Turning off servos and M42 interrupting the last pulse
@pfn Do you operate the servo from a Duex as well?
@chrishamm no, mine is run off the vfd/laser/out6 port on duet3mini5+
@pfn you can also turn off the servo output using M280 Pnn S0 although you may find that it has the same issue.
@dc42 thanks, my concern is actually how to avoid the truncated last pulse. (For that matter, sending M280 S0 rather than M42 S0 seems to send a 500us pulse as the servo always goes to the 500us position when I use M280 S0)
@pfn which version of RepRapFirmware are you using?
@dc42 3.4.5
@pfn that's odd because I checked the code to confirm what I thought, which is that M208 Pnn S0 should turn the pin off, just like M42. I'll log this as a potential bug.
@dc42 I have this macro: https://github.com/pfn/voron2-rrf-config/blob/master/sys/mmu/lib/engage.g where
mmu_servo_engage
is set to0
and it reliably sets the servo position to that of the 500us value. -
@pfn said in Turning off servos and M42 interrupting the last pulse:
mmu_servo_engage
is set to0
and it reliably sets the servo position to that of the 500us value.Do you mean it does that if you uncomment the M42 line and change M42 to M208 ?
@dc42 the macro is just a link to how I have everything setup, if I use
M280 P2 S100
and subsequently runM280 P2 S0
, the servo 100% reliably goes back to the 500us position.If I use
M280 P2 S100
and subsequently runM42 P2 S0
most of the time the servo stays in place, sometimes it will go to a position between S100 and 500us. -
@pfn thanks for the clarification.
