 2023-07-11 17:44:06 [warn] Date and time set at power up + 00:00:09 power up + 00:00:03 [info] Event logging started at level debug power up + 00:00:03 [info] Running: Duet 3 Mini5plus WiFi: 3.5.0-beta.4 (2023-06-08 23:40:14) power up + 00:00:03 [debug] Done! power up + 00:00:03 [debug] RepRapFirmware for Duet 3 Mini 5+ is up and running. power up + 00:00:03 [warn] WiFi module started power up + 00:00:08 [warn] WiFi module is connected to access point RV32-IOT2G, IP address 192.168.10.50 power up + 00:00:09 [warn] HTTP client 192.168.10.100 login succeeded (session key 1141699597) 2023-07-11 18:32:59 [warn] Date and time set at power up + 00:00:09
11.7.2023, 18:57:10 M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-beta.4 (2023-06-08 23:40:14) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: FAP55-Q967A-G65J0-401GL-0S02Z-RF9TL Used output buffers: 1 of 40 (29 max) === RTOS === Static ram: 102996 Dynamic ram: 124216 of which 0 recycled Never used RAM 11988, free system stack 186 words Tasks: NETWORK(1,ready,21.0%,219) HEAT(3,nWait,0.0%,327) Move(4,nWait,0.0%,358) CanReceiv(6,nWait,0.0%,672) CanSender(5,nWait,0.0%,337) CanClock(7,delaying,0.0%,351) TMC(4,delaying,1.2%,108) MAIN(1,running,73.1%,704) IDLE(0,ready,3.8%,29) AIN(4,delaying,0.8%,266), total 100.0% Owned mutexes: === Platform === Last reset 00:24:18 ago, cause: software Last software reset at 2023-07-11 18:32, reason: HardFault invState, Platform spinning, available RAM 11980, slot 1 Software reset code 0x4060 HFSR 0x40000000 CFSR 0x00020000 ICSR 0x00000803 BFAR 0xe000ed38 SP 0x20011fa8 Task NETW Freestk 482 ok Stack: 000001ae 00000002 200014ec 00000000 2003335a 0009d43d 00000000 600f0000 00000000 00000000 00000000 00000000 2003217c 00000800 20035e70 2002c558 20018670 2002c3f5 20018670 2001e920 0002fe6f 00000000 00000000 00000000 20012058 00000014 b5ddc1d1 Error status: 0x00 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 1458383, completed 1458383, timed out 0, errs 0 MCU temperature: min 35.3, current 35.9, max 39.0 Supply voltage: min 23.7, current 23.8, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/28, heap memory allocated/used/recyclable 2048/468/84, gc cycles 428 Events: 0 queued, 0 completed Driver 0: standstill, SG min 2, read errors 0, write errors 1, ifcnt 143, reads 1472, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 2, read errors 0, write errors 1, ifcnt 143, reads 1472, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 229, reads 1472, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 2, read errors 0, write errors 1, ifcnt 231, reads 1472, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 230, reads 1472, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 5: standstill, SG min 0, read errors 0, write errors 1, ifcnt 98, reads 1475, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 6: standstill, SG min 0, read errors 0, write errors 1, ifcnt 98, reads 1475, writes 10, timeouts 0, DMA errors 0, CC errors 0 Date/time: 2023-07-11 18:57:08 Cache data hit count 2422773404 Slowest loop: 22.63ms; fastest: 0.14ms === Storage === Free file entries: 18 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 4.7ms, write time 12.4ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 1 is on, I-accum = 0.0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is doing "G4 P100 " in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000803 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === CAN === Messages queued 13133, received 29207, lost 0, boc 0 Longest wait 3ms for reply type 6053, peak Tx sync delay 223, free buffers 18 (min 17), ts 7292/7291/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 22.76ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 = WiFi = Interface state: active Module is connected to access point Failed messages: pending 0, notready 0, noresp 0 Firmware version 1.27 MAC address bc:ff:4d:e6:b1:62 Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 25544 WiFi IP address 192.168.10.50 Signal strength -57dBm, channel 0, mode 802.11n, reconnections 0 Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0
EDIT 12/7-23:
With the crashes being just as bad now as with the 2.1b4 WiFiServer FW i'm rolling everything back to 3.5b2 since that's the last "stable" version I can remember being on in regards to the crashing. If the crashing stops there I would assume it's safe to say it's a change post 3.5b2 that's causing the behaviour.
