Solved 3.5 B3 Toolboard stepper intermittently running backwards
@dc42 said in 3.5 B3 Toolboard stepper intermittently running backwards:
@ctilley79 the new commands for configuring and controlling LED strips are implemented in the 3.5.0-beta.3+ binaries that I posted. They have been tested on Duet 3 Mini and 6HC.
@Exerqtor please post the M950 and M150 commands you used.
That's weird, since i'm quiiiite sure i'm using the right command set (for a Duet3 Mini).
I TRY to send
M950 E0 C"DO" T2
, but i get the error mentioned above.The M150's have been changed to this (for example):
M150 E0 R150 U150 B150 W150 S1 F1 M150 E0 R150 U150 B150 W150 S2 F0
@Exerqtor Is "DO" a valid pin name on the mini? I had a quick look and couldn't find any pins with that name. Is this for the neopixels in a display attached via the exp headers?
@Exerqtor Are you sure
DO
is right and notD0
@oliof I copied it from the docs since I was unsure about the exact same thing
So unless it's written wrong there as well it should be correct. -
@Exerqtor Which docs? I've just checked the source and there is no pin called either D0 or DO as far as I can tell. What pin are you trying to drive the neopixels from?
@gloomyandy said in 3.5 B3 Toolboard stepper intermittently running backwards:
The only pin that supports it on a Duet 3 Mini, which from what I can see lacks a proper explanation on what the "DO" pin is actually called. "ctrl+f" search for DO here and look at the 14th entry. Thats the only mention of it (that i'm able to find) in all the docs / schematics.
It's also just called "DO" in the schematics:
@Exerqtor the dedicated LED port is known as "led" in the firmware. This needs to be added to the documentation.
@dc42 Then i bet a beer on the problem being solved for both me and @ctilley79 now that we know that. Thx!
This post is deleted! -
@Exerqtor said in 3.5 B3 Toolboard stepper intermittently running backwards:
Does the M150 P parameter to work for you on this firmware build? I'm also using RGBW neopixels. The P parameter does nothing right now.
@ctilley79 said in 3.5 B3 Toolboard stepper intermittently running backwards:
I don't use the
P
parameter, only the R/G/B/W component "amount", it should yeld the same result although you would have to play around with the values to get the same effect. -
@ctilley79 you are correct, the P parameter doesn't work for Neopixels. I will correct this before we release beta4.
May I know how to define M950 for Duet2Wifi? It can use M150 directly before, however it is failed and need definition first now. But not pin name found...
@hestiahuang said in 3.5 B3 Toolboard stepper intermittently running backwards:
Add the source code to confirm my finding.
so don't miss Duet2Wifi...
@hestiahuang thanks, this is now fixed ready for 3.5beta4.
