Show current chamber temperature on 12864-display?
Hi.
I'm trying to configure my 12864-display to show the current chamber temperature, but can't find an N-parameter for the menu system that works. I have tried N90, but this seems to only work for an actively heated chamber, and only displays a zero value.My chamber temperature sensor is defined like this:
M308 S2 P"0.spi.cs2" Y"dht22" A"Chamber Temp" ; Chamber temp sensor
(this is a Duet2 Maestro board running RRF 3.4.1)
Do I need to define a (fake) chamber heater to make the N90-code work? Is this even possible?/Ö
@örjane if you can wait for firmware 3.5beta1, in that version you can display the value of any object model expression on the 12864 display.
Hej Örjan,
I have a std thermistor to monotor chamber tempM308 S2 A"Chamber" P"T2" Y"thermistor" T100000 B4092 M950 H2 T2
Ha en bra dag
Bengt -
@tecno Thanks Bengt.
I added the lineM950 H2 T2
to create a "fake" chamber heater. However, I still only get a zero value displayed on the 12864-display; both with codes N90 and N92 for addressing the chamber "heater".
/Ö
Skippa DHT:n = skit
@tecno The sensor itself is working fine. I am actually using the AM2320 which is backwards compatible with the DHT, and I get the correct temperature in the web interface and in the object model. My problem is that I can't get this value to show up on the 12864-display.
OK, sorry I misunderstood. Never played with 12864 display.
@örjane that's not implemented at present, only the existing ability to choose the number of decimal places.
