Euclid facility
config.g
; ================ General preferences ============
M550 P"duet3" ; set printer name
M669 K1 ; select CoreXY mode; ================ Network ========================
M552 S1 P192.168.1.116 ; enable network and acquire dynamic address via DHCP
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M586 P2 S0 ; disable Telnet; ================ Drives mapping =================
M569 P1 S0 ; physical drive 0.1 goes forwards - X driver
M569 P2 S0 ; physical drive 0.2 goes forwards - Y driver
M569 P3 S1 ; physical drive 0.3 goes forwards - Z1 Right driver
M569 P4 S0 ; physical drive 0.4 goes forwards - Z2 Left driver
M569 P0 S1 ; physical drive 0.0 goes forwards - extruder driverM584 X1 Y2 Z4:3 E0 ; set drive mapping
; ================ Drives settings ================
M92 X200.00 Y200.00 Z800.00 E693.55 ; set steps per mm - for Matrix extruder:E324.214M566 X500 Y500 Z800 E600 ; Set maximum instantaneous speed changes (Jerk) (mm/min)
M203 X20000 Y20000 Z600 E3600 ; Set maximum speeds (mm/min)M201 X1000 Y1000 Z100 E600 ; Set accelerations (mm/s^2)
M906 X1350 Y1350 Z1200 E700 I10 ; Set motor currents (mA) and motor idle factor in per cent
M84 S60 ; Set idle timeout; ================ Independent Z leveling (original 2 z-axis) =================
M671 X-45.0:364.0 Y165.0:165.0 S5.0 ;bed compensation
; ================ Axis Limits ====================
M208 X-3.50 Y0 Z0 S1 ; Set axis minima
M208 X330 Y320 Z350 S0 ; Set axis maxima; ================ Endstops =======================
M574 X1 S1 P"io0.in" ; configure active-high endstop for low end on X via pin io0.in
M574 Y2 S1 P"io1.in" ; configure active-high endstop for low end on Y via pin io1.in
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; ================ Z-Probe ========================
;M558 P8 C"io2.in" A5 H5 F120 T15000 ; set Z probe type to unmodulated and the dive height + speeds (for Mini IR sensor M558 P8 C"io2.in" A2 H5 F120 T15000)
;M558 K0 P5 C"io8.in" H8 F300 60 T9000 A3 S0.01
M558 K0 P5 C"^io2.in" H8 F300 60 T9000 A3 S0.01 ;
;M558 K0 P5 C"^io2.in" H8 F300 T9000 A3 S0.01 ; K0 for probe 0, P5 for NC switch, C for input pin,;G31 P50 X-1 Y-20 Z1.444 ; Set Z probe trigger value, offset and trigger height
G31 K0 P500 X-27.955 Y-18.716 Z1.033 ; CHECK for LOOSE things first! set Z probe triggerM556 S50 X0 Y0 Z0 ; set orthogonal axis compensation parameters
M557 X20:270 Y20:270 P3 ; Define mesh grid
; ================ Heaters ==============================================
M308 S0 P"temp0" Y"thermistor" A"Bed" T100000 B3950 ; configure sensor 0 as thermistor on pin temp0
M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 (if NOT using SSR - delete Q10)
M307 H0 R0.312 K0.313:0.000 D13.50 E1.35 S1.00 B0 ; disable bang-bang mode for the bed heater and set PWM limit
M143 H0 S100 ; set temperature limit for heater 0 to 100CM308 S1 P"temp1" Y"thermistor" A"Hotend" T107537 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
M950 H1 C"out2" T1 ; create nozzle heater output on out1 and map it to sensor 1
M307 H1 R2.451 K0.445:0.102 D5.36 E1.35 S1.00 B0 V24.1 ; disable bang-bang mode for heater and set PWM limit
M143 H1 S280 ; set temperature limit for heater 1 to 280C; ================ Fans & Lights ==================
M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
M106 P0 S0 H1 T35 ; set fan 0 value. Thermostatic control is turned on
M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
M106 P1 S0 H-1 C"Layers Fan" ; set fan 1 value. Thermostatic control is turned off
M950 F2 C"out9" Q500 ; create fan 2 on pin out9 and set its frequency (lights)
M106 P2 S0.2 H-1 C"Lights" ; set fan 2 value. Thermostatic control is turned off (lights); ================ Tools ==========================
M563 P0 D0 H1 F1 ; define tool 0
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C; ===================== Custom settings ====================
M572 D0 S0.05 ;pressure advance Set bowden extruder elasticity compensation for E0
M207 S1.5 F3600 Z0.01 ; Set firmware retraction parameters
M564 H0 ; Let the Jog buttons work blv: added to allow jog buttons
; ================ Miscellaneous ==================
;M575 P1 S1 B57600 ; enable support for PanelDue
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
there is something that I did not understand guys is that I must put the command m 401 and m 402 in deploy and retract or in home z and bed?