One last M122 from 3.5b4:
12.7.2023, 11:43:13 M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-beta.4 (2023-06-08 23:40:14) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: FAP55-Q967A-G65J0-401GL-0S02Z-RF9TL Used output buffers: 1 of 40 (30 max) === RTOS === Static ram: 102996 Dynamic ram: 125612 of which 12 recycled Never used RAM 10580, free system stack 182 words Tasks: NETWORK(1,ready,17.2%,203) HEAT(3,nWait,0.0%,341) Move(4,nWait,0.0%,358) CanReceiv(6,nWait,0.0%,672) CanSender(5,nWait,0.0%,337) CanClock(7,delaying,0.0%,351) TMC(4,nWait,1.2%,108) MAIN(1,running,78.3%,704) IDLE(0,ready,2.3%,29) AIN(4,delaying,0.8%,266), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 01:22:08 ago, cause: software Last software reset at 2023-07-12 10:21, reason: HardFault invState, Expansion spinning, available RAM 9476, slot 2 Software reset code 0x4072 HFSR 0x40000000 CFSR 0x00020000 ICSR 0x00000803 BFAR 0xe000ed38 SP 0x20011fa8 Task NETW Freestk 482 ok Stack: 000001ae 00000002 200014ec 00000000 2003336a 0009d43d 00000000 600f0000 00000000 00000000 00000000 00000000 2003115c 00000800 20035e80 2002c558 20018670 2002c3f5 20018670 2001e920 0002fe6f 00000000 00000000 00000000 20012058 00000014 b5ddc1d1 Error status: 0x00 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 4929142, completed 4929140, timed out 0, errs 0 MCU temperature: min 35.9, current 36.7, max 42.1 Supply voltage: min 23.7, current 23.8, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/32, heap memory allocated/used/recyclable 2048/1404/980, gc cycles 781 Events: 0 queued, 0 completed Driver 0: standstill, SG min 16, read errors 0, write errors 1, ifcnt 17, reads 54838, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 17, reads 54838, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 80, reads 54839, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 82, reads 54839, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 2, read errors 0, write errors 1, ifcnt 82, reads 54839, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 5: standstill, SG min 0, read errors 0, write errors 1, ifcnt 175, reads 54842, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 6: standstill, SG min 0, read errors 0, write errors 1, ifcnt 175, reads 54842, writes 10, timeouts 0, DMA errors 0, CC errors 0 Date/time: 2023-07-12 11:43:10 Cache data hit count 4294967295 Slowest loop: 37.38ms; fastest: 0.14ms === Storage === Free file entries: 18 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 4.7ms, write time 3.9ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 1 is on, I-accum = 0.0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is doing "G4 P100 " in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000803 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === CAN === Messages queued 44368, received 98617, lost 0, boc 0 Longest wait 3ms for reply type 6053, peak Tx sync delay 270, free buffers 18 (min 17), ts 24645/24644/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 22.05ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 = WiFi = Interface state: active Module is connected to access point Failed messages: pending 0, notready 0, noresp 0 Firmware version 1.27 MAC address bc:ff:4d:e6:b1:62 Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 22464 WiFi IP address 192.168.10.50 Signal strength -59dBm, channel 0, mode 802.11n, reconnections 0 Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0
I've been running the printer more or less nonstop (except during the night) since the 12th on the full 3.5b2 release without a single crash.So it seems to me it's some change that got implemented post 3.5b2 that makes my machine act up at least.
EDIT 16th July:
Another two days without any issues running 3.5 beta2.
Still not a single crash with 3.5b2, so i'll go out on a limb and claim that it's a 3.5b3/b4 issue and not HW. -
@Exerqtor can you still get it to crash when you run 3.5.0-beta.4 ?
It could still be a hardware issue, because the memory layout changes between firmware versions. If it's a hardware issue then it might be benign in older firmware versions, e.g. if memory still gets corrupted but that memory is an unused area of the stack instead of a recently-used area.
If it was a a firmware issue, then I would expect to be able to reproduce the reset on a genuine Duet using your build configuration; but I ran it twice for 8 hours at a time and it didn't crash. I would also expect other users to report it.
Gotcha! I'll update to b4 again tomorrow and see how it plays out. If it's still an issue i simply have to run b2 until I get a genuine Duet 3 Mini. -
Updated to 3.5b4 yesterday evening(fresh binaries from github) , and the crashing started again.
