Temperature offset?
@Queevix
https://docs.duet3d.com/User_manual/Connecting_hardware/Temperature_connecting_thermistors_PT1000
For the PT1000 B and C parameter are not required. Remove them.... -
@DIY-O-Sphere
Thank you for your reply, I removed the B and C parameters, must have been a relic from the previous setup of this printer.The problem seems to persist though, I'm now at -9°C, and still going down...
@Queevix
Are you shure that it is an PT1000 sensor? -
@DIY-O-Sphere
I am. I just double checked. I do have a spare, that I could replace it with, but I feel a little awkward about disassembling the hotend if I can't accurately control the temperature. -
@Queevix
If you can reach the connector on the board, you can disconnect the sensor and measure the resistance directly with an ohmmeter.
At 20°C you should measure about 1077Ohm.
You can also do this with the replacement. -
@DIY-O-Sphere
The spare measures 1.070 Kohm at about 18°C, the problematic PT1000 gives me 1.069 Kohm. I feel like this difference would be tolerable, or am I wrong? -
@Queevix https://www.sterlingsensors.co.uk/pt1000-resistance-table
1069 is just under 18C, so no you're not wrong.
@achrn @DIY-O-Sphere
So why am I still getting a reading of -12.4°C in DWC? -
@Queevix I have no idea, because the direction it's going implies the resistance the Duet is seeing is slightly lower than what you're measuring - if it was a poor connection I'd expect it to be increasing resistance, which would show as a too high reading, and if it was a short you'd see a reading that's miles off. I don't know what manifests as a slightly too low reading.
Does that change if you heat the sensor with a something like hair dryer?
@infiniteloop
It sure does, it also changes if I set the hotend to any temperature.
The problem (I assume) is that the reading I get from my sensor is about 30 degrees lower than the temperature it's actually at.
so if I heat it up to 160degrees, it would actually be about 190°C -
So I assume the PT1000 to be working properly.
For a PT1000, such an offset is uncommon. Maybe you got some parasitic resistance along the lines and/or connectors? As you have a second PT1000, try to connect that directly to the board: does it tell the same readings at room temperature as the one you've built-in?
Can you post your full config.g and config-override.g?
Also post the results of M122 and M98 P"config.g" -
@infiniteloop
The spare gives me more or less the same result (difference of about half a degree), also with the other connector lead. -
Here's my full config file. I do not seem to have a config-override on this printer. Could that be a problem?
; Configuration file for Duet 3 Mini 5+ (firmware version 3.3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3.10 on Sat Jan 22 2022 15:24:14 GMT+0100 (Central European Standard Time) ; General preferences M575 P1 S1 B57600 ; enable support for PanelDue G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"BigBitch" ; set printer name ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0.0 S1 ; physical drive 0.0 goes forwards M569 P0.1 S0 ; physical drive 0.1 goes forwards M569 P0.2 S1 ; physical drive 0.2 goes forwards M569 P0.3 S1 ; physical drive 0.3 goes forwards M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z400.00 E409.00 ; set steps per mm M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E250.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X475 Y465 Z450 S0 ; set axis maxima ; Endstops M574 X1 S1 P"io5.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io5.in M574 Y1 S1 P"io6.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io6.in M574 Z1 S2 ; configure Z-probe endstop for low end on Z ; Z-Probe M950 S0 C"io2.out" ; Duet 3 Mini 5+ M558 P9 C"io2.in" H10 F120 T6000 A3 ; set Z probe type to modulated and the dive height + speeds G31 P1000 X-39 Y2 Z3.1 S21 H2 T0.02 ; Nozzle offset - Powder Coated Sheet with temperature compensation (0.02mm/°C) M574 Z1 S2 ; set Z probe trigger value, offset and trigger height M557 X5:435 Y5:465 P10:10 ; define mesh grid M376 H5 ; Fade height 5mm ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 B0 R0.213 C666.6 D8.13 S1.00 V24.1 ; M140 H0 ; map heated bed to heater 0 M143 H0 S80 ; set temperature limit for heater 0 to 80C M308 S1 P"temp1" Y"pt1000" ; configure sensor 