[3.5.0-beta.3] 'set var.arr[0] = 1' in loop leads to reset
Hi folks,
Right now, I'm trying to make my macros a bit more maintainable by using arrays. I noticed the following problem:
; create array to store n messurements var reading = vector(10, 0) echo var.reading ; get n messurements and save them in array while iterations < 10 set var.reading[iterations] = 1 echo var.reading
Normally, of course, I would not assign a 1 to all elements in the array, but I have simplified the example as much as possible.
If I run the macro, I get the following messages in the console:
"M122" throws the following output:
M122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.5.0-beta.3 (2023-04-14 11:28:15) running on Duet 3 MB6HC v1.0 or earlier (SBC mode) Board ID: 08DJM-956L2-G43S4-6JTD4-3SS6J-TA7GH Used output buffers: 5 of 40 (31 max) Error in macro line 72 while starting up: M584: Driver 1.0 does not exist === RTOS === Static ram: 154728 Dynamic ram: 87944 of which 1128 recycled Never used RAM 99336, free system stack 196 words Tasks: SBC(rWait:,1.1%,390) HEAT(nWait,0.0%,326) Move(nWait,0.0%,340) CanReceiv(nWait,0.0%,795) CanSender(nWait,0.0%,334) CanClock(delaying,0.0%,341) TMC(nWait,7.7%,59) MAIN(running,90.5%,135) IDLE(ready,0.6%,30), total 100.0% Owned mutexes: HTTP(MAIN) === Platform === Last reset 00:01:54 ago, cause: software Last software reset at 2023-05-18 13:49, reason: TerminateCalled, FilamentSensors spinning, available RAM 99240, slot 0 Software reset code 0x418d HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x20439470 Task SBC Freestk 665 ok Stack: 0000002b 004966d1 0000002b 00496a7f 00000000 004964c1 204394c0 ffff0000 204394c0 004962a7 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 20434a68 00000000 004b7ba4 20434a68 0040ae05 20439524 20409b08 Error status: 0x00 Aux0 errors 0,0,0 MCU temperature: min 35.6, current 44.0, max 44.3 Supply voltage: min 23.9, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.0, current 12.0, max 12.1, under voltage events: 0 Heap OK, handles allocated/used 99/8, heap memory allocated/used/recyclable 2048/1208/1076, gc cycles 9 Events: 0 queued, 0 completed Driver 0: standstill, SG min n/a, mspos 8, reads 48953, writes 14 timeouts 0 Driver 1: standstill, SG min n/a, mspos 8, reads 48952, writes 15 timeouts 0 Driver 2: standstill, SG min n/a, mspos 8, reads 48953, writes 15 timeouts 0 Driver 3: standstill, SG min n/a, mspos 8, reads 48954, writes 14 timeouts 0 Driver 4: standstill, SG min n/a, mspos 8, reads 48954, writes 14 timeouts 0 Driver 5: standstill, SG min n/a, mspos 8, reads 48954, writes 14 timeouts 0 Date/time: 2023-05-18 13:51:18 Slowest loop: 3.89ms; fastest: 0.05ms === Storage === Free file entries: 20 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000 no step interrupt scheduled === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Movement locks held by null, null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon* is idle in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000000 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === Filament sensors === Extruder 2: no data received === CAN === Messages queued 1044, received 3756, lost 0, boc 0 Longest wait 3ms for reply type 6053, peak Tx sync delay 373, free buffers 50 (min 49), ts 574/573/0 Tx timeouts 0,0,0,0,0,0 === SBC interface === Transfer state: 5, failed transfers: 0, checksum errors: 0 RX/TX seq numbers: 7608/6553 SPI underruns 0, overruns 0 State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x26650 Buffer RX/TX: 0/0-0, open files: 0 === Duet Control Server === Duet Control Server version 3.5.0-beta.3 (2023-04-14 15:12:26) Daemon: >> Doing macro daemon.g, started by system Code buffer space: 4096 Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0 Full transfers per second: 59.05, max time between full transfers: 304.0ms, max pin wait times: 258.3ms/10.2ms Codes per second: 3.45 Maximum length of RX/TX data transfers: 4657/960
@marvineer Should there be a var Iterations = 0 before the while?
@tas no. iterations is created by the
while
loop -
@marvineer this looks like either a bug that we have already fixed in the 3.5 source code, or it's specific to SBC mode. We're looking into it.
Thanks @marvineer and @dc42, I have fixes ready for DSF and RRF. The reason for the reset was identified by dc42 and the underlying problem was the fact that
iterations
, which is provided by DSF in SBC mode, wasn't populated before theset
command was executed by RRF. -
