DSF Rockpi 4B Se on armbian
@Amagatth Can you install
gpiod
and issuesudo gpioinfo
Hopefully the device tree has the detailed info and you can just read it there. -
gpiochip4 - 32 lines:
line 0: unnamed unused input active-high
line 1: unnamed unused input active-high
line 2: unnamed unused input active-high
line 3: unnamed unused input active-high
line 4: unnamed unused input active-high
line 5: unnamed unused input active-high
line 6: unnamed unused input active-high
line 7: unnamed unused input active-high
line 8: unnamed unused input active-high
line 9: unnamed unused input active-high
line 10: unnamed unused input active-high
line 11: unnamed unused input active-high
line 12: unnamed unused input active-high
line 13: unnamed unused input active-high
line 14: unnamed unused input active-high
line 15: unnamed unused input active-high
line 16: unnamed unused input active-high
line 17: unnamed unused input active-high
line 18: unnamed unused input active-high
line 19: unnamed unused input active-high
line 20: unnamed unused input active-high
line 21: unnamed unused input active-high
line 22: unnamed unused input active-high
line 23: unnamed unused input active-high
line 24: unnamed unused input active-high
line 25: unnamed "vcc5v0-host-regulator" output active-high [used]
line 26: unnamed unused input active-high
line 27: unnamed unused output active-high
line 28: unnamed unused input active-high
line 29: unnamed unused input active-high
line 30: unnamed unused input active-high
line 31: unnamed unused input active-high
cdfi@CDFI:~$you want the other gpiochip ?
@Amagatth
GPIO4 has 32 lines so 37 is not valid.I made a mistake in the GPIO line calculation above. It should be 3 * 8 + 5 = 29
Can you try :
"GpioChipDevice": "/dev/gpiochip4", "TransferReadyPin": 29,
@Falcounet Thx i try it monday
@Falcounet Hi falcounet,
The error change now i have error like on the image !
when i try tout boot duet control server i have an error and it dont want to start
i have it on the journaltcl
mars 25 12:52:28 CDFI systemd[1]: Starting Duet Web Server...
mars 25 12:52:31 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.DataProtection.Repositories.EphemeralXmlRepository[50] Using an in-memory repository. Keys will not be persisted to storage.
mars 25 12:52:31 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.DataProtection.KeyManagement.XmlKeyManager[59] Neither user profile nor HKLM registry available. Using an ephemeral key repository. Protected data >
mars 25 12:52:32 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.DataProtection.KeyManagement.XmlKeyManager[58] Creating key {e2589570-6e22-48e4-bc7f-a96ff057bc2b} with creation date 2023-03-25 11:52:32Z, activat>
mars 25 12:52:32 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.DataProtection.KeyManagement.XmlKeyManager[35] No XML encryptor configured. Key {e2589570-6e22-48e4-bc7f-a96ff057bc2b} may be persisted to storage >
mars 25 12:52:33 CDFI DuetWebServer[1548]: Microsoft.Hosting.Lifetime[14] Now listening on: http://[::]:80
mars 25 12:52:33 CDFI DuetWebServer[1548]: Microsoft.Hosting.Lifetime[0] Application started. Hosting environment: Production; Content root path: /opt/dsf/dwc
mars 25 12:52:33 CDFI systemd[1]: Started Duet Web Server.
