I could use some help
@mac
I'm not going anywhere.
@fcwilt okay, here are the results: with X endstop pressed down, M119 reports X at min stop. With Y endstop pressed down, M119 reports Y at min stop.
Interestingly, M119 continues to report Z at min stop even though I'm NOT pressing it down?
; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X220 Y220 Z240 S0 ; set axis maxima
@fcwilt are the S0 and S1 reversed?
@mac said in I could use some help:
No they are correct.
But, just FYI, there is a simpler form of M208 (at least I think it is simpler)
M208 X0:220 Y0:220 Z0:240
Notice no S0 or S1.
The number before the : character is the min value for the axis specified by the letter.
The number after the : character is the max value for the axis specified by the letter.
I find it easier to remember "min then max" rather then "is it S0 or S1".
That's just me.
@fcwilt for a moment I was confused as to where the 0 was, i.e., the number before the "colon" is . . . .
But I figured it out!
@fcwilt so where do these responses put us?
We are still need to test the X and Y endstop switches to see what M119 reports when a switch is pressed or not pressed.
@fcwilt with X depressed, X is at min stop, everything else is as it has been.
With Y depressed, Y is at min stop, everything else is as it has been.
@fcwilt the Z-endstop is still saying it's at the min stop.
@fcwilt Z must be wrong, don't you think?
Fantastic.
So we know the X and Y endstop are working.
But the Z is not. It should do the same as the X and Y.
Please do this - from the DWC console execute M574 by itself - it should report how each endstop is configured.
6/27/2022, 9:17:19 AM M574 Endstop configuration: X: low end switch connected to pin !io5.in Y: low end switch connected to pin !io6.in Z: low end switch connected to pin io2.in
@fcwilt something about that doesn't look right?
Great. You getting the hang of this, aren't you!
So it says the Z endstop is configured on the low end, is connected to io2.in and does not have the ! character because the white wire is connected to the NO connection on the switch.
But it seems that pressing or not pressing the Z endstop switch doesn't change what M119 reports.
Did you verify that the Z endstop switch is still plugged onto the IO2 connector?
@mac are you sure z endstop is connected to io2? Check with wiring diagram. https://docs.duet3d.com/Duet3D_hardware/Duet_3_family/Duet_3_Mini_5+_Hardware_Overview#wiring-diagram
@droftarts hey's baaaaaaaaaccccccccckkkkkkk
I just moved the white wire on the 5 pin io2 connector from io2_out to io2_in, The green wire is still in the center of the connector / connected to GND.
Well that certainly should make a difference.
Please run the M119 tests with the Z endstop switch pressed and not pressed.
@droftarts @fcwilt M119 reported all of the axis are NOT STOPPED, WAIT A MINUTE!!!!!
6/27/2022, 9:28:48 AM M119 Endstops - X: not stopped, Y: not stopped, Z: at min stop, Z probe: not stopped 6/27/2022, 9:28:11 AM M119 Endstops - X: not stopped, Y: not stopped, Z: not stopped, Z probe: not stopped
Look at the timecode, between :11 and :48 Z changed!
@droftarts @fcwilt I knew there was a reason I named this machine Frankenstein's Cinderella.