M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-beta.4 (2023-06-08 23:40:14) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: FAP55-Q967A-G65J0-401GL-0S02Z-RF9TL Used output buffers: 1 of 40 (38 max) === RTOS === Static ram: 102996 Dynamic ram: 124204 of which 12 recycled Never used RAM 11988, free system stack 182 words Tasks: NETWORK(1,ready,140.3%,219) HEAT(3,nWait,0.2%,327) Move(4,nWait,0.0%,348) CanReceiv(6,nWait,0.4%,672) CanSender(5,nWait,0.0%,337) CanClock(7,delaying,0.1%,351) TMC(4,nWait,8.9%,108) MAIN(1,running,260.0%,704) IDLE(0,ready,6.7%,29) AIN(4,delaying,6.1%,266), total 422.7% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 03:40:27 ago, cause: software Last software reset at 2023-07-25 06:15, reason: HardFault invState, Platform spinning, available RAM 11988, slot 1 Software reset code 0x4060 HFSR 0x40000000 CFSR 0x00020000 ICSR 0x00000803 BFAR 0xe000ed38 SP 0x20011fa8 Task NETW Freestk 482 ok Stack: 000001b0 00000002 200014ec 00000000 ffffffff 0009d43d 00000000 600f0000 00000000 00000000 00000000 00000000 20032174 00000800 20035e68 2002c558 20018670 2002c3f5 20018670 2001e920 0002fe6f 00000000 00000000 00000000 20012058 00000014 00000000 Error status: 0x00 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 13227701, completed 13227701, timed out 0, errs 0 MCU temperature: min 35.5, current 36.1, max 39.4 Supply voltage: min 23.7, current 23.8, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/29, heap memory allocated/used/recyclable 2048/1884/1488, gc cycles 1629 Events: 0 queued, 0 completed Driver 0: standstill, SG min 2, read errors 0, write errors 1, ifcnt 216, reads 22838, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 2, read errors 0, write errors 1, ifcnt 216, reads 22837, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 234, reads 22837, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 2, read errors 0, write errors 1, ifcnt 234, reads 22837, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 2, read errors 0, write errors 1, ifcnt 232, reads 22838, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 5: standstill, SG min 0, read errors 0, write errors 1, ifcnt 76, reads 22839, writes 10, timeouts 2, DMA errors 0, CC errors 0, failedOp 0x41 Driver 6: standstill, SG min 0, read errors 0, write errors 1, ifcnt 76, reads 22840, writes 10, timeouts 0, DMA errors 0, CC errors 0 Date/time: 2023-07-25 09:55:34 Cache data hit count 4294967295 Slowest loop: 24.26ms; fastest: 0.14ms === Storage === Free file entries: 18 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 4.5ms, write time 4.5ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 1 is on, I-accum = 0.0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is doing "G4 P100 " in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000803 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === CAN === Messages queued 119057, received 264597, lost 0, boc 0 Longest wait 4ms for reply type 6053, peak Tx sync delay 274, free buffers 18 (min 17), ts 66139/66138/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 22.45ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 2 of 8 = WiFi = Interface state: active Module is connected to access point Failed messages: pending 0, notready 0, noresp 0 Firmware version 2.1beta4 MAC address bc:ff:4d:e6:b1:62 Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42968 WiFi IP address 192.168.10.50 Signal strength -54dBm, channel 1, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0
@Exerqtor was the machine idle or printing?
