Tool Fan Speed not showing correctly on status screen
All of the relevant configuration information is in the attached files. For some reason I cannot get the Tool Fan Speed to show up on the status screen. The fan runs 100% on 100% of th e time yet it always shows 0 on the status screen. A copy of the screen and of my config.g file are attached. Any reason this would be the case, and can I change it so it shows the correct speed? Thanks
Duet 2 WiFi Main Screen.docx
Config.g 110122 Duet WiFi .docx -
Which fan are you referring to? Tool fan usually refers to the part cooling fan that is controlled by the slicer during a print.
Where are you seeing 0 on the status screen? Your photo shows the general settings tab.
The hotend fan is usually thermostatically controlled.
M106 P1 C"Hot End" S1.0 L1 H1 T45
L1 sets the minimum speed to full speed.
And you have assigned that fan to be used as the tool fan in the tool definition.
M563 P0 S"Hot End" D0 H1 F1
Based on your config I think you want to change F1 to F0
