CAN command glossary?
Hi there,
I have been part of developing a CAN-FD enabled machine pendant at work for something unrelated to a 3d printer, but seems like it would be cool if it could also be attach to my home duet 3 setup. Which leads to two questions 1) does the current duet setup allow for a pendant be attached to the CAN bus to send commands to a duet 3 6HC which it could execute across expansion and tool boards and if so 2) is there a syntax/command library out there that? -
@acmeanvil RRF doesn't yet support sending GCode commands to a main board over CAN. We've considered supporting it in the past for use by our test equipment, and we may do so in a future version.
@dc42 Thanks for the quick reply David I will keep an I out for it.
