CONSTANT AJAX disconnect errors
Loaded on my system. Got a message saying can't rename the file but then it went ahead and updated.
Wont be able to print to later but I can make it run through some large simulation files remotely. -
JavaScript Error
A JavaScript error has occurred so the web interface has closed the connection to your board. It is recommended to reload the web interface now. If this happens again, please contact the author and share this error message:
Script Error: See Browser Console for Detail
Received the above when i resized the browser window, reconnected when the "connect" button is pressed.
Then when i ran M122 and tried to copy the wifi section it disconnected with same errorM122:Network state is running
WiFi firmware version 1.20beta7-nosle
WiFi MAC address a0:20:a6:10:55:89
WiFi Vcc 3.45, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 28552
WiFi IP address 192.168.2.34
WiFi signal strength -45dBm, reconnections 0, sleep mode none
HTTP sessions: 1 of 8
Socket states: 2 0 0 0 0 0 0 0
Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) -
No. One. Mention. The. Clones.
J/k pm where you have seen them
I thought I had some good google fu, but I can't find anything. Mythological creature, maybe?
I've seen 0.8.5 clones, but nothing for Duet Wifi/Ethernet yet.
1. I have put a build of DuetWiFiServer with sleep disabled (version 1.20beta7-nosleep) at https://www.dropbox.com/s/59s7vfkrf50fe0v/DuetWiFiServer-1.20beta7-nosleep.bin?dl=0. Please try it. The previous build (1.20beta6) is at https://www.dropbox.com/s/djs0p4beitjs60t/DuetWiFiServer-1.20beta6.bin?dl=0.
2. Patel, what make and model of wifi router are you connecting the Duet to?
Devid I try my iPhone it same
An AJAX error has been reported, So the current session has been terminated.
HTTP sessions : 1 of 8
Socket states:- 2 0 0 0 0 0 0 0
Responder states:HTTP(1) HTTP(0)…......I connect to the duet to USB ( My desktop )
this is the summery .
USB CONNECT TO DUETm122
SENDING:M122
Used output buffers: 1 of 32 (15 max)
RepRapFirmware for Duet WiFi version 1.19.2 running on Duet WiFi 1.0
Board ID: 08DDM-9FAM2-LW4SD-6J9D6-3SN6L-12ZHY
Static ram used: 21176
Dynamic ram used: 96040
Recycled dynamic ram: 1568
Stack ram used: 4048 current, 5920 maximum
Never used ram: 6368
Last reset 02:34:02 ago, cause: power up
Last software reset reason: User, spinning module GCodes, available RAM 7408 bytes (slot 4)
Software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff
Error status: 0
[ERROR] Error status: 0Free file entries: 10
SD card longest block write time: 0.0ms
MCU temperature: min 34.6, current 35.4, max 36.4
Supply voltage: min 12.0, current 12.0, max 12.2, under voltage events: 0, over voltage events: 0
Driver 0: standstill
Driver 1: stalled standstill
Driver 2: stalled standstill
Driver 3: standstill
Driver 4: standstill
Date/time: 2017-11-09 13:48:43
Slowest main loop (seconds): 0.224121; fastest: 0.000000
MaxReps: 8, StepErrors: 0, FreeDm: 240, MinFreeDm 239, MaxWait: 5259148ms, Underruns: 0, 0
Scheduled moves: 9, completed moves: 9
Bed compensation in use: none
Bed heater = 0, chamber heater = -1
Heater 0 is on, I-accum = 0.0
Heater 1 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is ready with "M122" in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
WiFi firmware version 1.20beta6
WiFi MAC address 2c:3a:e8:0a:f1:18
WiFi Vcc 3.36, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 33592
WiFi IP address 192.168.0.144
WiFi signal strength -42dBm
Reconnections 0
HTTP sessions: 2 of 8
Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)Communication Error
An AJAX error has been reported, so the current session has been terminated.
Please check if your printer is still on and try to connect again
m122
SENDING:M122
Used output buffers: 10 of 32 (15 max)
Last reset 02:36:37 ago, cause: power up
Error status: 0
MCU temperature: min 35.3, current 35.5, max 35.9
Supply voltage: min 12.0, current 12.1, max 12.2, under voltage events: 0, over voltage events: 0
Driver 0: stalled standstill
Date/time: 2017-11-09 13:51:18
Slowest main loop (seconds): 0.079102; fastest: 0.000000
MaxReps: 0, StepErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
Scheduled moves: 10, completed moves: 10
Segments left: 0
WiFi signal strength -43dBm
Reconnections 0
Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) -
12:35:24 PMConnection established!
