M915 feature is loss after 3.5.0 beta2 version on extruder
@chrishamm I am not sure why, maybe H1 is never been tested for ST yet. However the restult is as my test reported.
M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5.0-beta.3 (2023-04-14 11:27:37) running on Duet WiFi 1.02 or later + DueX5 Board ID: 0JD0M-9P6M2-NW4SD-6JKFG-3SJ6S-KAQBJ Used output buffers: 2 of 26 (26 max) === RTOS === Static ram: 22192 Dynamic ram: 84248 of which 0 recycled Never used RAM 8, free system stack 112 words Tasks: NETWORK(ready,810.1%,194) HEAT(nWait,6.3%,307) Move(nWait,25.0%,291) DUEX(nWait,0.0%,26) MAIN(running,75.6%,451) IDLE(ready,1.2%,29), total 918.3% Owned mutexes: === Platform === Last reset 09:03:48 ago, cause: software Last software reset at 2023-04-23 10:51, reason: StuckInSpinLoop, Gcodes spinning, available RAM 1100, slot 2 Software reset code 0x4083 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x200021f8 Task NETW Freestk 4294966881 ok Stack: 00000000 200012dc 10000000 e000e000 000000a0 0045f78b 0045ef00 610b0000 0045eef1 00000000 ffffffff 00000000 050a5a26 00000000 20000d94 ffffffff 20002818 200194e8 0045efb7 200002e0 200022cc 200194e8 0045c3f7 20000d94 00405a29 20000b58 0042d70f Error status: 0x04 Aux0 errors 0,0,0 MCU temperature: min 35.1, current 35.8, max 49.7 Supply voltage: min 22.4, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 198/85, heap memory allocated/used/recyclable 4096/3360/1644, gc cycles 1 Events: 0 queued, 0 completed Driver 0: standstill, SG min 0 Driver 1: standstill, SG min 0 Driver 2: standstill, SG min 0 Driver 3: standstill, SG min n/a Driver 4: standstill, SG min n/a Driver 5: standstill, SG min n/a Driver 6: standstill, SG min n/a Driver 7: standstill, SG min 0 Driver 8: standstill, SG min n/a Driver 9: standstill, SG min n/a Driver 10: Driver 11: Date/time: 2023-04-23 19:55:46 Cache data hit count 4294967295 Slowest loop: 238.91ms; fastest: 0.14ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 10.9ms, write time 2.8ms, max retries 0 === Move === DMs created 83, segments created 41, maxWait 624886ms, bed compensation in use: none, comp offset 0.000 no step interrupt scheduled === DDARing 0 === Scheduled moves 85286, completed 85286, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 0 is on, I-accum = 0.1 === GCodes === Movement locks held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Q0 segments left 0 Code queue 0 is empty === DueX === Read count 301, 0.55 reads/min === Network === Slowest loop: 210.71ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 = WiFi = Network state is active Module is connected to access point Failed messages: pending 0, notready 0, noresp 0 Firmware version 2.1beta4 MAC address e8:db:84:9b:18:c5 Module reset reason: Power up, Vcc 3.36, flash size 2097152, free heap 42856 WiFi IP address 192.168.50.52 Signal strength -50dBm, channel 7, mode 802.11n, reconnections 0 Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0
@chrishamm said in M915 feature is loss after 3.5.0 beta2 version on extruder:
@hestiahuang I've checked the underlying code and there is no notable difference between the code used on the Duet 2 and 3.
G1 S
is only supported in Laser mode and theS
parameter is ignored otherwise in 3.5-b3. OnlyG1 H1
moves can use SG for filament loading. If you are still on an old RRF version, this behaviour may be inverted, i.e.G1 S1
stops when the extruder stalls andG1 H1
acts like a normal move without SG detection.Please send the output of
M122
from your machine.Let me try explain more what my config.
- The whole macro can run fine after I change "H" back to "S". No other extra change.
- code like this
M201 E10000 M915 P3 S6 F0 R0 G1 E-1 F300 G1 E60 F300 G1 E800 F4800 M201 E1000 M913 E28 G1 S1 E200 F1500 M915 P3 R0 M913 E100 M201 E10000
I really not config the M201.1 in my config.g. I guess it is defaul by the firmware. My machine is E3D ToolChanger.
Simulation steps like my macro code about.- M201 to set the acceleration to 10000
- Define the ST
- Retract 1mm avoid to trigger ST detection
- Run extrusion and load the filament slowly
- Load filament fast
- M201 to change the acceleration to 1000
- Change ST detection current to 28%(full current is 1250mA)
- G1 S1 E200 F1500 => Extrude 200mm with 25mm/s, ensure it ST can be captured(Howere there is no move if it is H1, it is working fine it is S1)
- Turn off ST
- Resume 100% current
- Set the acceleration back to 10000
@hestiahuang on a G1 H1 move with a stall endstop enabled, the M201.1 acceleration is used instead of the M201 acceleration. So try removing the M201 commands from your macro and instead adding M201.1 E1000 to your config.g file or to that macro.
@dc42 said in M915 feature is loss after 3.5.0 beta2 version on extruder:
Noted and thx, I can't wait to try now.
Just tried. Result is the same as before.
M915 P3 S6 F0 R0 ;Define the ST
G1 E-1 F300 ;Retract 1mm avoid to trigger ST detection
G1 E60 F300 ;Run extrusion and load the filament slowly
G1 E800 F4800 ;Load filament fast
M201.1 E1000 ;M201.1 to define the acceleration to 1000
M913 E28 ;Change ST detection current to 28%(full current is 1250mA)
G1 H1 E200 F1500 ;Extrude 200mm with 25mm/s ====>tested and found there is no move(no extrusion)
M915 P3 R0 ;Turn off ST
M913 E100 ;Resume 100% current -
What my point is if the same macro, and the change is only from S1 to H1 and M201 to M201.1, why it is not working now. What change else I should implement?
@hestiahuang only two of us at Duet3D have Duet 2 systems that could be used to try to reproduce the issue you are experiencing, and both of us are away at present. I will be back next week so I will try to reproduce it then.
@dc42 great, thx!
@hestiahuang I raised this issue https://github.com/Duet3D/RepRapFirmware/issues/847
thx for your help on that!
@hestiahuang can you confirm that this works in 3.4.0-beta.4 ?
