FTP does not properly respond to "LIST -a"
I am using wget to download files from the SD Card using FTP. worked so far for 3.4, but has stopped working in 3.5.
After some research it turns out that the newly introduced feature of supporting LIST <dir> does not take into account the -a flag that is sent by many FTP clients including wget.there is a discussion here:
https://savannah.gnu.org/bugs/?59954The relevant change is here. Should an error be returned on LIST -a?
https://github.com/Duet3D/RepRapFirmware/commit/7e11027b22a0720d756369393bf96d94a2c01b9a#diff-1608ecf6e91dd6a71fa80c16d6c79cc2e79f5b6ed17ab92a97b8fd8de96d1dd4R675-R678i guess if an error is returned, wget will retry with "LIST", that's the usual behaviour.
debug output of wget looks like this:
230 Login successful. Logged in! ==> SYST ... --> SYST 215 UNIX Type: L8 done. UNIX TYPE L8: I know it and I will use "LIST -a" as standard list command
Cheers
Adam -
@adambx if I provide you with a new RRF binary, can you test it? Which Duet are you using?
PS - I created https://github.com/Duet3D/RepRapFirmware/issues/882.
@adambx we are closing this issue because you have not responded.
