DWC volumetric flow that 2 x that of prusa slicer
@oliof thought i would move it to DWC
M122
RepRapFirmware for STM32F4 based Boards (biqoctopuspro_1.0) version 3.5.0-beta.4_101 (2023-06-10 19:03:47) running on STM32F4 (standalone mode)
Board ID: 32063-002JU-NJ38P-6T18S-HFUN7-70000
Used output buffers: 3 of 40 (33 max)
Static ram: 19636
Dynamic ram: 92072 of which 0 recycled
Never used RAM 18336, free system stack 105 words
CCMRam static ram: 24276 dynamic ram: 34380 free ram 6876
Tasks: NETWORK(2,nWait,118.2%,176) HEAT(3,nWait,0.4%,324) Move(4,nWait,0.9%,275) TMC51xx(4,delaying,70.1%,116) FSWRITE(2,nWait,0.0%,492) MAIN(1,running,36.4%,538) IDLE(0,ready,0.3%,29), total 226.2%
Owned mutexes: WiFi(NETWORK)
Last reset 07:37:25 ago, cause: software
Last software reset at 2023-07-07 12:15, reason: User, Gcodes spinning, available RAM 18132, slot 0
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
Error status: 0x08
MCU temperature: min 35.1, current 37.3, max 41.5
Supply voltage: min 24.0, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
Heap OK, handles allocated/used 99/13, heap memory allocated/used/recyclable 2048/1540/1340, gc cycles 0
Events: 0 queued, 0 completed
Driver 0: standstill 5160, SG min 0, mspos 952, reads 43963, writes 55, write errors 1
Driver 1: standstill 5160, SG min 0, mspos 632, reads 43963, writes 55, write errors 1
Driver 2: standstill 5160, SG min 0, mspos 744, reads 43989, writes 30
Driver 3: standstill 5160, SG min 0, mspos 884, reads 43976, writes 43, write errors 1
Driver 4: standstill 5160, SG min 0, mspos 548, reads 43977, writes 42, write errors 1
Driver 5: standstill 5160, SG min 0, mspos 4, reads 43977, writes 42, write errors 1
Driver 6: not present
Driver 7: standstill 5160, SG min 0, mspos 24, reads 43991, writes 28
Driver 8:
Driver 9:
Driver 10:
Driver 11:
Driver 12:
Driver 13:
Date/time: 2023-07-07 19:53:22
Slowest loop: 320.96ms; fastest: 0.07ms
=== Storage ===
Free file entries: 20
SD card 0 detected
SD card longest read time 5.9ms, write time 25.4ms, max retries 0
DMs created 83, segments created 34, maxWait 107224ms, bed compensation in use: none, height map offset 0.000, ebfmin -1.00, ebfmax 1.00
no step interrupt scheduled
=== DDARing 0 ===
Scheduled moves 57782, completed 57782, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 2], CDDA state -1
=== DDARing 1 ===
Heater 0 is on, I-accum = 0.1
Heater 1 is on, I-accum = 0.5
HTTP is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
File2 is idle in state(s) 0, sync state 2
Queue2 is idle in state(s) 0
Q0 segments left 0, axes/extruders owned 0x0006003
Code queue 0 is empty
Code queue 1 is empty
=== Filament sensors ===
Extruder 0 sensor: ok
=== CAN ===
Disabled
Longest wait 0ms for reply type 0, peak Tx sync delay 0 free buffers 0 (min 0), ts 0/0/0
Tx timeouts 0,0,0,0,0,0
=== Network ===
Slowest loop: 242.65ms; fastest: 0.00ms
Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0)
HTTP sessions: 1 of 8
Uploads/Errors: 3/0
= WiFi =
Interface state: active
Module is connected to access point
Bad header: 0/0
Firmware version 2.1beta4
MAC address e8:68:e7:d9:f9:a3
Module reset reason: Turned on by main processor, Vcc 3.39, flash size 2097152, free heap 42916
WiFi IP address 192.168.0.21
Signal strength -57dBm, channel 1, mode 802.11n, reconnections 0
Clock register 00002002
Socket states: 0 0 0 0 0 0 0 0 -
@moth4017 also check in the object model browser that move.extruders[0].filamentDiameter is correct. RRF passes the extrusion rate in mm/sec to DWC, and DWC uses the filament diameter to convert it to mm^3/sec.
@moth4017
i do have 2 extruders running at the same time in a push pull configuration is it possible its adding both values? -
@moth4017 Set the mixing ratios to 50%:50% and double your E steps/mm (and potentially other E-related settings), else your filament-based estimation is probably off, too.
@moth4017 said in DWC volumetric flow that 2 x that of prusa slicer:
@moth4017
i do have 2 extruders running at the same time in a push pull configuration is it possible its adding both values?Yes. The firmware has no way of knowing if the mechanical configuration is a single input hot end with two extruders in push-pull configuration, or if it's a two in one out mixing hot end with both extruders feeding different filaments. So it will combine the flow for each extruder in accordance with the mixing ratio in use (in your case that would be 1.00:1.00 so 200%).
@deckingman if the esteps are different on each extruder is it still 50:50 or does it have to be in the estep ratio?
Not sure I fully understand your question but for the purposes of calculating volumetric flow correctly, the sum of mixing ratio should add up to unity. As @chrishamm has said, you could double the steps per mm for both extruders then use 0.5:0.5 instead of 1.0:1.0. If you have different steps per mm for each extruder and the system works but the only problem is the displayed volumetric flow values is exactly double what it should be, and if your current mixing ratio is 1.00:1.00, then double both extruder steps per mm from their current values and halve the mixing ratio to 0.5:0.5.
@deckingman
interesting at 50% its is half the speed of prursa slicer so:at
M567 P0 E0.5:0.5 half the speed of the prusa rate DWC 4mm^3 Prusa 8mm^3
M567 P0 E1:1 is twice the speed of the prusa rate DWC 16mm^3 Prusa 8mm^3in DWC if i extrude 40mm on 20mm is extruded
M567 P0 E0.5:0.5 it is also only extruding half the amount of filamenti guess because it is selected in "Mix" but it also Prints in "Mix" because it assumes the extruders are in parallel.
@dc42 may be there needs to be an added option to M567 2P ( for 2 extruders in parallel) or 2S (for 2 extruders in series
) etc . -
@moth4017 Did you change the extruder steps per mm as well as the mixing ratio?
@deckingman no only the ratios , i left the steps/mm correct for the extruder
@moth4017 That's your problem. DWC will report the extrusion amount based on the sum of each extruder in accordance with the mixing ratio. So when you used 1.0:1.0 you were seeing the volumetric extrusion reported as being double but the actual amount extruded was correct. By changing it to 0.5:0.5 in a push pull arrangement, each extruder will physically half the amount needed. That's why both @chrishamm and I told you to double the steps per mm for each extruder so that the amount physically extruded would remain the same.
would it make more sense for the software to adjust the steps/mm so that you can set up the extruders with the correct steps, because when your using multiple tools keeping track of them is fun .
thanks for all the help
