using a macro for the G31 command?
Is there a way to set the z-offset position in g-config and config.g.bak to 0 at the same time using a macro for the G31 command? So far I have to open config.g and set the offset to 0 every time and then open config.g.bak and set the offset to 0 there...I find that cumbersome
@axiom
I think you might mean config-override.g rather than config.g.bakIf you have a config-override.g and you have M501 at the end of config.g then there's no need to edit config.g
In your macro, just set your offsets using G31 then call M500 P31 to save it to config-override.g
e.g
G31 X0 Y0 M500 P31
On restart, whatever is in the override file will replace what was set in config.g
@axiom said in using a macro for the G31 command?:
It should be set once and it won't change.
Are you sending M500 P31 at some point to save a different G31 value to config-override.g?
Or are you saying that your config.g isn't saving when you edit it? How are you editing it?
@Phaedrux If I want to reset my z-offset, do I first have to set the existing offset to zero in config.g? Then I follow the routine from the documentation...after that I enter my result from the G30 S-1 for the z-offset in the config.g. Although I have M501 at the end, I have to enter the value in confi-override.g every time, otherwise my offset will not be accepted. I find that very difficult. Can't you simplify this whole routine? Here is my config.g code:
; Configuration file for Duet WiFi (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.16 on Sun May 28 2023 15:23:44 GMT+0200 (Mitteleuropäische Sommerzeit); General preferences
M550 P"DUKA Axiom" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S1 ; enable FTP
M586 P2 S1 ; enable Telnet; Drives
;M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
M92 X80.00 Y80.00 Z640.00 E322.58 ; set steps per mm
;M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M566 X900.00 Y900.00 Z100.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
;M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M203 X6000.00 Y6000.00 Z300.00 E1200.00 ; set maximum speeds (mm/min)
;M201 X500.00 Y500.00 Z20.00 E250.00 ; set accelerations (mm/s^2)
M201 X500.00 Y500.00 Z40.00 E250.00 ; set accelerations (mm/s^2)
M906 X2500 Y1600 Z1800 E1600 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X750 Y638 Z1255 S0 ; set axis maxima; Endstops
M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
;M574 Z2 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin zstop
;M574 Z2 S2 ; configure Z-probe endstop for high end on Z; Z-Probe
M558 P1 C"!zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
G31 P1000 X-1 Y-61 Z2 ; set Z probe trigger value, offset and trigger height
M557 X0:700 Y-27:577 S40 ; define mesh grid; Heaters
; Bed
;M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit
M307 H2 R0.283 K0.463:0.000 D7.17 E1.35 S1.00 B0 ; enable bang-bang mode for the bed heater and set PWM limit
M143 H0 S280 ; set temperature limit for heater 0 to 120C;Hotend
;M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
M307 H1 R1.797 K0.742:0.000 D7.57 E1.35 S1.00 B0 V23.8 ; disable bang-bang mode for heater and set PWM limit
M143 H1 S400 ; set temperature limit for heater 1 to 400C; Fans
M950 F0 C"fan0" Q600 ; create fan 0 on pin fan0 and set its frequency
M950 F1 C"fan1" Q700 ; create fan 1 on pin fan1 and set its frequency
M106 P1 S1 H1 T60 ; set fan 1 value. Thermostatic control is turned on
M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
M106 P2 S1 H1 T50 ; set fan 2 value. Thermostatic control is turned on; Tools
;M563 P1 S"Druckkopf 1" H1 F0 ; define tool 1
M563 P0 D0 H1 F0 ; define tool 1
G10 P0 X0 Y0 Z0 ; set tool 1 axis offsets
G10 P0 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
M591 D0 P1 C"e1-stop" S0 ;R40:120 E3.0 S1 Filament Sensor
M501 -
If you would like to have the paramaters saved to the config-override automatically check the M500 command.
M501 only tells the firmware to read the config-override at the end of the boot process.
So all of the parameters that are redundant will be set to the last read values.
In your case the config-override.If you remove the parameter entry from config-override the config is used......
I personally avoid using the override function. It is easier for me to have all the parameters in one place. It also makes support more difficult.
Yes, you don't need to even measure the offset at all if you're using manual probing because the offset is 0. It's only needed when using a probe that isn't the nozzle tip.
You can delete the line from your config-override.g if it exists. It only gets written there if you send
M500 P31
specifically.
