Duet 6XD "halted" and show restart , why?
i use duet 6XD some days and everything was ok, but now while i am printing or not, the board show me the message for restart...
Emergency stop, attemping to reconnect...
I don't know why, i dont have any input config that restart the board for any alarm or similar.
This is the M122 that give me after restart.
Any idea?
M122 === Diagnostics === RepRapFirmware for Duet 3 MB6XD version 3.4.5 (2022-11-30 19:41:59) running on Duet 3 MB6XD v1.0 or later (SBC mode) Used output buffers: 1 of 40 (12 max) === RTOS === Static ram: 151200 Dynamic ram: 65076 of which 0 recycled Never used RAM 134396, free system stack 219 words Tasks: SBC(ready,0.5%,511) HEAT(notifyWait,0.0%,374) Move(notifyWait,0.0%,351) CanReceiv(notifyWait,0.0%,944) CanSender(notifyWait,0.0%,336) CanClock(delaying,0.0%,343) MAIN(running,96.9%,1232) IDLE(ready,2.6%,29), total 100.0% Owned mutexes: HTTP(MAIN) === Platform === Last reset 00:00:32 ago, cause: software Last software reset at 2023-05-04 14:57, reason: User, none spinning, available RAM 130916, slot 1 Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a Error status: 0x00 Step timer max interval 18465 MCU temperature: min 36.8, current 37.0, max 47.2 Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0 Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Events: 0 queued, 0 completed Driver 0: ok Driver 1: ok Driver 2: ok Driver 3: ok Driver 4: ok Driver 5: ok Date/time: 2023-05-04 14:58:31 Slowest loop: 25.43ms; fastest: 0.04ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Segments left: 0 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === CAN === Messages queued 165, received 0, lost 0, boc 0 Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 165/0/0 Tx timeouts 0,0,164,0,0,0 last cancelled message type 30 dest 127 === SBC interface === Transfer state: 5, failed transfers: 0, checksum errors: 0 RX/TX seq numbers: 1616/1616 SPI underruns 0, overruns 0 State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x2b770 Buffer RX/TX: 0/0-0, open files: 0 === Duet Control Server === Duet Control Server v3.4.5 Code buffer space: 4096 Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 13 Full transfers per second: 51.67, max time between full transfers: 257.0ms, max pin wait times: 36.0ms/10.0ms Codes per second: 1.98 Maximum length of RX/TX data transfers: 3008/844
@FBG that reset code indicates that the SBC commanded the Duet to reset. More info may be available in the DSF logs.
@dc42 Where i can find DSF logs?
- log into your Single Board Computer
- run
sudo journalctl -xe -u duetcontrolserver
@FBG E-STOP from the SBC is only triggered if it is part of a macro file or when you hit E-STOP on the UI. There is no other mechanism that calls it. Also, E-STOP on DWC restarts the board as well, it doesn't leave the machine in the "Halted" state.
Do you have any other triggers configured? A trigger can be set up to halt the machine as well, and if there is a dodgy connection to it, that could explain it.
Hello everybody,
after send the code for the dsf log this said that trigger6 do the restart...I checked trigger6 and my config.g and is truth... i did a mistake in the config.g file...
Sorry for that, i was desperate!!
Thanks for your support!
