Part fans no spinning on T1 and T3 on new e3d Tool Changer
Send these in turn to test all the fans
M106 P1 S1 H-1
M106 P2 S1 H-1
M106 P3 S1 H-1
M106 P4 S1 H-1
M106 P5 S1 H-1
M106 P6 S1 H-1
M106 P7 S1 H-1
M106 P8 S1 H-1P# addresses the fan
H-1 turns off thermostatic mode so they can be manually controlled.
S1 sets them to full power. -
can you snap a close up photo of the fan headers on the duex? Sometimes there is visible damage to the fan mosfets.
Ok, so please recap for me, since it's been a long thread.
When sending the fan commands I posted above, which fans do not work?
For the fans that do not work, you have tested the fans themselves in other working ports to confirm they actually work there?
@Phaedrux P106 commands for T1 and T3 don't work. All others do.
@rmilyard said in Part fans no spinning on T1 and T3 on new e3d Tool Changer:
M950 F1 C"fan1"
M950 F3 C"duex.fan3"So fan1 is on the Duet and Fan3 is on the Duex. Correct?
@Phaedrux said in Part fans no spinning on T1 and T3 on new e3d Tool Changer:
@rmilyard So none of the T1 and T3 fans work? Not even hotend fan.
@Rushmere3D so think found issue. If I get the fans anywhere near the extruder the fan stops. I have not tried to steal washers and still doesn't work.
Fans need to be away from stepper almost half inche. Anything can think other than steel washers?
I have some zinc washers but ones I have are thick. Going order some from Amazon.
Thanks all for help! It was combo that my old harness had wire issue and these 2 fans needed zinc washer. Seems like fan working now.
