Manual method of Autocal on a delta (Solved)
I believe there is a method where the firmware will probe by manual means and then take a measurement by button press then move to the other points in the bed.g to do the same. this is on a machine with no Z Probe or failing that can the probe be fitted lower than the nozzle and if so would the offset be negative in the G31 command?
Question is how to define that method and how to instigate it what to look for etc
You set probe type P0 in the M558 command, then send the G31 command from DWC.
Thank you David much appreciated so the G31 will be something like G31 X0 Y0 Z0.1 then and what about the G32?
The G31 Z offset won't be used. The X and Y offsets should be set to zero. You will need to construct a bed.g file as usual.
Sorted thanks David worked like a charm for the cal.
How do I mark this as solved on the forum
Doug