mars 25 12:52:33 CDFI DuetWebServer[1548]: DuetWebServer.Services.ModelObserver[0] Failed to synchronize machine model System.Net.Internals.SocketExceptionFactory+ExtendedSocketException (99): Cannot assign requ>
mars 30 14:18:50 CDFI DuetWebServer[1548]: DuetWebServer.Services.ModelObserver[0] Failed to synchronize machine model System.Net.Internals.SocketExceptionFactory+ExtendedSocketException (99): Cannot assign requ>
mars 30 14:18:55 CDFI DuetWebServer[1548]: DuetWebServer.Services.ModelObserver[0] Failed to synchronize machine model System.Net.Internals.SocketExceptionFactory+ExtendedSocketException (99): Cannot assign requ>
mars 30 14:19:00 CDFI DuetWebServer[1548]: DuetWebServer.Services.ModelObserver[0] Failed to synchronize machine model System.Net.Internals.SocketExceptionFactory+ExtendedSocketException (99): Cannot assign requ>
mars 30 14:19:05 CDFI DuetWebServer[1548]: DuetWebServer.Services.ModelObserver[0] Failed to synchronize machine model System.Net.Internals.SocketExceptionFactory+ExtendedSocketException (99): Cannot assign requ>
mars 30 14:19:10 CDFI DuetWebServer[1548]: DuetWebServer.Services.ModelObserver[0] Failed to synchronize machine model System.Net.Internals.SocketExceptionFactory+ExtendedSocketException (99): Cannot assign requ>
mars 30 14:19:15 CDFI DuetWebServer[1548]: DuetWebServer.Services.ModelObserver[0] Failed to synchronize machine model System.Net.Internals.SocketExceptionFactory+ExtendedSocketException (99): Cannot assign requ>
mars 30 14:19:20 CDFI DuetWebServer[1548]: DuetWebServer.Services.ModelObserver[0] Failed to synchronize machine model System.Net.Internals.SocketExceptionFactory+ExtendedSocketException (99): Cannot assign requ>
mars 30 14:19:25 CDFI DuetWebServer[1548]: DuetWebServer.Services.ModelObserver[0] Failed to synchronize machine model System.Net.Internals.SocketExceptionFactory+ExtendedSocketException (99): Cannot assign requ>
mars 30 14:19:30 CDFI DuetWebServer[1548]: DuetWebServer.Services.ModelObserver[0] Failed to synchronize machine model System.Net.Internals.SocketExceptionFactory+ExtendedSocketException (99): Cannot assign requ>
mars 30 14:19:35 CDFI DuetWebServer[1548]: DuetWebServer.Services.ModelObserver[0] Failed to synchronize machine model System.Net.Internals.SocketExceptionFactory+ExtendedSocketException (99): Cannot assign requ>
mars 30 14:19:40 CDFI DuetWebServer[1548]: DuetWebServer.Services.ModelObserver[0] Failed to synchronize machine model System.Net.Internals.SocketExceptionFactory+ExtendedSocketException (99): Cannot assign requ>
mars 30 14:19:42 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Hosting.Diagnostics[1] Request starting HTTP/1.1 GET http://127.0.0.1/precache-manifest.f4a5c16fc7874f9aeeb60a854f6db5f3.js - -
mars 30 14:19:42 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Hosting.Diagnostics[1] Request starting HTTP/1.1 GET http://127.0.0.1/service-worker.js - -
mars 30 14:19:43 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.StaticFiles.StaticFileMiddleware[2] Sending file. Request path: '/service-worker.js'. Physical path: '/opt/dsf/sd/www/service-worker.js'
mars 30 14:19:43 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.StaticFiles.StaticFileMiddleware[2] Sending file. Request path: '/precache-manifest.f4a5c16fc7874f9aeeb60a854f6db5f3.js'. Physical path: '/opt/dsf/>
mars 30 14:19:43 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Hosting.Diagnostics[2] Request finished HTTP/1.1 GET http://127.0.0.1/precache-manifest.f4a5c16fc7874f9aeeb60a854f6db5f3.js - - - 200 1921 applicat>
mars 30 14:19:43 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Hosting.Diagnostics[2] Request finished HTTP/1.1 GET http://127.0.0.1/service-worker.js - - - 200 1069 application/javascript 370.1715ms
mars 30 14:19:45 CDFI DuetWebServer[1548]: DuetWebServer.Services.ModelObserver[0] Failed to synchronize machine model System.Net.Internals.SocketExceptionFactory+ExtendedSocketException (99): Cannot assign requ>
mars 30 14:19:45 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Hosting.Diagnostics[1] Request starting HTTP/1.1 GET http://127.0.0.1/img/icons/apple-touch-icon-152x152.png - -
mars 30 14:19:45 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.StaticFiles.StaticFileMiddleware[2] Sending file. Request path: '/img/icons/apple-touch-icon-152x152.png'. Physical path: '/opt/dsf/sd/www/img/icon>
mars 30 14:19:45 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Hosting.Diagnostics[2] Request finished HTTP/1.1 GET http://127.0.0.1/img/icons/apple-touch-icon-152x152.png - - - 200 3608 image/png 50.3444ms
mars 30 14:19:50 CDFI DuetWebServer[1548]: DuetWebServer.Services.ModelObserver[0] Failed to synchronize machine model System.Net.Internals.SocketExceptionFactory+ExtendedSocketException (99): Cannot assign requ>
mars 30 14:19:54 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Hosting.Diagnostics[1] Request starting HTTP/1.1 GET http://127.0.0.1/rr_connect?password=reprap&time=2023-03-30T14%3A19%3A53 - -
