need help with config.g for cr touch and swiss drive
System - Ender 3 v1 with duet2 wifi, swiss direct drive extruder, CR touch,
I changed the setting in config.g for swiss direct drive and CR touch. Does this look correct?
Original
;Z-Probe
M574 Z1 S2 ; Set endstops controlled by probe
M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
M307 H4 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
M558 P9 H2.5 F120 T6000 ; Set Z probe type to bltouch and the dive height + speeds
G31 P25 X-48 Y-10 Z1.240 ; Set Z probe trigger value, offset and trigger height
M557 X15:185 Y50:220 S35 ; Define mesh gridModified
M950 S0 C "io7.out"
M558 P9 C "Io7.in" H5 F120 T6000
G31 P1000 X-48 Y-10 Z2.5 ; Set Z probe trigger value, offset and trigger height
M557 X15:185 Y50:220 S35 ; Define mesh gridSwiss direct drive changes
original
M92 X80.00 Y80.00 Z400 E90 ; Set steps per mmto
M92 X80.00 Y80.00 Z400 E135
original config.g file anything out of place?
; generated by RepRapFirmware Configuration Tool on Thu Sep 06 2018 21:21:12 GMT-0700 (Pacific Daylight Time); General preferences
M83 ; ...but relative extruder moves; Network
M550 Pe3 ; Set machine name
M552 S1 ; Enable network
;*** Access point is configured manually via M587
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M569 P0 S0 ; Drive 0 goes backwards
M569 P1 S0 ; Drive 1 goes backwards
M569 P3 S0 ; Drive 3 goes backwards
M92 X80.00 Y80.00 Z400 E135 ; Set steps per mm
M566 X1000 Y1000 Z100 E30000 ; Set maximum instantaneous speed changes (mm/min)
M203 X6000 Y6000 Z500 E1500 ; Set maximum speeds (mm/min)M201 X300 Y300 Z100 E5000 ; Set accelerations (mm/s^2) was 500 you changed it to 300 for stall guard
M906 X500 Y500 Z500 E1000 I30 ; Set motor currents (mA) and motor idle factor in per cent
M84 S300 ; Set idle timeout; Axis Limits
M208 X235 Y235 Z250 S0 ; Set axis maxima; Endstops
M574 X1 Y1 S1 ; Set active high endstops; Z-Probe
M557 X15:185 Y50:220 S35 ; Define mesh grid; Heaters
;M305 P1 X150 T"K" ; Set THERMOCOUPLE parameters for heater 1 X150 is the right channel (terminal block) on the daughterboard. X151 is the left channel.
M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
M143 H1 S345 ; Set temperature limit for heater 1 to 345C; Fans
M106 P0 S0 I0 B0.5 F250 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 B0.5 F500 L255 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Minimum Speed is 1/3 aka 87 Thermostatic control is turned on triggered at nozzle temp 45;
M106 P2 S0 I0 B0.5 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Automatic power saving
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss; Custom settings
M591 D0 P5 C3 R10:300 E3.0 S1 ; Duet3D laser sensor for extruder drive 0 is connected to endstop input 3 (E0), tolerance 10 to 120%, 3mm comparison length0
1 out of 1
Please send M122 and M98 P"config.g" in the gcode console and copy and paste the results here. Would like to check your firmware version because your config is using old syntax.
@Phaedrux Thank you for the quick reply, I keep trying to post but it's getting flagged as spam. going to try to break it up.
= RTOS ===
Static ram: 28380
Dynamic ram: 96224 of which 0 recycled
Exception stack ram used: 332
Never used ram: 6136
Task NETWORK ready, free stack 396
Task HEAT blocked, free stack 1256
Task MAIN running, free stack 3568
Last reset 00:01:13 ago, cause: power up
Last software reset at 2020-04-10 15:57, reason: User, spinning module GCodes, available RAM 6060 bytes (slot 2)
Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0041f000, BFAR 0xe000ed38, SP 0xffffffff
Error status: 0
Free file entries: 10
SD card longest block write time: 0.0ms
MCU temperature: min 19.7, current 20.1, max 20.1
Supply voltage: min 24.1, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0
Date/time: 2023-01-26 20:51:20
Slowest loop: 9.78ms; fastest: 0.08ms
Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
Bed compensation in use: none
Segments left: 0
Stack records: 1 allocated, 0 in use=== Network ===
Slowest loop: 201.94ms; fastest: 0.01ms
HTTP sessions: 1 of 8=== Filament sensors ===
Extruder 0 sensor: position 0.00, ok, framing errors 0, parity errors 0, no calibration dataM98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled -
It looks like the top half of the M122 results are missing.
Can you send M115 to get the firmware version summary?
@Phaedrux yeah the spam filter kept me from posting all of it , let me try again,
M115
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.0(RTOS) ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2018-06-05b3M122 part1
Static ram: 28380
Task NETWORK ready, free stack 324
Last reset 00:02:19 ago, cause: power up
Error status: 0
MCU temperature: min 16.1, current 20.1, max 20.4
Supply voltage: min 24.0, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0
Date/time: 2023-01-26 22:13:08
Slowest loop: 24.13ms; fastest: 0.07ms
Bed probe heights: 0.000 0.000 0.000 0.000 0.000 -
@Flynbrd said in need help with config.g for cr touch and swiss drive:
Your board is quite old and the firmware is from 2018.
This would be a good time to update.
If you still have access to DWC. Upload these zip files, one at a time in the system tab. Don't extract them first. Reboot after each. Use M115 in the gcode console to verify the firmware has been applied.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/Duet2and3Firmware-3.3.zip
https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.5/Duet2and3Firmware-3.4.5.zipThat will get your firmware and DWC up to date.
You can see the change logs here:
https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.xFor your config, might be a good idea to run through the configurator tool and generate a fresh set for RRF3.
https://configtool.reprapfirmware.org/StartBackup your existing config files in the sys folder in case you want to switch back to RRF2. It’s easy to switch back and forth, just upload the zip file for the version you want and then upload your config files.
These documents will come in handy during the conversion.
https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview
https://docs.duet3d.com/en/User_manual/RepRapFirmware/Migration_RRF2_to_RRF3
https://docs.duet3d.com/en/User_manual/Reference/Gcodes -
@Phaedrux Thanks again, I didn't realize that the firmware had to be done in steps. I original ran the most current firnware weeks ago and called it a day. Last night I got it all updates done with no issue, now to work on the setting for the mc touch and direct extruder. Thank for all the info provided
@Borgtribble It depends where you start in the upgrade path. If you're already on 3.x it's a lot more straightforward. The order I've given just ensures you have all the files needed in case you want to go back and forth between versions at some point. I include 3.3 because the firmware folder was added in that release.
