Orbiter 2 extruder mounting for Smart effector with Magball arms
@fred-y Its 1.5mm.
You do need to be able to rotate your hot end - would be difficult with a v6 where the heater block really has to be aligned with the part cooling fan -
@adrian52 said in Orbiter 2 extruder mounting for Smart effector with Magball arms:
@fred-y Its 1.5mm.
You do need to be able to rotate your hot end - would be difficult with a v6 where the heater block really has to be aligned with the part cooling fanIt actually depends. The earlier versions that shipped with the metal nut had a fine pitch..
@adrian52 Wow! Looks solid. Is this design available for download somewhere? Or is it an "alpha" version?
I have this on my Big Delta.
Does any of you have a view as to how much the size of the Smart Effector should be increased to allow the Orbiter 2 to be mounted directly on it?
Will you want to keep 55mm c/c on balls or go a bit wider there also? -
@tecno said in Orbiter 2 extruder mounting for Smart effector with Magball arms:
Will you want to keep 55mm c/c on balls or go a bit wider there also?Go wider.
Good, like that approach a lot. You should also have a look at Phaetus 4-screw mounting of the hotend.
@dc42 yes, definitely look at supporting mounting a dragon or dragonfly hotend
This is my take for direct extruder sherpa mini
[url=https://ibb.co/jh3q5yK][img]https://i.ibb.co/zsPC5Xc/20220717-113347.jpg[/img][/url]
[url=https://ibb.co/3Mvh1hX][img]https://i.ibb.co/P9MCxCp/20220717-113353.jpg[/img][/url]
[url=https://ibb.co/HGjsNyM][img]https://i.ibb.co/r5VSbhL/20220717-113358.jpg[/img][/url]
[url=https://usefulwebtool.com/math-keyboard]subscript in math[/url] -
This post is deleted! -
@vapvap I have just added it to the thingiverse thing 5402227
@dc42 I find an extra 12mm allows the orbiter 2 to be mounted horizontally with a minimal vertical filament path between extruder and hotend, whilst maintaining the 55mm arm separation. I find the 55mm separation works well - you don't have to modify carriages, and the performance seems fine. I have been printing at 250mm/sec, with travel at 300mm/sec.
@adrian52 Thanks a lot.
What plastic do you use/recommend for this part? -
@vapvap it works OK with PLA, although I am currently printing a set in nylon - will report if I can see a difference.
@dc42 I've made a quick and dirty model approximating how big the smart effector would need to be for me to be able to mount an Orbiter directly on-top of where the bolt is. With my specs it would need to be a distance of around 71.3 mm between the ball studs. I've angled the extruder by 15 degrees to make it take slightly less space in between the arms.
The cones visualize the maximum reach of the arms for my delta with a 350mm bed and 440mm arms.
Its probably possible to make it an even tighter fit by tweaking the parameters but I thought it was good enough to continue the discussion ¯\(ツ)/¯
@snimax thanks, that's very useful. Did you leave the spacing between adjacent ball studs in the corners the same, or did you increase that too?
@snimax tried to take a picture of my version from the same viewpoint
I have maintained the 55mm spacing, and find a good fit with the motor orientated as shown. The effector is in its furthest 'Y' position, where the arms are closest to the motor.
@dc42 I tried to keep the spacing between the balls at the corners. I think there was a formula somewhere of the stability of the effector where you wanted to keep that spacing short but I cant recall where I saw it
@Adrian52 Looks good! I like the idea of having a straight and much shorter filament path, compared to my adapter where the filament is in a slight s-shape Haven't gotten around to compare it yet though
