what code to modify for z motors ,one on z and one on e1
@fcwilt if i connect wit yat dwc comes up and everything looks correct, but when i try to home or make any commands via the panel due nothing happens except a pop up that says files on card 0. i installed the latest firmware, i also tried formatting a new sd card with the /firmware and /sys files from the zipped config all in 1 download, still behaves the same
@dallash said in what code to modify for z motors ,one on z and one on e1:
So you cannot connect to the DWC via a browser?
@fcwilt no
@dallash always says connecting
@dallash i'm giving up for today. thanks
I suggest you start here: https://docs.duet3d.com/en/How_to_guides/Getting_connected/Getting_connected_to_your_Duet
@phaedrux I cant connect even with yat now. i get this error when trying to update drivers
What OS?
@phaedrux win 7 ultimate, 64 bit
That's a blast from the past. Does anything new show up in device manager even without the driver?
@phaedrux ok i finally got everything talking, everything works from dwc thru a wifi browser, but nothing works from the panel due, display looks fine, but if you touch home it pops up a screen that says files on card 0. i can find nothing that responds from the panel due
Does the PanelDue have the correct firmware required by the current Duet firmware?
@fcwilt panel due v3.0a 5i display firmware 1.17 not sure what firmware to use with rrf 3.4! would this be correct ? (PanelDueFirmware-3.4.1-pre1-v3-5.0.bin)
IMG_0006.jpg -
IMG_0006.jpgHere is some information:
https://docs.duet3d.com/User_manual/RepRapFirmware/Updating_PanelDue
@fcwilt I UPDATED the panel due firmware. but still have unresponsive panel due.
Add this line to the beginning of your config.g
M575 P1 B57600 S1
And change the baud setting on your PanelDue settings to
57600
to match. -
Well it's still not connecting.
First thing to check would be the wiring.
How do you have it connected?
@phaedrux AWESOME! THAT DID THE TRICK! THANKS SO MUCH!!!!
@fcwilt I have the ribbon cable and the 4 wire lead connected.
