Duet Wifi Thermocoupler Daughter board issue.
So I setup my board with the Duet Thermocoupler daughter board, but i am not getting any readings for "current" except a 2000c and I/O error fault. I read just about every wiki on this site and tried numerous things but nothing changes. i'm using E3D TYPE K THERMOCOUPLE (CARTRIDGE) and have set it in the 0 slot (using 100) on the daughterboard, but nothing i'm still getting the i/o error and 2000c. I did try connecting the Thermocoupler to E0 thermoistore1 on the board and change the G Code to see if maybe the Thermocoupler wire was bad. I did start getting a reading , but it was high like 350c and stable. but it was reading something. so, what does tell me? I'm thinking of either two things; my G code is wrong or the daughter board is bad. As i have tried just about every variation of G code I could think of. I'm at a lost. and i don't know how to troubleshoot the daughter board. I did try taking a wire and jumping over the connection on the daughterboard (read somewhere in the forum or wiki) and still got the same readings. I am open to any suggestions at this point.
NOTE: this is a new printer build, so it hasn't even printed anything yet.
This is my config.g file as it is now:
; Configuration file for Duet WiFi (firmware version 1.17)
; executed by the firmware on start-up; generated by RepRapFirmware Configuration Tool on Fri Oct 06 2017 22:21:06 GMT-0500 (Central Daylight Time)
M111 S0 ; Debugging off
G21 ; Work in millimetres
G90 ; Send absolute coordinates…
M555 P2 ; Set firmware compatibility to look like MarlinM667 S1 ; Select CoreXY mode
M208 X300 Y300 Z300 S0 ; Set axis maxima; Endstops
M574 X1 Y1 Z2 S0 ; Define active low and unused microswitches
M558 P1 X0 Y0 Z0 H5 F120 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
G31 P600 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
M557 X15:285 Y15:285 S20 ; Define mesh grid; Drives
M569 P0 S0 ; Drive 0 goes forwards
M569 P1 S0 ; Drive 1 goes forwards
M92 X80 Y80 Z4000 E420 ; Set steps per mm
M566 X900 Y900 Z12 E120 ; Set maximum instantaneous speed changes (mm/min)
M203 X6000 Y6000 Z180 E1200 ; Set maximum speeds (mm/min)
M201 X500 Y20 Z250 E250 ; Set accelerations (mm/s^2)
M906 X800 Y800 Z800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout; Heaters
;M143 S400 ; Set maximum heater temperature to 260C
;M305 P1 T100000 B4138 C0 R4700 X100 ; Set thermistor + ADC parameters for heater 1 and remap it to channel 100
M305 P1 X100; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Network
M550 PCoreXY ; Set machine name
M552 S1 ; Enable network
M587 Sxxxxxxx P"xxxxxxxxxxxxx" ; Configure access point. You can delete this line once connected
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M586 P2 S0 ; Disable Telnet; Fans
M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Custom settings are not configured
thanks in advance
-curtis
Which version of the thermocouple board is it? If it's the newer version with two Error LEDs on it, you need X150 in the M305 command instead of X100 - see the instructions on the wiki.
That was it. I must have read the wiki a hundred times and did not catch the version of the daughter board. set my G code to 150 and voila, it works. thanks.
I just checked the wiki and although the instruction to use channels 150-153 was included in the Hardware paragraph, it wasn't mentioned in the Firmware Configuration paragraph. I'm sorry if this misled you. I have now corrected it.
