DWC failure
Woke up to DWC not working at all this morning.
Getting blank page. Tried obvious stuff like rebooting.Was running 3.4b7 all the way around.
Using Duet2Wifi w/ Duex
Built new SD card w/ clean config:
DWC 3.4.1
RRF 3.4.1Issue persists across clean config and upgrade.
telnet to port 80 produces no output from DWC.Able to print from SD card via paneldue.
Any help troubleshooting would be greatly appreciated.
Sounds like it's responding over USB and the PanelDue is working otherwise?
Can you send M122 and M98 P"config.g" and post the results?
Is the wifi module LED lit up?
Weirdest thing... It's back up now.
WiFi module has been up the whole time (it was responding to pings(ICMP))
Telnet to ports 23 and 80 were getting nothingI did not connect directly to USB with my workstation and try to print.
I did put a file in the gcode directory on the SD card by hand and was able to print.I did set up and connect an OctoPi as a possible work around and it did seem to be communicating but I had not had a chance to print with it.
I've been beating my head against my desk for the last 8 hours trying to get this sorted
and I walk away from my desk for few minutes and its back up.I do not like issues that seem to resolve themselves in this way for obvious reasons.
It may have something to do with burning some sage and swinging a dead chicken around but.... That's dinner so it would have happened regardless.
Just for posterity:
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.1 (2022-06-01 21:05:28) running on Duet WiFi 1.02 or later + DueX5
Board ID: 08DJM-9178L-L2MS8-6JKDA-3S06M-K8HAP
Used output buffers: 3 of 26 (26 max)
Static ram: 23860
Dynamic ram: 76456 of which 12 recycled
Never used RAM 8248, free system stack 96 words
Tasks: NETWORK(ready,37.5%,242) HEAT(notifyWait,0.1%,324) Move(notifyWait,2.9%,292) DUEX(notifyWait,0.0%,24) MAIN(running,59.4%,460) IDLE(ready,0.1%,30), total 100.0%
Owned mutexes: WiFi(NETWORK)
Last reset 01:52:37 ago, cause: power up
Last software reset at 2022-08-15 23:22, reason: User, GCodes spinning, available RAM 8608, slot 0
Error status: 0x0c
Aux0 errors 0,0,0
Step timer max interval 0
MCU temperature: min 15.3, current 23.6, max 28.3
Supply voltage: min 23.9, current 24.1, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/40/40, gc cycles 0
Events: 1 queued, 1 completed
Driver 0: standstill, SG min 0
Driver 1: standstill, SG min 0
Driver 2: standstill, SG min n/a
Driver 3: standstill, SG min 0
Driver 4: standstill, SG min n/a
Driver 5: standstill, SG min 0
Driver 6: standstill, SG min 0
Driver 7: standstill, SG min 0
Driver 8: standstill, SG min n/a
Driver 9: standstill, SG min n/a
Driver 10:
Driver 11:
Date/time: 2022-08-29 15:49:42
Slowest loop: 135.33ms; fastest: 0.17ms
=== Storage ===
Free file entries: 10
SD card longest read time 1.9ms, write time 14.1ms, max retries 0
DMs created 83, segments created 27, maxWait 3482734ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
Scheduled moves 40317, completed 40317, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
=== AuxDDARing ===
Heater 0 is on, I-accum = 0.0
Heater 1 is on, I-accum = 0.5
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty
=== Filament sensors ===
Extruder 0: pos 247.50, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
=== DueX ===
Read count 1, 0.01 reads/min
=== Network ===
Slowest loop: 40.98ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.26
WiFi MAC address 84:0d:8e:ad:74:86
WiFi Vcc 3.40, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 24680
WiFi IP address 192.168.1.226
WiFi signal strength -37dBm, mode 802.11n, reconnections 0, sleep mode modem
Clock register 00002002
Socket states: 4 0 0 0 0 0 0 0
M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is enabled on port 23
Error: Heater 1 not switched on due to bad model - WiFi -
