NEED HELP please
still no luck.
i think my problem is the command promt.
is says
"file name" is not recognized as an internal or external command, operable program or batch file. -
Try the next 2 commands in command prompt window (press ENTER after each entered command):
cd "\Program files (x86)\BOSSA"
bossac.exe –port=COM11 -e -w -v -b PanelDueFirmware.bin -
That command i think got me closer but still no go.
https://imgur.com/a/XQTWNI feel im missing something stupid…....
Yes, you're closer. But your command is referencing "PanelDueFirmware.bin", but the filename you have is "PanelDue-v4-5.0.bin". So Bossa can't find the file you're asking it to find.
So you either need to rename the .bin file, or change the command that you're putting into the command prompt.
Didn't see filename, sorry. So second command should be
bossac.exe –port=COM11 -e -w -v -b PanelDue-v3-5.0.bin -
https://imgur.com/a/DEpnk
Is that it? -
It seems to me you are in right place, firmware is download on the board.
still no luck, i have a black screen that wont turn on. ive checked wiring and made sure its not 1 pin off or backwards.
You have successfully re-installed firmware on the board.
1.
Check that there is a jumper on the voltage select pins, in the 3.3V position.Please check that your board revision is 3.0, to match the firmware you have flashed. The version is printed on the back of the PanelDue controller board.2. If you EITHER press the Reset button (NOT Erase!) OR disconnect and then reconnect the USB connector, the display should turn on and you should see a "Touch the spot" prompt (you don't need to connect it to the Duet to get this). If the screen is still blank, then return both the PanelDue control board and the display to your supplier and ask for a replacement.
will the Paneldue work not plugged into the duetwifi?
is there a software i can use to control the DuetWiFi from my computer and bypass the PanelDue?
It will display all the pages if powered from the USB connector but not connected to the Duet, but the status displayed at the top will be stuck at 'Connecting'.
Yes, you can use the web interface, or a 3D printer host program such as Pronterface connected via USB to the Duet.
Im willing to pay someone to fix my boards. I can give you remote control of my computer to fix it and set it up for me.
