RRF3.5: select two files for printing?
The idea behind the topic is to preselect two files on SD-card and assign each one to their tool.
Then start a universal 'start-dual gcode' file which does all the preliminary stuff, like homing and heating.
At the end this start file should start the preselected files.How could this be done? Via object model would be best, but I'd also consider renaming the printfiles...
undefined o_lampe marked this topic as a question
@o_lampe you could assign the file names to variables, then call the variables from a dual print file.
