Destroyed USB port - how add another wifi
Hi.
Friend of mine destroyed USB socket on his Duet WiFi board. We must connect the printer to another network - how to send proper comands?
We were trying to do that via PanelDue port, but board is not responding. Also adding M552 etc comand at the end of config.g doing nothing. Do You have any ideas how to do that? -
@button
Ok, I enabled support for paneuldue in config.g and comunication via bossa works over paneldue uart -
The easiest way to add a new SSID would be to create a macro with the M587 command and then execute that macro from the paneldue.
@Phaedrux yes, was also and option for us, but when i told to my friend "remember to enable paneldue in config" i discovered that this was the thing we missed to comunnicate via usb to uart converter
@button do you mean you can communicate over YAT (serial terminal)? Bossa is used for firmware flashing when the firmware is erased. Still, interesting that you can communicate over the PanelDue port; I hadn’t thought of doing that. I guess you made up a cable with USB to PC one end, and Molex KK header at the other end to connect to the PanelDue pins on the Duet? And is this Duet 2 WiFi, or Duet 3 Mini 5+ WiFi?
@droftarts
I'm using usb to uart converter connected with jumper wires to paneldue connector on duet2wifi.Ps. Yes, sorry, i meant YAT
