Can't connect to wifi after updating to DuetWiFiServer_2.1b2
It keeps giving me the error:
WiFi module reported:[Warning: Maximal number of characters per line exceeded! Check the line break settings in Terminal > Settings > Text or increase the limit in Terminal > Settings > Advanced.How do I fix this without being able to connect to the web terminal?
@Caveman that error is about the settings in YAT. you need to change those so you can see the rest of the output
@jay_s_uk got it fixed now bit wifi still fighting with me.
HTTP sessions: 0 of 8
= WiFi =
Network state is changingMode
WiFi module is idle
Failed to get WiFi status
ok
Error: failed to retrieve WiFi status message: SPI timeout
WiFi module is idle
Error: failed to change WiFi mode: SPI timeout -
@Caveman this looks like the same issue reported here https://forum.duet3d.com/topic/31075/3-5-0b1-wifi-error-spi-timeout/12
maybe @T3P3Tony can comment -
@Caveman can you downgrade to 1.27 and see if the issue clears up please.
