Solved File Updates lost after Reboot
After updating system files and or adding new gcode files, the system recognizes the changes or additions. However, after rebooting the system, the file system reverts to an older date. Note, I have 4 machines with the identical setup, but I am only seeing this behavior on the one machine. Possible file corruption???Currently running:
Board: Duet 3 MB6HC (MB6HC)
DSF Version: 3.3.0
Firmware: RepRapFirmware for Duet 3 MB6HC 3.3 (2021-06-15) -
@tmreith given this is running in SBC mode maybe @chrishamm has some troubleshooting steps.
@T3P3Tony Yes, running SBC
@tmreith said in File Updates lost after Reboot:
DSF Version: 3.3.0
Firmware: RepRapFirmware for Duet 3 MB6HC 3.3 (2021-06-15)Update firmware? I believe there were some fixes recently on file saving.
@tmreith What are you doing to "reboot the system"?
@tmreith Possibly damaged microSD card? Try exchanging it, ideally with an A1- or A2-rated microSD card.
@chrishamm Yes, microSD card damaged and was in forced ready-only mode. I replaced with a new microSD A1 and back to normal. Thanks!
