Firmware Update
How do I know which version I have?
Assuming you mean firmware version, press "Setup" - the version number is at the top of that screen
I did not, I meant hardware version, that link has files for each size and version panel due. I found a site differentiating the first two to know I have a v2, but idk what a v3 looks like haha
It is written on the board.
How long have you had your board I very much doubt there are any V3 Boards out in the wilds yet the Github page does say it is forthcoming and using a different display?
Yes the PCB revision is written on the back of the board (1.0, 1.1, 2.0 or 3.0). Version 3.0 boards started shipping a few days ago. They work with the same displays as the previous versions, although there is also an experimental build (7.0E) for a different sort of display that we are experimenting with.
I understand that updating the firmware doesn't require the steps in the OP.
But changing the functionality does.
(not that I am going this route, but in case I ever wanted to)It would be good to know the answer to
Download and install Eclipse Neon 2.
-Okie Dokie, no download link, so head to google and find this. http://www.eclipse.org/downloads/eclipse-packages/ Which of the 159 versions do I need? Who knows.Since it is documented, I think it should be made claer
Many Thx
Pete
The one you need is Eclipse IDE for C/C++ Developers. I'm using Eclipse Oxygen now. I'll update the readme file.
For the v1.1 paneldue board, which release 1.17 file is the correct version for the 7" screen? I only see V2 and V3 listed. Is the older revision of the boards limited to 1.16 revision?
The V2 file will work on V1 and V1.1.
Thanks David!
