Duet 3 Expansion 1HCL tacho reading
@dc42 can I use OUT 0 and OUT 1 on tisti same board for PWM controlling my noctua fans and water pump. Will be same as fan pwm output?
@matej1006 yes you can, provided the current they require doesn't exceed the rating of the outputs. Check the water pump starting current in particular.
@dc42 it is a 12V pc Water colling so i think it will be ok but i will check just to be sure about it
@dc42 if i connect 12v directly from power supply tacho won't work ?
@matej1006 tacho connections should still work of you connect the positive fan wire direct to +12V.
this is how have now connected all . And pump won't start! GND is commom
@matej1006 have you the specification of the pump?
You may need to invert the polarity of the out port in the M950 command, as you would for a PWM fan.
@dc42 it is 12Vdc 17W pump which can be connected directly to pc Mother board
I did try to invert and pullup and nothing was different -
@matej1006 does the pump work if you disconnect the blue PWM wire?
; Water colling PUMP M950 F2 C"!Fan0" Q25000 ; fan 2 is a 4-wire PWM fan so invert it, use high PWM frequency, tacho connected to PB6 on expansion connector M106 P2 H5 I1 T20:25 L255 ; set fan 2 value. Thermostatic control is turned on
This is my code from duet2 eth board
Now I have duet3 6hc
I try same code and it wasn't workIf I swap noctua fans with pump fans works on this output out6 pump on out5 is same nothing from her
That I didn't try I Will tommorow
