[Request] Add `recursiveDelete` to param to `GET /rr_delete`
Is is possible to add a
recursiveDelete
(default tofalse
) toGET /rr_delete
? At the moment it's doesn't seem to be possible to remove a dir if it contains something inside. I would like to avoid overloading HTTP server with a bunch of delete reqs. -
@chrishamm do you think that it's worth adding this to API?
@AndMaz if we do add this facility then I think we should put some restrictions on it. I am reminded of when I ran a Linux script that had an error in it and ended up running "rm -r /". It deleted a lot of files on other devices on the LAN before I realised what was happening.
@dc42 I agree with you. It should not be possible to run
rm -r /
or to delete any other system dir.
But I think that it's safe to do with any other (user-defined) dir -
@dc42 For that reason you must now add
--no-preserve-root
torm
to actually wipe your root directory Disallowing the root directory (/
or0:/
) from a recursive delete request sounds sensible, though. -
@chrishamm @dc42 sorry for tagging you but is there any chance of including this in v3.5?
@AndMaz we'll try to include this in one of the 3.5beta or release candidate builds.
@dc42 thank you for the https://github.com/Duet3D/RepRapFirmware/commit/73d1509f6bf2efe8e9c200b1327a20dcd2d8989a
Is there any ETA for the v3.5beta3?
@AndMaz I hope around the end of next week.