1 as thermistor on pin temp1 M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1 M307 H1 R1.350 K0.244:0.000 D5.89 E1.35 S1.00 B0 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"out4" Q500 ; create fan 1 on pin out4 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M572 D0 S0.06 M563 P1 D0 H1 F0 ; define tool 0 G10 P1 X0 Y0 Z0 ; set tool 0 axis offsets G10 P1 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M572 D0 S0.06 M563 P2 D0 H1 F0 ; define tool 0 G10 P2 X0 Y0 Z0 ; set tool 0 axis offsets G10 P2 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M572 D0 S0.06 M563 P3 D0 H1 F0 ; define tool 0 G10 P3 X0 Y0 Z0 ; set tool 0 axis offsets G10 P3 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M572 D0 S0.06 M563 P4 D0 H1 F0 ; define tool 0 G10 P4 X0 Y0 Z0 ; set tool 0 axis offsets G10 P4 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M572 D0 S0.06 M563 P5 D0 H1 F0 ; define tool 0 G10 P5 X0 Y0 Z0 ; set tool 0 axis offsets G10 P5 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M572 D0 S0.06 M563 P6 D0 H1 F0 ; define tool 0 G10 P6 X0 Y0 Z0 ; set tool 0 axis offsets G10 P6 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M572 D0 S0.06 M563 P7 D0 H1 F0 ; define tool 0 G10 P7 X0 Y0 Z0 ; set tool 0 axis offsets G10 P7 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M572 D0 S0.06 ; Custom settings are not defined
M122
M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.4.1 (2022-06-01 21:06:56) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: URV2B-M396U-D65J0-40KMY-1H03Z-72JMX Used output buffers: 3 of 40 (27 max) === RTOS === Static ram: 103684 Dynamic ram: 111512 of which 0 recycled Never used RAM 26516, free system stack 196 words Tasks: NETWORK(ready,14.4%,253) HEAT(notifyWait,0.0%,358) Move(notifyWait,0.0%,363) CanReceiv(notifyWait,0.0%,942) CanSender(notifyWait,0.0%,372) CanClock(delaying,0.0%,339) TMC(notifyWait,0.7%,114) MAIN(running,84.0%,426) IDLE(ready,0.1%,29) AIN(delaying,0.8%,273), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:05:29 ago, cause: power up Last software reset at 2023-02-26 13:21, reason: User, GCodes spinning, available RAM 23252, slot 0 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 330081, completed 330080, timed out 0, errs 0 Step timer max interval 1490 MCU temperature: min 23.5, current 28.0, max 28.0 Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Events: 0 queued, 0 completed Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 17318, writes 9, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 17317, writes 9, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 17317, writes 9, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 17317, writes 9, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 17318, writes 9, timeouts 0, DMA errors 0, CC errors 0 Driver 5: not present Driver 6: not present Date/time: 2023-02-27 07:12:12 Cache data hit count 636420885 Slowest loop: 33.38ms; fastest: 0.13ms === Storage === Free file entries: 10 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 1.5ms, write time 8.5ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === CAN === Messages queued 2964, received 0, lost 0, boc 0 Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 18 (min 18), ts 1648/0/0 Tx timeouts 0,0,1647,0,0,1315 last cancelled message type 4514 dest 127 === Network === Slowest loop: 33.48ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 - WiFi - Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.26 WiFi MAC address d8:bf:c0:15:0b:d5 WiFi Vcc 3.38, reset reason Power up WiFi flash size 2097152, free heap 25464 WiFi IP address 192.168.1.33 WiFi signal strength -70dBm, mode 802.11n, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0
M98 P"config.g"
M98 P"config.g" HTTP is enabled on port 80 FTP is disabled TELNET is disabled Warning: Temperature coefficients ignored due to invalid sensor number 2
@Queevix said in Temperature offset?:
That warning is because you've put temperature compensation using sensor 2 in the probe definition, but you don't have a sensor 2. I don't think it's relevant to the fault under discussion though.
The warning would go if you took the
S21 H2 T0.02
out of your G31 line. -
I'll try that this evening. Thanks!
Try moving the sensor to a different input. It is possible you have a bad ADC channel.