mars 30 14:19:54 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Hosting.Diagnostics[2] Request finished HTTP/1.1 GET http://127.0.0.1/rr_connect?password=reprap&time=2023-03-30T14%3A19%3A53 - - - 404 0 - 9.7355ms
mars 30 14:19:54 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Hosting.Diagnostics[1] Request starting HTTP/1.1 GET http://127.0.0.1/service-worker.js - -
mars 30 14:19:54 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.StaticFiles.StaticFileMiddleware[6] The file /service-worker.js was not modified
mars 30 14:19:54 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Hosting.Diagnostics[2] Request finished HTTP/1.1 GET http://127.0.0.1/service-worker.js - - - 304 - application/javascript 80.8443ms
mars 30 14:19:55 CDFI DuetWebServer[1548]: DuetWebServer.Services.ModelObserver[0] Failed to synchronize machine model System.Net.Internals.SocketExceptionFactory+ExtendedSocketException (99): Cannot assign requ>
mars 30 14:19:56 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Hosting.Diagnostics[1] Request starting HTTP/1.1 GET http://127.0.0.1/rr_connect?password=reprap&time=2023-03-30T14%3A19%3A56 - -
mars 30 14:19:56 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Hosting.Diagnostics[2] Request finished HTTP/1.1 GET http://127.0.0.1/rr_connect?password=reprap&time=2023-03-30T14%3A19%3A56 - - - 404 0 - 4.8931ms
mars 30 14:19:57 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Hosting.Diagnostics[1] Request starting HTTP/1.1 GET http://127.0.0.1/machine/connect?password=reprap - -
mars 30 14:19:57 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Routing.EndpointMiddleware[0] Executing endpoint 'DuetWebServer.Controllers.MachineController.Connect (DuetWebServer)'
mars 30 14:19:57 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[3] Route matched with {action = "Connect", controller = "Machine"}. Executing controller action with sig>
mars 30 14:19:57 CDFI DuetWebServer[1548]: DuetWebServer.Controllers.MachineController[0] [Connect] Failed to initialize settings: Object reference not set to an instance of an object.
mars 30 14:19:57 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Mvc.Infrastructure.ObjectResultExecutor[1] Executing ObjectResult, writing value of type 'System.String'.
mars 30 14:19:58 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[2] Executed action DuetWebServer.Controllers.MachineController.Connect (DuetWebServer) in 214.1531ms
mars 30 14:19:58 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Routing.EndpointMiddleware[1] Executed endpoint 'DuetWebServer.Controllers.MachineController.Connect (DuetWebServer)'
mars 30 14:19:58 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Hosting.Diagnostics[2] Request finished HTTP/1.1 GET http://127.0.0.1/machine/connect?password=reprap - - - 503 - text/plain;+charset=utf-8 567.867>
mars 30 14:19:59 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Hosting.Diagnostics[1] Request starting HTTP/1.1 GET http://127.0.0.1/rr_connect?password=reprap&time=2023-03-30T14%3A19%3A59 - -
mars 30 14:19:59 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Hosting.Diagnostics[2] Request finished HTTP/1.1 GET http://127.0.0.1/rr_connect?password=reprap&time=2023-03-30T14%3A19%3A59 - - - 404 0 - 13.3461>
mars 30 14:19:59 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Hosting.Diagnostics[1] Request starting HTTP/1.1 GET http://127.0.0.1/machine/connect?password=reprap - -
mars 30 14:19:59 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Routing.EndpointMiddleware[0] Executing endpoint 'DuetWebServer.Controllers.MachineController.Connect (DuetWebServer)'
mars 30 14:19:59 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[3] Route matched with {action = "Connect", controller = "Machine"}. Executing controller action with sig>
mars 30 14:19:59 CDFI DuetWebServer[1548]: DuetWebServer.Controllers.MachineController[0] [Connect] Failed to initialize settings: Object reference not set to an instance of an object.
mars 30 14:19:59 CDFI DuetWebServer[1548]: Microsoft.AspNetCore.Mvc.Infrastructure.ObjectResultExecutor[1] Executing ObjectResult, writing value of type 'System.String'. -
@Amagatth No idea if that error can be related to a SPI communication issue. Probably @chrishamm can comment
@Amagatth Sounds like you messed up something in the DCS settings. Try to delete the
config.json
file once (sudo rm /opt/dsf/conf/config.json
), restart DCS (it should recreate it automatically), make the chip/pin/SPI adjustments again, and check if it works then. -
@chrishamm It work !! thx !!!
@chrishamm hi , i have a new error
spi reset always each second
Warning: SPI connection has been reset its the error message
@Amagatth said in DSF Rockpi 4B Se on armbian:
Take a look here: https://github.com/Duet3D/DuetSoftwareFramework/wiki/SBC-Setup-Guide#spi-connection-reset