10:51:05 AMDisconnected.
9:46:14 AMConnection established!
9:46:14 AMPage Load complete!Went for lunch, came back, and disconnected….it did reconnect with connect button but it had bene disco'd for over 90 min which usually is long enough for it to reconnect
Firmware Name: RepRapFirmware for Duet WiFi
Firmware Electronics: Duet WiFi 1.0
Firmware Version: 1.20beta6 (2017-11-03)
WiFi Server Version: 1.20beta7-nosle
Web Interface Version: 1.19.3edit: Made a change to config, rebooted printer....and the below is the printer sitting idle
1:14:26 PMDisconnected.
12:54:22 PMConnection established!
12:54:17 PMDisconnected.
12:38:44 PMConnection established!
12:38:44 PMPage Load complete! -
My system has disconnected again, 8 min after disconnect I can ping it via terminal fine and it still shows as connected in my router page. Connected via connect button.
Will test again when i get one of the locked out disconnects.
Jarery, thanks for your report. What make and model of router are you using?
Patel, thanks for your reports too. have you tried with DuetWiFiServer 1.20beta7-nosleep yet? Also, what make and model of router are you using?
I have 2, an Asus RT-AC3100 as my main and located 3m away, and an Asus RT-AC66U used as a access point located about 12m away. I get similar results with and without the AP router turned on.
Running latest Merlin Firmware, 380.68_4
Edit:
last disconnect at 2:56, its now 4:03 and connect button will not reconnect. Will take a rebootor reset of wifi module. Cannot ping via terminaledit 2: wifi reset (M552 S-1, G4 S1, M552 S1) showed a reconnect on the paneldue screen but could not connect web browser, a power cycle to the printer did work.
I have updated to DuetWiFiServer 1.20beta7-nosleep and am testing it now.
Curiously, I am not sure that they "print simulation" is working. Its been going for 33mins on a print file that should have taken less than 10mins.
I gave up on the print simulation issue. I guess Ill sort that later.
I have been connected since 8:42pm.
I printed a 14 min calibration cube. Success.
Started a 6.5 hour print at 10:45pmFingers crossed for the morning.
Keegan, which main firmware version are you running? Simulation mode was broken in 1.20b2 and b3 but fixed in b4.
You know what? That is it! I am running 1.20beta2.
I am still connected this morning. It has been over 10hrs now. I am starting the third print now.
Running latest Merlin Firmware, 380.68_4.
Just as a related data point – I have two routers also running Asus Merlin 380.68_4. Once is an RT-N66R (https://www.asus.com/us/Networking/RTN66R/) running just as an AP, and the main router/AP is an RT-AC68P (https://www.asus.com/us/Networking/RTAC68P/).
The DuetWiFi usually connects to the RT-N66R.
I've stayed connected for up to 4 hours. I've not left the printer on longer than that yet.
I've had occasional disconnects, but not enough to bother me yet. If I did longer prints on this printer, it might crop up as an issue more often. If my printer is typically on for 3 hours, I might have one disconnect every third session.
I'm running 1.19.2.
John
John, when you get the disconnect, are you locked out or can you just click connect to get back?
Hi all,
Here are two new builds of DuetWiFiServer:
https://www.dropbox.com/s/5cp3w947vonp36s/DuetWiFiServer-1.20b8.bin?dl=0
https://www.dropbox.com/s/8k83pw56gefezqm/DuetWiFiServer-1.20b8-nosleep.bin?dl=0
Those of you having issues maintaining a wifi connection, please try the first one (needs DuetWiFiFirmware 1.20b4 or 1.20b6). If that doesn't improve things, try the second one. The recommended way to install these is to download the one you want, rename it to DuetWiFiServer.bin, then upload it through the Settings->General page of DWC.
If for any reason you can't reconnect after installing it, please try re-installing it by sending M997 S2 via USB or PanelDue. I had to do this once on one of my test systems.
Please report your findings here. As a bonus, access point mode is working in this build.
M997 S0
Error: M997: Firmware binary "DuetWiFiFirmware.bin" is not valid for this electronicsFirmware Name: RepRapFirmware for Duet WiFi
Web Interface Version: 1.19.3- Install worked via panel due.
Jarery, I'm sorry, I should have said rename it to DuetWiFiServer.bin. I have corrected the text. You are still running beta7, so you'll need to do it again.
I've seen both types of disconnects, but only the last disconnect was one where I had to power cycle the printer. It was also the only disconnect I've seen since upgrading to 1.19+. The previous disconnects (same timeout AJAX message) I was just able to hit reconnect from the DWC web page.