Idle. It's been a couple more crashes since last post to, also while idle.M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-beta.4 (2023-06-08 23:40:14) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: FAP55-Q967A-G65J0-401GL-0S02Z-RF9TL Used output buffers: 19 of 40 (28 max) === RTOS === Static ram: 102996 Dynamic ram: 124180 of which 12 recycled Never used RAM 12012, free system stack 186 words Tasks: NETWORK(2,nWait,18.4%,219) HEAT(3,nWait,0.0%,352) Move(4,nWait,0.0%,358) CanReceiv(6,nWait,0.0%,662) CanSender(5,nWait,0.0%,337) CanClock(7,delaying,0.0%,351) TMC(4,delaying,1.2%,108) MAIN(1,running,78.5%,704) IDLE(0,ready,0.9%,29) AIN(4,delaying,0.8%,266), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:18:41 ago, cause: software Last software reset at 2023-07-25 20:51, reason: HardFault invState, Gcodes spinning, available RAM 11236, slot 1 Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00020000 ICSR 0x00000803 BFAR 0xe000ed38 SP 0x20011fa8 Task NETW Freestk 482 ok Stack: 000001b0 00000002 200014ec 00000000 ffffffff 0009d43d 00000000 600f0000 00000000 00000000 00000000 00000000 20032174 00000800 20035e68 2002c558 20018670 2002c3f5 20018670 2001e920 0002fe6f 00000000 00000000 00000000 20012058 00000014 b5ddc1d1 Error status: 0x00 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 1121100, completed 1121100, timed out 0, errs 0 MCU temperature: min 36.3, current 36.9, max 41.8 Supply voltage: min 23.7, current 23.8, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/29, heap memory allocated/used/recyclable 2048/1692/1296, gc cycles 137 Events: 0 queued, 0 completed Driver 0: standstill, SG min 174, read errors 0, write errors 1, ifcnt 103, reads 36347, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 16, read errors 0, write errors 1, ifcnt 103, reads 36347, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 111, reads 36347, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 2, read errors 0, write errors 1, ifcnt 110, reads 36347, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 2, read errors 0, write errors 1, ifcnt 108, reads 36347, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 5: standstill, SG min 0, read errors 0, write errors 1, ifcnt 175, reads 36350, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 6: standstill, SG min 0, read errors 0, write errors 1, ifcnt 175, reads 36350, writes 10, timeouts 0, DMA errors 0, CC errors 0 Date/time: 2023-07-25 21:10:08 Cache data hit count 1876944189 Slowest loop: 8.00ms; fastest: 0.14ms === Storage === Free file entries: 18 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 4.3ms, write time 2.2ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 1 is on, I-accum = 0.0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is doing "G4 P100 " in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000803 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === CAN === Messages queued 10098, received 22458, lost 0, boc 0 Longest wait 3ms for reply type 6053, peak Tx sync delay 261, free buffers 18 (min 17), ts 5606/5605/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 10.73ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 2 of 8 = WiFi = Interface state: active Module is connected to access point Failed messages: pending 0, notready 0, noresp 0 Firmware version 2.1beta4 MAC address bc:ff:4d:e6:b1:62 Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 43124 WiFi IP address 192.168.10.50 Signal strength -52dBm, channel 1, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0
@Exerqtor can you try un-configuring some devices to see whether that stops the board from crashing when it is sitting idle. For example, you could un-configure everything on the expansion boards; or un-configure all temperature sensors.
Sure, i'm up for trying. What would be the best approach to do this in your opinion (i'm not sure how to "un-configure" it once it's been configuredAnd would you suggest putting it in daemon or just make it a custom config.g to be ran as a test with mentioned stuff not configured and let the machine stay idle to see if it mitigates the crashing?
@Exerqtor I suggest temporarily commenting out the corresponding lines in config.g and rebooting.
TLDR: Can a bad / "EOL" SD-card have been at fault for the issues I've been having?
Never got around to change the lines since the printer was running stable on 3.5b2 and i had some prints going.I went through with buying a genuine Mini 5+ instead since i was/am in the impression that issue was most likely HW related. It still haven't arrived so I cant confirm that or not.
BUT on sunday evening while doing some routine maintenance (printer powered down, and power cord pulled) something weird happened when I finished up and booted the printer. It started all normally and i went through to home it but then PD promted me that i was missing all the homing files (one after one once i tried axis by axis), i went forrward to try turning on the chamber lights with it's macro: same issue, it's reported missing as well.
Baffeled i tried heating up the hotend to 75c just to see if the hotend fan turned on or not, it did. Turned off the heater and let it settle to where the fan turned off again. Started to think something must have gone wrong in the bootup (or something), so i powet toggeled the printer, this time PD warned about some JSON error while booting then just said "connecting" in top right corner and everything was unresponsive, couldn't connect to DWC either.
That's when i started to suspect something was going on with the SD card, powered down again and pulled the card out and put it in my computer, and sure AF it was corrupted with only a handfull of files readable, and ALL the files in
sys/
and subfolders had changed names and exentions to something totally nonsense and went corrupted despite changing them to the right file extension.Tried running some recovery software on it, and managed to pull everything from
filaments/
,firmware/
& most of the job files ingcode/
except one file. So yesterday i bought a new namebrand class 10 sdcard and started rebuilding the printer setup on the new card. And i just managed to boot and run the checks before going to bed.With everything confirmed working it started to dawn on me that maybe a shoddy SD card might have been the culprit for this reboot issue to, so I got back up from bed and flashed 3.5b4 to both the MB and Toolboard and ran a new set of initial checks to see that everything was fine (which it was) and went back to bed.
