Solved 6HC + 1LC. Input shaper No accelerometer found!
When I go to record a motion profile, I get the error No accelerometer found. M122 B121 returns with Accelerometer detected: yes, status: 00.
Firmware on the 1LC is version 3.3
Firmware on the 6HC is 3.4.1Any advice or help to get me in the correct direction?
I forgot to mention that the 1LC is version 1.2
@tmitch205 I take it you have M955 in your config?
@jay_s_uk Correct
M955 P121.0 I10
@tmitch205 are you able to get a photo of the back of the toolboard?
@jay_s_uk I have a crap ton of the front, but none of the back. It will be a bit before I can get a pic of rear.
@tmitch205 What happens if you enter the M955 P121.0 I10 into the console?
@gloomyandy It sends a successful message in the console. I will get the exact wording in about 30 minutes.
@tmitch205 I think you should upgrade the 1LC firmware to match the 6HC and try again....
@gloomyandy I will do that and report back. Thank you for the suggestion.
@gloomyandy Sorry for the late reply. You know how it is when you get involved with printers... time just seems to disappear.
Updating the firmware resolved the issue. Thank you.