@sgk you should only need to use M401 at the start of bed.g and M402 at the end. That will pick up the probe once and put it down once only, instead before/after every probe point. Also they are useful for testing pickup and release of the probe.
OK i understand thank you
@sgk can you post your Homeall.g, homez.g, deployprobe.g, retractprobe.g, and bed.g put these in quotes (thats the little </> button above the reply box) I suspect your using a mish mash of different configurations which is causing the issue as @DC42 is alluding too.
@jumpedwithbothfeet
hello it's true that I'm a little lost. thank you all for your patience and your help.retractprobe.g homez.g homeall.g deployprobe.g config.g bed.g
@sgk all of this is pretty well addressed in the Euclid docs.
https://euclidprobe.github.io/06_macros_overview.html
there are annotated picures and macro files.
if you need more help, the euclid discord might be faster, i dont come here often.
and just so you know, Euclid does not like it when you call it klicky
This post is deleted! -
@sgk in bed.g comment out M401 and M402 just like below and try it again
; bed.g ; called to perform automatic bed compensation via G32 ; ; generated by Ben Levi - BLV developer as a basic version M561 ; clear any bed transform G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G90 ; absolute positioning G28 ; home all ;G30 P0 X10 Y175 Z-99999 ; probe near a leadscrew, half way along Y axis ;G30 P1 X330 Y175 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors G29 S0 ; probe the bed and enable compensation M291 P"Leveling finished !" R"Probing.." S1 T2 G1 Y8.5 F6000 ; Pick Up Klicky G1 X20 F2000 ; G1 X0 F1000 ; Pick Up Klicky G1 Y30 F1000 ; G1 Y50 F6000 ; Pick Up Klicky ;M401 ; deploy Z probe (omit if using bltouch) G30 P0 X10 Y175 Z-99999 ; probe near a leadscrew, half way along Y axis G30 P1 X330 Y175 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors ;M402 ; retract probe (omit if using bltouch) G1 Y250 F6000 ; Drop Klicky G1 X0 F6000 ; Drop Klicky G1 Y8.5 F6000 ; Drop Klicky G1 X170 F6000 ; Drop Klicky G1 Y170 F6000 ;
@jumpedwithbothfeet Ha OK I will modify and I will let you know thank you
@sgk I have just realised you should also move the M291 to the bottom of the file and also comment G29 S0 out, just like this -
; bed.g ; called to perform automatic bed compensation via G32 ; ; generated by Ben Levi - BLV developer as a basic version M561 ; clear any bed transform G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G90 ; absolute positioning G28 ; home all ;G30 P0 X10 Y175 Z-99999 ; probe near a leadscrew, half way along Y axis ;G30 P1 X330 Y175 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors ;G29 S0 ; probe the bed and enable compensation ;M291 P"Leveling started!" R"Probing.." S1 T2 G1 Y8.5 F6000 ; Pick Up Klicky G1 X20 F2000 ; G1 X0 F1000 ; Pick Up Klicky G1 Y30 F1000 ; G1 Y50 F6000 ; Pick Up Klicky ;M401 ; deploy Z probe (omit if using bltouch) G30 P0 X10 Y175 Z-99999 ; probe near a leadscrew, half way along Y axis G30 P1 X330 Y175 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors ;M402 ; retract probe (omit if using bltouch) G1 Y250 F6000 ; Drop Klicky G1 X0 F6000 ; Drop Klicky G1 Y8.5 F6000 ; Drop Klicky G1 X170 F6000 ; Drop Klicky G1 Y170 F6000 ; M291 P"Leveling finished !" R"Probing.." S1 T2
@jumpedwithbothfeet yes OK
thank you
@jumpedwithbothfeet The m 401 and m 402 I have to leave like this with [;]
@sgk yes thatβs the quickest way to get you up and running, but itβs not the conventional way, it all depends on how you what to use your Euclid probe, I think most people would use M401 and M402 in which case you would need to remove the G1 codes from bed.g, homeall.g, and homez.g, see how you get on, the best thing about rrf is itβs flexible, there are multiple ways of achieving the same thing.
@jumpedwithbothfeet I will already change and see how it works.
@jumpedwithbothfeet
hello I changed but it's the same nothing to change when I do home and after g29 or g32 it doesn't probing the bed. -
@sgk in homez.g remove or comment out -
G1 X152 Y166.4 F6000 ; go to first probe point G30 ; home Z by probing the bed
in homeall.g remove or comment out -
G1 X170 Y180 F6000 ; go to first probe point X11.5 Y65.8 Z0 The coordinate put the Z sensor in the center of the bed. G30 ; Probe
repost both files once you have changed them
@jumpedwithbothfeet I will change and see
I changed but when I run g32 or g29 it doesn't work
@sgk ok back to the beginning, when you home all axis, the printer does this? the euclid probe is detected and you can move all axes of the printer independently?