Checked the printer now after the morning walk with the dog, and still bo reboots/crashes/resets.
SOOOO can a shoddy SD card have caused these issues all along? Or is the corrupted card a totally standalone problem? -
@Exerqtor the only way I can think of that a corrupt SD card could cause the problem would be if RRF read a corrupt command from it that caused RRF to overflow an array bound, or something like that.
All the code I added to RRF does check that commands don't cause array bounds to be exceeded, but there might be some older code that doesn't.
@dc42 Ok, i to doubt the SD card was the culprit but i thought i should air the theory since it happened.
Still running 3.5b4 in idle at home, so i'm curious if it's gotten any new resets by the time i finish work
π€·ββοΈ
Curious to see if the behaviour changes with the new board to ofc.
Just had a reset now, so that comfirms it not being the SD-card lol.
M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-beta.4 (2023-06-08 23:40:14) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: FAP55-Q967A-G65J0-401GL-0S02Z-RF9TL Used output buffers: 1 of 40 (28 max) === RTOS === Static ram: 102996 Dynamic ram: 125644 of which 12 recycled Never used RAM 10548, free system stack 182 words Tasks: NETWORK(1,ready,17.1%,203) HEAT(3,nWait,0.0%,352) Move(4,nWait,0.0%,358) CanReceiv(6,nWait,0.0%,672) CanSender(5,nWait,0.0%,337) CanClock(7,delaying,0.0%,351) TMC(4,nWait,1.2%,108) MAIN(1,running,80.6%,704) IDLE(0,ready,0.2%,29) AIN(4,delaying,0.8%,266), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:44:41 ago, cause: software Last software reset at 2023-08-15 18:10, reason: HardFault invState, Gcodes spinning, available RAM 9052, slot 0 Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00020000 ICSR 0x00000803 BFAR 0xe000ed38 SP 0x20011fa8 Task NETW Freestk 482 ok Stack: 000001af 00000002 200014ec 00000000 2003338b 0009d43d 00000000 600f0000 00000000 00000000 00000000 00000000 2003095c 00000800 20035e98 2002c558 20018670 2002c3f5 20018670 2001e920 0002fe6f 00000000 00000000 00000000 20012058 00000014 b5dd60fa Error status: 0x00 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 2681568, completed 2681568, timed out 0, errs 0 MCU temperature: min 36.1, current 36.9, max 42.2 Supply voltage: min 23.7, current 23.8, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/33, heap memory allocated/used/recyclable 2048/564/128, gc cycles 125 Events: 0 queued, 0 completed Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 126, reads 47121, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 14, read errors 0, write errors 1, ifcnt 126, reads 47121, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 98, reads 47121, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 2, read errors 0, write errors 1, ifcnt 99, reads 47120, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 2, read errors 0, write errors 1, ifcnt 99, reads 47121, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 5: standstill, SG min 0, read errors 0, write errors 1, ifcnt 54, reads 47124, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 6: standstill, SG min 0, read errors 0, write errors 1, ifcnt 54, reads 47124, writes 10, timeouts 0, DMA errors 0, CC errors 0 Date/time: 2023-08-15 18:55:09 Cache data hit count 4294967295 Slowest loop: 13.48ms; fastest: 0.13ms === Storage === Free file entries: 18 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 5.3ms, write time 4.5ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 1 is on, I-accum = 0.0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is doing "G4 S1 " in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000803 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === CAN === Messages queued 24140, received 53662, lost 0, boc 0 Longest wait 3ms for reply type 6053, peak Tx sync delay 316, free buffers 18 (min 17), ts 13407/13406/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 6.07ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 = WiFi = Interface state: active Module is connected to access point Failed messages: pending 0, notready 0, noresp 0 Firmware version 2.1beta4 MAC address bc:ff:4d:e6:b1:62 Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42972 WiFi IP address 192.168.10.50 Signal strength -57dBm, channel 1, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0
Hopefully the new board arrives tomorrow or tuesday, let's hope that solves it.
I had a reset as well, this one ANOTHER out of memory fault tied to the tool-board/CAN bus.
It's at the point I can't do any large prints without the machine resetting half way through and wasting filament. Incredibly frustrating when you have it running 1-2 days only to quit on you before it finishes.
