E0 endstop conflict with U axis and FSR
ok I'm using the E0 endstop per documentation for JohnSL FSR
but reading through setting up IDEX, it says that U axis is hardwired to E0 endstop… does this mean I can't tell U axis to use endstop connected to E1 stop?
Thanks,
Stephen -
hmm I see E0 stop in deux5 will that work as U axis endstop?
You will need to connect the JohnSL board to either E1 endstop input (M558 P6) or the Z probe connector (M558 P5) instead.
